Flash U-Boot
I just booted the Manjaro eMMC installer from SD and flashed my eMMC storage. Everything works as it is supposed to be. I have a running system I can log into.
My first step was to run pacman -Suy. It prints some lines concerning u-boot, which wants me to flash files to my install drive.Is my install drive the eMMC or the block devices called mmcblkboot0 and mmcblkboot1? I have already flashed mmcblkboot0 but I am unsure if this is the right place and decided to ask here before rebooting and having to reflash a bricked device.
Where do I put idbloader.img and i-boot.itb go on the pinebook pro? What is supposed to be on mmcblkboot0 and mmcblkboot1?
Yours
Stefan
>idbloader.img
raw, starts at sector 64
> i-boot.itb ,, u-boot
in mmcblk1boot0 probably, starts at sector 16384 (8M)
mmcblk1boot1 likely empty
ATF starts at 12M, hasn't changed
(03-21-2020, 08:41 PM)wdt Wrote: >idbloader.img
Just to be sure that I understood you correctly: Both of these images have to be flashed to boot0 and boot1 does not fulfill any function when using u-boot, correct?
NO, definitely not for idbloader,, STARTS at sector 64
Its really hard to tell where boot0 and boot1 are located,
don't show up in fdisk or cfdisk or gparted
So, you tell me
uboot STARTS at sector 16384, do the calculations, that is 8M
I think the location for idbloader is baked into chip,
where uboot is located is a config in idbloader,
in other arm devices uboot is in a different location
Oh, and BTW, I am still on the uboot from MJ19.12,
since everything works well, especially sleep
IOW, there is no problem needing fixing, why risk mucking it up
  Boot Order in Pinebook Pro food 12 19,114 05-25-2026, 08:28 AM
Last Post: finmark
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,651 08-21-2024, 04:17 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,591 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,443 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 20,265 06-02-2023, 01:32 PM
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 4,361 03-24-2023, 04:25 PM
Last Post: srs5694
  Tow Boot install help Paulie420 7 11,407 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,070 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 3,312 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 11,500 08-18-2022, 11:47 AM
Last Post: Bemo
