How do you prevent the battery from discharging when the phone is off?
1) How and when it charges kind of depends on the Operating System software, so no set rules there.
2) Watch the screen carefully when you shut it off, sometimes you can see if it powers down completely.
The screen will go completely black pretty quick.. If it just sort of fades away, you may need to hold the power button for it to completely power-down.
Remember the old Windows 98 and XP computers ? Some would actually turn off when you turned it off, but some
would go to a screen saying "It is Safe to Turn Off your Computer Now" ? Then you had to manually push the button to turn it off.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
a little offtopic.
I read that the piephone has an rtc, I remember the old phones that could turn on to work the alarm clock.
With android this seems to be no longer possible (maybe something to do with the rtc?) but once I happened a phone (very cheap, I don't remember if it was a mediatek) that could do it.
Maybe in the future it could be possible with the pinephone, planning phone turning off and on..
I'm not sure about the circutry in the Pinephone, - but it appears to need to be  'powered on'  to be able to charge the battery..?
So perhaps it could be the OS is needed to control the charging ?
Perhaps future models could have an independent charge control circut ahead of the main computer board ?
*(an independent circut could also have a clock function in it.)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(03-19-2020, 04:11 AM)bcnaz Wrote: but it appears to need to be  'powered on'  to be able to charge the battery..?
woot? so to be able to charge my phone, it needs to be powered on?! so i never should let it go off with a "empty" battery?
Then the phone would be broken by design. I can't imagine it is that way.
>  "Appears to be"  is only   'my impression'
  Besides,  you Did Read the warning disclosures posted everywhere before 'Buying this Phone'   ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(03-19-2020, 03:44 PM)bcnaz Wrote:   Besides,  you Did Read the warning disclosures posted everywhere before 'Buying this Phone'   ?
yes and i am wondering if you understood what i wrote and meant with:
"Then the phone would be broken by design. I can't imagine it is that way."
(03-11-2020, 10:15 AM)supermagic Wrote: Seems like the battery discharges when the phone is off.
How do you prevent this?
I'm using terminal command 'sudo shutdown now'
  Battery connector dead mdk 5 4,489 01-15-2026, 02:24 PM
Last Post: mikeb
  My Phone stopped making and recieving Calls tracyanne 0 10,945 09-14-2025, 03:30 PM
Last Post: tracyanne
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 3,393 09-20-2024, 04:04 AM
  Phone powers off with high user demands car46999 7 9,187 04-11-2024, 09:17 AM
Last Post: zetabeta
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,028 02-17-2024, 04:15 PM
Last Post: vortex
  Phone will not turn on (but sometimes will) insidetrip101 10 13,820 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 3,605 07-31-2023, 07:50 PM
  Battery life improvement freelectro 10 11,573 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,224 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 3,602 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
