mobile data - always in use?
how can i turn off mobile data?
i somehow have the feeling that mobile data is used whenever it is on.
and since i was not able to disable it, it eats my balance on the new prepaid contract
how can i check if it is on? is wifi higher priorized than mobile data?
Not certain on different variations of OSes, but all I have used you can go into settings and turn off mobile data.
Though if you are not actively using your data, watching video's, browsing or such, I would not expect very much data will be "used" anyhow.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(04-02-2020, 06:44 PM)bcnaz Wrote: all I have used you can go into settings and turn off mobile data.
then please tell me where i can disable that in postmarketos, because i did find nothing in settings.
(04-02-2020, 06:44 PM)bcnaz Wrote: Though if you are not actively using your data, watching video's, browsing or such, I would not expect very much data will be "used" anyhow.
dont get me wrong but sometimes it is really better to say nothing than to "guess" or "believe" something and tell the user to do the same. because this can fuck him hard.
i live in a country where i have to pay about 10 EUR for 1 mb.
when i do an apk update and this goes over mobile data, my budget is gone.
It doesn't help that you don't tell us what DE you're using. With Plasma Mobile you can just press the wwan toggle in the top drawer. I'm not sure about Phosh as I don't use it personally.
Sorry, my bad. Yes it is Phosh
i have "Mobile Broadband" which i can disable. But i am not sure if i want that as i want to be able to recieve phone calls. But i do not want "Mobile data". I dont know if that is the same?
And if i have this enabled, is "Mobile data" on by default? And if so, is this used as default or is wifi higher priorized? Questions over questions... guess i will try plasma.
Phosh:
Go to settings > Mobile> turn-off Mobile Data
  Really no need for the Profanity
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
There is no: settings > mobile
hmm....
  I go to 'settings'
From there I pick 'mobile'
    next:
( looking under the heading 'Network' )
there I find 'mobile data' and 'Data Roaming'
 (looking at  the phone now)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(04-03-2020, 01:31 PM)bcnaz Wrote: hmm....
  I go to 'settings'
    next:
https://ibb.co/0YFX9F3
hmm..
my screen reads:
wifi
Mobile
Bluetooth
Slightly different menus
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 5,775 11-18-2024, 02:23 AM
Last Post: linmob
  Gnome mobile user641 1 3,151 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 5,800 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 4,686 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 5,598 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 3,682 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  No Application Data PMOS 21.12.1 Captain1ndustry 4 7,610 08-12-2022, 07:42 AM
Last Post: Gon
  Disable mobile data auto-enable on boot 64_Tesseract 3 5,412 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 2,335 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 3,284 03-24-2022, 04:10 AM
Last Post: yasmi
