get battery status on the command line
Apologies for the newbie question, but I've been stymied on this so far-- what's a good way to get the PBP battery status (percentage or time remaining, plugged in or on battery, etc) on the command line?
If it matters, I'm on Manjaro 20.04.
(04-04-2020, 06:10 PM)rossk Wrote: Apologies for the newbie question, but I've been stymied on this so far-- what's a good way to get the PBP battery status (percentage or time remaining, plugged in or on battery, etc) on the command line?
On Manjaro,  you can use the tlp-stat  command: tlp-stat -b gives basic battery info.  tlp-stat --help gives further explanations/possibilities.
You can also cat some of the files in the /sys/class/power_supply/cw2015-battery directory.
There are other programs that will give battery  statistics if those ideas don't work for you.  Just web  search on something like
"linux battery statistics from console".
Yeah-- most of the answers I got from general searches like that, weren't giving me useful results (things like the acpi tools, which aren't helpful on the PBP).
but, /sys/class/power_supply/cw2015-battery/ is exactly what I was looking for. Thanks!
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,416 03-15-2025, 01:47 AM
Last Post: frank_philip
  Improved battery life with TLP daemon Surehand53 0 3,576 12-30-2024, 07:46 AM
Last Post: Surehand53
  Is the same DD command appropriate for writing EMMC and SD cards wpeckham 4 10,752 09-23-2021, 09:19 PM
  Enabling spekaer/Connecting to bluetooth from command line axisarm 1 5,246 08-06-2021, 04:29 PM
Last Post: nfms
  Battery gauge issue (mainline kernel) lfourquaux 4 11,470 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 30,955 05-14-2021, 01:18 PM
Last Post: djhnsn
  Battery charge threshold xNix 1 5,434 04-17-2021, 07:13 AM
Last Post: Damon
Question Manjaro arm + sway - battery indicator broken mfashby 6 13,939 02-20-2021, 04:07 AM
Last Post: mfashby
  Status stonepound 0 3,099 11-18-2020, 01:35 PM
Last Post: stonepound
  Possible battery and performance improvement xehartnort 4 10,041 11-09-2020, 12:26 AM
Last Post: rimaille
