CrOS debugging request
Hi all
I have been working on a CrOS79 image with the mainline kernel. I have built an image, and it can be found here: https://drive.google.com/open?id=1-72xu8...s7ka5HoLd9
However, the image doesn't boot and does not give any output to the screen. Is there anyone out there with a debugging console cable that can help me out here? Smile I'm stumbling in the dark right now
Help appreciated!
Posted the link in the IRC, also: BUMP.
Edit: just in case, I've found and added a 3.3v UART cable to my Amazon cart, so if no one joins in, I'll try my hand at debugging the boot.
Had to wait a little bit to get a UART cable for myself, but it arrived, and I've got the output from trying to boot up this image:
DDR Version 1.20 20190314 In channel 0 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 400MHz 0,1 channel 0 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x81 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 Channel 0: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 250 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=119276MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30528MB FwPartOffset=2000 , 0 StorageInit ok = 245691 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT part: 0, name: STATE, start:0x44e000, size:0x40006d GPT part: 1, name: KERN-A, start:0x5000, size:0x8000 GPT part: 2, name: ROOT-A, start:0x4e000, size:0x400000 GPT part: 3, name: KERN-B, start:0xd000, size:0x8000 GPT part: 4, name: ROOT-B, start:0x4d000, size:0x1000 GPT part: 5, name: KERN-C, start:0x4040, size:0x1 GPT part: 6, name: ROOT-C, start:0x4041, size:0x1 GPT part: 7, name: OEM, start:0x15000, size:0x8000 GPT part: 8, name: reserved, start:0x4042, size:0x1 GPT part: 9, name: reserved, start:0x4043, size:0x1 GPT part: 10, name: RWFW, start:0x40, size:0x4000 GPT part: 11, name: EFI-SYSTEM, start:0x3d000, size:0x10000 no find partition:uboot. LoadTrust Addr:0x4000 No find bl30.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe65c0 RunBL31 0x40000 NOTICE: BL31: v1.3(release):57824cc NOTICE: BL31: Built : 10:59:12, Jan 6 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #191 Mon Nov 18 07:00:24 UTC 2019 aarch64) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 fdtdec_get_addr_size_fixed: reg: addr=ff770000, size=10000 fdtdec_get_addr_size_fixed: reg: addr=ff320000, size=1000 U-Boot 2017.09 (Feb 16 2020 - 17:42:34 +0100) Model: Pine64 RK3399 Pinebook Pro PreSerial: 2 DRAM: 3.8 GiB Sysmem: init Relocation Offset: f5be6000, fdt: f3dd1238 I2c0 speed: 400000Hz PMIC: RK808 vdd_center 900000 uV vdd_log init 900000 uV rk_board_init PWM2 pinctrl init fail! rk_board_init: vcc3v0_sdio cannot set regulator value -38 vdd_center 900000 uV DCDC_REG1@ vdd_center: 750000uV <-> 1400000uV, set 900000uV, enabling | suspend -61uV, disabled DCDC_REG4@ vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling LDO_REG1@ vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling LDO_REG4@ vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling LDO_REG5@ vcca3v0_codec: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling LDO_REG7@ vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling LDO_REG8@ vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling SWITCH_REG2@ vcc3v3_s0: -61uV <-> -61uV, set 0uV, enabling | suspend -61uV, disabled dc-12v@ dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend -61uV, enabling (ret: -38) vcc-sys@ vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend -61uV, enabling (ret: -38) vcc3v3-sys@ vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend -61uV, enabling (ret: -38) vcc-phy-regulator@ vcc_phy: -61uV <-> -61uV, set -61uV, enabling | suspend -61uV, enabling led-regulator@ led_regulator: -61uV <-> -61uV, set -61uV, enabling | suspend -61uV, enabling vcc5v0-host-en@ vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend -61uV, enabling (ret: -38) vcc5v0-usb3-host-regulator@vcc5v0_usb3_host: -61uV <-> -61uV, set -61uV, enabling | suspend -61uV, enabling vcc5v0-typec0-en@ vcc5v0_typec0: -61uV <-> -61uV, set -61uV, enabling | suspend -61uV, enabling vcc3v3-pcie-regulator@ vcc3v3_pcie: 3300000uV <-> 3300000uV, set 3300000uV, disabled | suspend -61uV, enabling vcc1v8-sdio@ vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend -61uV, enabling (ret: -38) vcc3v0-sdio@ vcc3v0_sdio: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend -61uV, enabling ; init 3000000uV (ret: -38) vdd_log init 900000 uV vdd_log@ vdd_log: 800000uV <-> 1400000uV, set 900000uV, enabling | suspend -61uV, enabling ; init 900000uV MMC: dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1 Invalid bus 0 (err=-19) *** Warning - spi_flash_probe_bus_cs() failed, using default environment In: serial Out: serial Err: serial Model: Pine64 RK3399 Pinebook Pro switch to partitions #0, OK mmc1 is current device Found IDB in SDcard Bootdev(atags): mmc 1 PartType: EFI rockchip_get_boot_mode: Could not found misc partition boot mode: None init_resource_list: failed to get resource part, ret=-1 Can't find file:logo.bmp failed to display uboot logo CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A) aplll 816000 KHz apllb 816000 KHz dpll 800000 KHz cpll 24000 KHz gpll 800000 KHz npll 600000 KHz vpll 24000 KHz aclk_perihp 133333 KHz hclk_perihp 66666 KHz pclk_perihp 33333 KHz aclk_perilp0 266666 KHz hclk_perilp0 88888 KHz pclk_perilp0 44444 KHz hclk_perilp1 100000 KHz pclk_perilp1 50000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 do_boot_rockchip: Could not find EFI-SYSTEM part Checking for mmc dev 1... switch to partitions #0, OK mmc1 is current device Scanning mmc 1 for bootable partitions... Scanning mmc 1:c for extlinux or boot scripts... Found U-Boot script /boot.scr reading /boot.scr 1117 bytes read in 2 ms (544.9 KiB/s) ## Executing script at 00500000 Setting bus to 4 I2c4 speed: 100000Hz Valid chip addresses: 62 Detected i2c4@62 charger circuit. It seems to be Pinebook Pro. FDT: rockchip/rk3399-pinebook-pro.dtb Bootdevice: mmcblk0 Retrieving file: /boot/extlinux/extlinux.conf 2087 bytes read in 22 ms (91.8 KiB/s) Boot Menu 1: dev-5.5.0-rockchip-dev 2: rockchip-5.5.0-MANJARO-ARM+-debug 3: rockchip-5.5.0-MANJARO-ARM+ Enter choice: 1: dev-5.5.0-rockchip-dev Retrieving file: /boot/vmlinuz-5.5.0-rockchip-dev ** File not found /boot/vmlinuz-5.5.0-rockchip-dev ** Skipping dev-5.5.0-rockchip-dev for failure retrieving kernel 2: rockchip-5.5.0-MANJARO-ARM+-debug Retrieving file: /boot/vmlinuz-5.5.0-MANJARO-ARM+ 21699072 bytes read in 936 ms (22.1 MiB/s) append: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk0p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=0 dm="1 vroot none ro 1,0 2539520 verity payload=/dev/mmcblk0p3 hashtree=HASH_DEV hashstart=2539520 alg=sha1 root_hexdigest=a1910fbe4a24a30d19a49b85d2889776251e54e3 salt=c520b38f1057e5bef0aa64c00cd0d2e50662e22bf19771278921f90a35fd616d" vt.global_cursor_default=0 ethaddr=b6:02:ba:f2:9c:f8 serial=d25c0363e6a5f5f Retrieving file: /boot/dtbs/5.5.0-MANJARO-ARM+/rockchip/rk3399-pinebook-pro.dtb 62426 bytes read in 66 ms (922.9 KiB/s) ## Flattened Device Tree blob at 08300000 Booting using the fdt blob at 0x8300000 fdtdec_get_addr_size_fixed: reg: addr=00000000, size=0 Loading Device Tree to 00000000f3dbb000, end 00000000f3dcd3d9 ... OK Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000) Total: 4208.872 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.5.0-MANJARO-ARM+ (brent@brent-pc) (gcc version 4.9.x 20150123 (prerelease) (4.9.2_cos_gg_4.9.2-r223-ac6128e0a17a52f011797f33ac3e7d6273a9368d_4.9.2-r223)) #3 SMP Mon Feb 17 00:45:01 CET 2020 [ 0.000000] Machine model: Pine64 Pinebook Pro [ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '') [ 0.000000] printk: bootconsole [uart8250] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] cma: Reserved 64 MiB at 0x00000000f4000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 34 pages/cpu s101400 r8192 d29672 u139264 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 991752 [ 0.000000] Kernel command line: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk0p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=0 dm="1 vroot none ro 1,0 2539520 verity payload=/dev/mmcblk0p3 hashtree=HASH_DEV hashstart=2539520 alg=sha1 root_hexdigest=a1910fbe4a24a30d19a49b85d2889776251e54e3 salt=c520b38f1057e5bef0aa64c00cd0d2e50662e22bf19771278921f90a35fd616d" vt.global_cursor_default=0 ethaddr=b6:02:ba:f2:9c:f8 serial=d25c0363e6a5f5f earlycon=uart8250,mmio32,0xff1a0000 mem_sleep_default=s2idle [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB) [ 0.000000] Memory: 3788516K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176412K reserved, 65536K cma-reserved) [ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x78/0x130 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support, no RVPEID support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @eec80000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000000eec40000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eec50000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001984] Console: colour dummy device 80x25 [ 0.002429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.003373] pid_max: default: 32768 minimum: 301 [ 0.003948] LSM: Security Framework initializing [ 0.004383] Yama: becoming mindful. [ 0.004779] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.005471] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.006236] *** VALIDATE tmpfs *** [ 0.007037] *** VALIDATE proc *** [ 0.007587] *** VALIDATE cgroup1 *** [ 0.007919] *** VALIDATE cgroup2 *** [ 0.009197] ASID allocator initialised with 65536 entries [ 0.009770] rcu: Hierarchical SRCU implementation. [ 0.010455] Platform MSI: interrupt-controller@fee20000 domain created [ 0.011442] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.012885] EFI services will not be available. [ 0.013716] smp: Bringing up secondary CPUs ... [ 0.014607] Detected VIPT I-cache on CPU1 [ 0.014641] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.014654] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000 [ 0.014698] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.015259] Detected VIPT I-cache on CPU2 [ 0.015283] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.015293] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000 [ 0.015318] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.015815] Detected VIPT I-cache on CPU3 [ 0.015836] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.015847] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000 [ 0.015869] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.016366] CPU features: detected: EL2 vector hardening [ 0.016374] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware [ 0.016378] CPU features: detected: ARM erratum 1319367 [ 0.016382] Detected PIPT I-cache on CPU4 [ 0.016407] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.016418] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000 [ 0.016445] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.016973] Detected PIPT I-cache on CPU5 [ 0.016993] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.017003] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000 [ 0.017024] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [ 0.017108] smp: Brought up 1 node, 6 CPUs [ 0.030197] SMP: Total of 6 processors activated. [ 0.030629] CPU features: detected: 32-bit EL0 Support [ 0.031100] CPU features: detected: CRC32 instructions [ 0.058685] CPU: All CPU(s) started at EL2 [ 0.059140] alternatives: patching kernel code [ 0.061991] devtmpfs: initialized [ 0.071051] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.071958] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.075197] pinctrl core: initialized pinctrl subsystem [ 0.076604] thermal_sys: Registered thermal governor 'fair_share' [ 0.076607] thermal_sys: Registered thermal governor 'bang_bang' [ 0.077196] thermal_sys: Registered thermal governor 'step_wise' [ 0.077773] thermal_sys: Registered thermal governor 'user_space' [ 0.078753] DMI not present or invalid. [ 0.080063] NET: Registered protocol family 16 [ 0.082200] DMA: preallocated 256 KiB pool for atomic allocations [ 0.083744] cpuidle: using governor ladder [ 0.084162] cpuidle: using governor menu [ 0.084949] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.085817] Serial: AMBA PL011 UART driver [ 0.112460] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.113109] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.113753] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.114397] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.126360] cryptd: max_cpu_qlen set to 1000 [ 0.152926] ACPI: Interpreter disabled. [ 0.153708] vcc_12v: supplied by vcc_sysin [ 0.154292] vcc3v3_sys: supplied by vcc_sysin [ 0.155012] vcc5v0_usb: supplied by vcc_sysin [ 0.155631] vcc_0v9: supplied by vcc3v3_sys [ 0.156211] vcca1v8_s3: supplied by vcc3v3_sys [ 0.156873] vcc3v0_sd: supplied by vcc3v3_sys [ 0.157584] vcc3v3_panel: supplied by vcc3v3_sys [ 0.277516] vcc3v3_ssd: supplied by vcc3v3_sys [ 0.278202] vcc5v0_otg: supplied by vcc5v0_usb [ 0.278891] vbus_5vout: supplied by vcc5v0_usb [ 0.279820] iommu: Default domain type: Translated [ 0.282311] vgaarb: loaded [ 0.283147] SCSI subsystem initialized [ 0.283790] usbcore: registered new interface driver usbfs [ 0.284340] usbcore: registered new interface driver hub [ 0.284908] usbcore: registered new device driver usb [ 0.285762] mc: Linux media interface: v0.10 [ 0.286188] videodev: Linux video capture interface: v2.00 [ 0.286735] pps_core: LinuxPPS API ver. 1 registered [ 0.287211] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.288107] PTP clock support registered [ 0.288652] EDAC MC: Ver: 3.0.0 [ 0.289469] Advanced Linux Sound Architecture Driver Initialized. [ 0.290391] NetLabel: Initializing [ 0.290719] NetLabel: domain hash size = 128 [ 0.291137] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.291714] NetLabel: unlabeled traffic allowed by default [ 0.292709] clocksource: Switched to clocksource arch_sys_counter [ 0.293299] *** VALIDATE bpf *** [ 0.293760] VFS: Disk quotas dquot_6.6.0 [ 0.294182] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.294891] *** VALIDATE ramfs *** [ 0.295229] *** VALIDATE hugetlbfs *** [ 0.295858] pnp: PnP ACPI: disabled [ 0.300942] NET: Registered protocol family 2 [ 0.301824] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.302697] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.303736] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.304921] TCP: Hash tables configured (established 32768 bind 32768) [ 0.305649] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.306387] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.307297] NET: Registered protocol family 1 [ 0.308240] RPC: Registered named UNIX socket transport module. [ 0.308786] RPC: Registered udp transport module. [ 0.309214] RPC: Registered tcp transport module. [ 0.309644] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.310236] PCI: CLS 0 bytes, default 64 [ 0.311986] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.313074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.314246] kvm [1]: IPA Size Limit: 40bits [ 0.315967] kvm [1]: vgic-v2@fff20000 [ 0.316338] kvm [1]: GIC system register CPU interface enabled [ 0.317045] kvm [1]: vgic interrupt IRQ10 [ 0.317603] kvm [1]: Hyp mode initialized successfully [ 0.367298] Initialise system trusted keyrings [ 0.367848] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.371457] zbud: loaded [ 0.373043] NFS: Registering the id_resolver key type [ 0.373541] Key type id_resolver registered [ 0.373944] Key type id_legacy registered [ 0.374336] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.375000] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.375633] fuse: init (API version 7.31) [ 0.376064] *** VALIDATE fuse *** [ 0.376387] *** VALIDATE fuse *** [ 0.376899] SGI XFS with ACLs, security attributes, quota, no debug enabled [ 0.378506] *** VALIDATE xfs *** [ 0.396297] NET: Registered protocol family 38 [ 0.396731] Key type asymmetric registered [ 0.397127] Asymmetric key parser 'x509' registered [ 0.397619] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 0.398445] io scheduler mq-deadline registered [ 0.398882] io scheduler kyber registered [ 0.399343] io scheduler bfq registered [ 0.406662] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 0.407336] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie1v8 not found, using dummy regulator [ 0.408279] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie0v9 not found, using dummy regulator [ 0.982759] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.983681] rockchip-pcie: probe of f8000000.pcie failed with error -110 [ 0.985190] IPMI message handler: version 39.2 [ 0.987106] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [ 0.988872] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.989567] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 0.990621] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [ 0.992833] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.993527] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.996046] pwm-regulator: supplied by regulator-dummy [ 0.997367] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.999705] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A [ 1.000654] serial serial0: tty port ttyS0 registered [ 1.001576] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A [ 1.002580] printk: console [ttyS2] enabled [ 1.002580] printk: console [ttyS2] enabled [ 1.003360] printk: bootconsole [uart8250] disabled [ 1.003360] printk: bootconsole [uart8250] disabled [ 1.006249] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.010285] spi-nor spi0.0: gd25q128 (16384 Kbytes) [ 1.012524] libphy: Fixed MDIO Bus: probed [ 1.013015] usbcore: registered new interface driver asix [ 1.021919] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.022501] ehci-pci: EHCI PCI platform driver [ 1.022959] ehci-platform: EHCI generic platform driver [ 1.025641] ehci-platform fe380000.usb: EHCI Host Controller [ 1.026313] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [ 1.027103] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000 [ 1.052735] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 1.053434] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [ 1.054161] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.054795] usb usb1: Product: EHCI Host Controller [ 1.055226] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [ 1.055792] usb usb1: SerialNumber: fe380000.usb [ 1.056658] hub 1-0:1.0: USB hub found [ 1.057017] hub 1-0:1.0: 1 port detected [ 1.059854] ehci-platform fe3c0000.usb: EHCI Host Controller [ 1.060484] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2 [ 1.061266] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000 [ 1.082736] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.083415] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [ 1.084141] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.084774] usb usb2: Product: EHCI Host Controller [ 1.085205] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [ 1.085770] usb usb2: SerialNumber: fe3c0000.usb [ 1.086558] hub 2-0:1.0: USB hub found [ 1.086917] hub 2-0:1.0: 1 port detected [ 1.087870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.088428] ohci-pci: OHCI PCI platform driver [ 1.088889] ohci-platform: OHCI generic platform driver [ 1.089545] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 1.090266] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3 [ 1.091045] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000 [ 1.156930] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [ 1.157657] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.158290] usb usb3: Product: Generic Platform OHCI controller [ 1.158811] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [ 1.159376] usb usb3: SerialNumber: fe3a0000.usb [ 1.160186] hub 3-0:1.0: USB hub found [ 1.160543] hub 3-0:1.0: 1 port detected [ 1.161327] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 1.162044] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4 [ 1.162921] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000 [ 1.236958] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [ 1.237685] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.238319] usb usb4: Product: Generic Platform OHCI controller [ 1.238840] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [ 1.239405] usb usb4: SerialNumber: fe3e0000.usb [ 1.240203] hub 4-0:1.0: USB hub found [ 1.240560] hub 4-0:1.0: 1 port detected [ 1.241486] uhci_hcd: USB Universal Host Controller Interface driver [ 1.242928] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.243564] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [ 1.244366] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 1.245230] xhci-hcd xhci-hcd.0.auto: irq 226, io mem 0xfe900000 [ 1.246050] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [ 1.246776] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.247410] usb usb5: Product: xHCI Host Controller [ 1.247840] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [ 1.248405] usb usb5: SerialNumber: xhci-hcd.0.auto [ 1.249239] hub 5-0:1.0: USB hub found [ 1.249598] hub 5-0:1.0: 1 port detected [ 1.250258] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.250861] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [ 1.251543] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.252169] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.252991] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [ 1.253718] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.254351] usb usb6: Product: xHCI Host Controller [ 1.254782] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [ 1.255347] usb usb6: SerialNumber: xhci-hcd.0.auto [ 1.256159] hub 6-0:1.0: USB hub found [ 1.256515] hub 6-0:1.0: 1 port detected [ 1.257276] usbcore: registered new interface driver uas [ 1.257856] usbcore: registered new interface driver usb-storage [ 1.258413] usbcore: registered new interface driver ums-alauda [ 1.258964] usbcore: registered new interface driver ums-cypress [ 1.259521] usbcore: registered new interface driver ums-datafab [ 1.260075] usbcore: registered new interface driver ums_eneub6250 [ 1.260646] usbcore: registered new interface driver ums-freecom [ 1.261201] usbcore: registered new interface driver ums-isd200 [ 1.261748] usbcore: registered new interface driver ums-jumpshot [ 1.262313] usbcore: registered new interface driver ums-karma [ 1.262986] usbcore: registered new interface driver ums-onetouch [ 1.263563] usbcore: registered new interface driver ums-realtek [ 1.264120] usbcore: registered new interface driver ums-sddr09 [ 1.264668] usbcore: registered new interface driver ums-sddr55 [ 1.265217] usbcore: registered new interface driver ums-usbat [ 1.265814] usbcore: registered new interface driver usbserial_generic [ 1.266404] usbserial: USB Serial support registered for generic [ 1.269245] mousedev: PS/2 mouse device common for all mice [ 1.272609] rk808 0-001b: chip id: 0x0 [ 1.276970] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 1.277538] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 1.278143] DCDC_REG1: supplied by vcc_sysin [ 1.279384] DCDC_REG2: supplied by vcc_sysin [ 1.280305] DCDC_REG3: supplied by vcc_sysin [ 1.280867] DCDC_REG4: supplied by vcc_sysin [ 1.281697] LDO_REG1: supplied by vcc_sysin [ 1.283287] LDO_REG2: supplied by vcc_sysin [ 1.283824] vcc3v0_touch: Bringing 1800000uV into 3000000-3000000uV [ 1.285372] LDO_REG3: supplied by vcc_sysin [ 1.286826] LDO_REG4: supplied by vcc_sysin [ 1.287377] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV [ 1.288935] LDO_REG5: supplied by vcc_sysin [ 1.290260] LDO_REG6: supplied by vcc_sysin [ 1.291711] LDO_REG7: supplied by vcc_sysin [ 1.293084] LDO_REG8: supplied by vcc_sysin [ 1.294534] SWITCH_REG1: supplied by vcc3v3_sys [ 1.295230] SWITCH_REG2: supplied by vcc3v3_sys [ 1.298950] rk808-rtc rk808-rtc: registered as rtc0 [ 1.300025] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.300651] fan53555-reg: supplied by vcc_1v8 [ 1.301428] random: fast init done [ 1.303177] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 1.303802] fan53555-reg: supplied by vcc_1v8 [ 1.306530] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22 [ 1.321382] device-mapper: uevent: version 1.0.3 [ 1.322091] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com [ 1.326884] sdhci: Secure Digital Host Controller Interface driver [ 1.327432] sdhci: Copyright(c) Pierre Ossman [ 1.328323] Synopsys Designware Multimedia Card Interface Driver [ 1.329663] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 1.330309] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.330907] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.331444] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo [ 1.332385] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ 1.332933] mmc_host mmc0: card is non-removable. [ 1.463051] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 1.463528] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.477984] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 1.478646] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 1.479245] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 1.479792] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo [ 1.480808] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO [ 1.481401] vcc_sdio: unsupportable voltage range: 3300000-3000000uV [ 1.494920] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.509942] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.512474] mmc2: CQHCI version 5.10 [ 1.512793] mmc0: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.515182] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.515806] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36 [ 1.516526] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.517151] usb 2-1: Product: USB2.0 Hub [ 1.517317] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.518351] hub 2-1:1.0: USB hub found [ 1.519123] hub 2-1:1.0: 4 ports detected [ 1.520855] mmc0: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.524853] mmc0: queuing unknown CIS tuple 0x81 (9 bytes) [ 1.538954] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 1.542908] ledtrig-cpu: registered to indicate activity on CPUs [ 1.544099] hid: raw HID events driver (C) Jiri Kosina [ 1.544776] usbcore: registered new interface driver usbhid [ 1.545266] usbhid: USB HID core driver [ 1.548623] Initializing XFRM netlink socket [ 1.549347] NET: Registered protocol family 10 [ 1.553688] Segment Routing with IPv6 [ 1.554100] mip6: Mobile IPv6 [ 1.554368] NET: Registered protocol family 17 [ 1.555105] Key type dns_resolver registered [ 1.556143] registered taskstats version 1 [ 1.556508] Loading compiled-in X.509 certificates [ 1.557036] zswap: loaded using pool lzo/zbud [ 1.557532] Key type ._fscrypt registered [ 1.557884] Key type .fscrypt registered [ 1.558239] Key type fscrypt-provisioning registered [ 1.558755] Key type big_key registered [ 1.560478] Key type encrypted registered [ 1.563470] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 1.580189] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 1.582598] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 1.583278] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 7 [ 1.584044] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 1.584900] xhci-hcd xhci-hcd.2.auto: irq 225, io mem 0xfe800000 [ 1.585588] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [ 1.586309] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.586939] usb usb7: Product: xHCI Host Controller [ 1.587365] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [ 1.587925] usb usb7: SerialNumber: xhci-hcd.2.auto [ 1.588679] hub 7-0:1.0: USB hub found [ 1.589017] hub 7-0:1.0: 1 port detected [ 1.589473] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 1.590008] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 8 [ 1.590677] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 1.591263] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.591998] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [ 1.592725] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.593353] usb usb8: Product: xHCI Host Controller [ 1.593778] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [ 1.594339] usb usb8: SerialNumber: xhci-hcd.2.auto [ 1.594916] hub 8-0:1.0: USB hub found [ 1.595252] hub 8-0:1.0: 1 port detected [ 1.597638] rk808-rtc rk808-rtc: setting system clock to 2020-03-09T13:16:06 UTC (1583759766) [ 1.599127] ALSA device list: [ 1.599395] No soundcards found. [ 1.599905] ttyS2 - failed to request DMA [ 1.600344] md: Waiting for all devices to be available before autodetect [ 1.600937] md: If you don't use raid, use raid=noautodetect [ 1.602105] md: Autodetecting RAID arrays. [ 1.602471] md: autorun ... [ 1.602738] md: ... autorun DONE. [ 1.603080] Waiting for root device /dev/mmcblk0p3... [ 1.623917] mmc2: Command Queue Engine enabled [ 1.624330] mmc2: new HS200 MMC card at address 0001 [ 1.625609] mmcblk2: mmc2:0001 DA4128 116 GiB [ 1.626146] mmcblk2boot0: mmc2:0001 DA4128 partition 1 4.00 MiB [ 1.626797] mmcblk2boot1: mmc2:0001 DA4128 partition 2 4.00 MiB [ 1.627495] mmcblk2rpmb: mmc2:0001 DA4128 partition 3 16.0 MiB, chardev (238:0) [ 1.630901] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 [ 1.793159] usb 3-1: new low-speed USB device number 2 using ohci-platform [ 1.843034] usb 2-1.2: new high-speed USB device number 3 using ehci-platform [ 1.954454] usb 2-1.2: New USB device found, idVendor=0c45, idProduct=6321, bcdDevice= 0.00 [ 1.955212] usb 2-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0 [ 1.955861] usb 2-1.2: Product: USB Camera [ 1.956233] usb 2-1.2: Manufacturer: Sonix Technology Co., Ltd. [ 2.069098] usb 3-1: New USB device found, idVendor=258a, idProduct=001e, bcdDevice= 1.00 [ 2.069854] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.070490] usb 3-1: Product: USB KEYBOARD [ 2.070862] usb 3-1: Manufacturer: HAILUCK CO.,LTD [ 2.080761] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:258A:001E.0001/input/input0 [ 2.127716] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 73 [ 2.128367] mmc1: new ultra high speed SDR104 SDHC card at address 0001 [ 2.130295] mmcblk1: mmc1:0001 GB1QT 29.8 GiB [ 2.136782] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 2.137443] GPT:8708252 != 62521343 [ 2.137752] GPT:Alternate GPT header not at the end of the disk. [ 2.138279] GPT:8708252 != 62521343 [ 2.138587] GPT: Use GNU Parted to correct GPT errors. [ 2.139114] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 [ 2.143323] hid-generic 0003:258A:001E.0001: input,hidraw0: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input0 [ 2.168800] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input1 [ 2.170662] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input2 [ 2.172317] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input3 [ 2.243814] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input4 [ 2.245586] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input5 [ 2.247954] hid-generic 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1 [ 2.433910] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 47 [ 2.437087] mmc0: new ultra high speed SDR104 SDIO card at address 0001 [ 31.833067] vcc3v3_ssd: disabling [ 31.833389] vbus_5vout: disabling [ 99.573796] random: crng init done
EDIT: in case anyone's looking for their own UART cable, this. is the one I used: https://www.amazon.com/dp/B00XSPECIA?ref...b_ap_share
So this seems to be a partitioning error?
I'll see if I have the time to look into this.
Hi Brent,
I would be happy to debug your image on a Rock Pi 4! (RK3399 like the Pinebook Pro)
Could you please compress the image (tar.xz or 7z) and upload? Where I live there is 1.5 Gb data cap per day.
Thanks.
(03-11-2020, 01:25 AM)aaditya Wrote: Hi Brent,
Thanks.
I know Brent's pretty busy lately, so I'm tarring my local copy of the .bin right now, and will update the post with a download link as soon as its uploaded.
Link: https://mega.nz/#!eg80CQKC!lkFKcymh92BaZ...98aE02Ml5Q
(03-11-2020, 07:18 AM)tophneal Wrote: I know Brent's pretty busy lately, so I'm tarring my local copy of the .bin right now, and will update the post with a download link as soon as its uploaded.
Thanks @tophneal!
Here is the output from serial console running off a Rock Pi 4:
DDR Version 1.20 20190314 In channel 0 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 400MHz 0,1 channel 0 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 Channel 0: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 250 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=29600MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 68548 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT part:  0, name:            STATE, start:0x44e000, size:0x40006d GPT part:  1, name:           KERN-A, start:0x5000, size:0x8000 GPT part:  2, name:           ROOT-A, start:0x4e000, size:0x400000 GPT part:  3, name:           KERN-B, start:0xd000, size:0x8000 GPT part:  4, name:           ROOT-B, start:0x4d000, size:0x1000 GPT part:  5, name:           KERN-C, start:0x4040, size:0x1 GPT part:  6, name:           ROOT-C, start:0x4041, size:0x1 GPT part:  7, name:              OEM, start:0x15000, size:0x8000 GPT part:  8, name:         reserved, start:0x4042, size:0x1 GPT part:  9, name:         reserved, start:0x4043, size:0x1 GPT part: 10, name:             RWFW, start:0x40, size:0x4000 GPT part: 11, name:       EFI-SYSTEM, start:0x3d000, size:0x10000 no find partition:uboot. LoadTrust Addr:0x4000 No find bl30.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe65c0 RunBL31 0x40000 NOTICE:  BL31: v1.3(release):57824cc NOTICE:  BL31: Built : 10:59:12, Jan  6 2020 NOTICE:  BL31: Rockchip release version: v1.1 INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    If lpddr4 need support multi frequency, INFO:    please update loader! INFO:    Current ctl index[0] freq=400MHz INFO:    Current ctl index[1] freq=800MHz INFO:    plat_rockchip_pmu_init(1190): pd status 3e INFO:    BL31: Initializing runtime services INFO:    BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #191 Mon Nov 18 07:00:24 UTC 2019 aarch64) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 fdtdec_get_addr_size_fixed: reg: addr=ff770000, size=10000 fdtdec_get_addr_size_fixed: reg: addr=ff320000, size=1000 U-Boot 2017.09 (Feb 16 2020 - 17:42:34 +0100) Model: Pine64 RK3399 Pinebook Pro PreSerial: 2 DRAM:  3.8 GiB Sysmem: init Relocation Offset: f5be6000, fdt: f3dd1238 I2c0 speed: 400000Hz PMIC:  RK808 vdd_center 900000 uV vdd_log init 900000 uV rk_board_init PWM2 pinctrl init fail! rk_board_init: vcc3v0_sdio cannot set regulator value -38 vdd_center 900000 uV                DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled                DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling                 LDO_REG5@  vcca3v0_codec: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling                 LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling                 LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling              SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled                   dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)                  vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)               vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)        vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling            led-regulator@  led_regulator:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling           vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38) vcc5v0-usb3-host-regulator@vcc5v0_usb3_host:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling         vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling    vcc3v3-pcie-regulator@    vcc3v3_pcie: 3300000uV <-> 3300000uV, set 3300000uV, disabled | suspend     -61uV, enabling              vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)              vcc3v0-sdio@    vcc3v0_sdio: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend     -61uV, enabling ; init 3000000uV (ret: -38) vdd_log init 900000 uV                  vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1 Invalid bus 0 (err=-19) *** Warning - spi_flash_probe_bus_cs() failed, using default environment In:    serial Out:   serial Err:   serial Model: Pine64 RK3399 Pinebook Pro Bootdev(atags): mmc 0 PartType: EFI rockchip_get_boot_mode: Could not found misc partition boot mode: None init_resource_list: failed to get resource part, ret=-1 Can't find file:logo.bmp failed to display uboot logo CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)  aplll 816000 KHz  apllb 816000 KHz  dpll 800000 KHz  cpll 24000 KHz  gpll 800000 KHz  npll 600000 KHz  vpll 24000 KHz  aclk_perihp 133333 KHz  hclk_perihp 66666 KHz  pclk_perihp 33333 KHz  aclk_perilp0 266666 KHz  hclk_perilp0 88888 KHz  pclk_perilp0 44444 KHz  hclk_perilp1 100000 KHz  pclk_perilp1 50000 KHz Net:   No ethernet found. Hit key to stop autoboot('CTRL+C'):  0 do_boot_rockchip: Could not find EFI-SYSTEM part Checking for mmc dev 1... Card did not respond to voltage select! mmc_init: -95, time 9 Checking for nvme dev 0... Device 0: unknown device starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3a0000: USB OHCI 1.0 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe3e0000: USB OHCI 1.0 Bus usb@fe800000: device name usb@fe800000 Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: device name usb@fe900000 Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... ERROR: Invalid USB EP length (9) ERROR: Invalid USB EP length (9) 4 USB Device(s) found scanning bus usb@fe3a0000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe3e0000 for devices... ERROR:  USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) unable to get device descriptor (error=-1) 1 USB Device(s) found scanning bus usb@fe800000 for devices... 1 USB Device(s) found scanning bus usb@fe900000 for devices... 4 USB Device(s) found       scanning usb for storage devices... 0 Storage Device(s) found Checking for usb dev 0... Device 0: unknown device Checking for mmc dev 0... switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0 for bootable partitions... Scanning mmc 0:c for extlinux or boot scripts... Found U-Boot script /boot.scr reading /boot.scr 1117 bytes read in 11 ms (98.6 KiB/s) ## Executing script at 00500000 Setting bus to 4 I2c4 speed: 100000Hz Valid chip addresses: Did not detect i2c4@62 charger circuit. It seems to be RockPro64. FDT: rockchip/rk3399-rockpro64.dtb Bootdevice: mmcblk1 Retrieving file: /boot/extlinux/extlinux.conf 2087 bytes read in 106 ms (18.6 KiB/s) Boot Menu 1:      dev-5.5.0-rockchip-dev 2:      rockchip-5.5.0-MANJARO-ARM+-debug 3:      rockchip-5.5.0-MANJARO-ARM+ Enter choice: 1:        dev-5.5.0-rockchip-dev Retrieving file: /boot/vmlinuz-5.5.0-rockchip-dev ** File not found /boot/vmlinuz-5.5.0-rockchip-dev ** Skipping dev-5.5.0-rockchip-dev for failure retrieving kernel 2:      rockchip-5.5.0-MANJARO-ARM+-debug Retrieving file: /boot/vmlinuz-5.5.0-MANJARO-ARM+ 21699072 bytes read in 1061 ms (19.5 MiB/s) append: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_verity.error_behavior=3 dm_verd Retrieving file: /boot/dtbs/5.5.0-MANJARO-ARM+/rockchip/rk3399-rockpro64.dtb 55062 bytes read in 156 ms (343.8 KiB/s) ## Flattened Device Tree blob at 08300000   Booting using the fdt blob at 0x8300000   Loading Device Tree to 00000000f3dbc000, end 00000000f3dcc715 ... OK Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000) Total: 13589.367 ms Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [    0.000000] Linux version 5.5.0-MANJARO-ARM+ (brent@brent-pc) (gcc version 4.9.x 20150123 (prerelease) (4.9.2_cos_gg_4.9.2-r223-ac6128e0a17a52f011797f33ac3e7d620 [    0.000000] Machine model: Pine64 RockPro64 [    0.000000] efi: Getting EFI parameters from FDT: [    0.000000] efi: UEFI not found. [    0.000000] cma: Reserved 64 MiB at 0x00000000f4000000 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.0 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: Trusted OS migration not required [    0.000000] psci: SMC Calling Convention v1.0 [    0.000000] percpu: Embedded 34 pages/cpu s101400 r8192 d29672 u139264 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: ARM erratum 845719 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 991752 [    0.000000] Kernel command line: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_ved [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB) [    0.000000] Memory: 3788560K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176368K reserved, 65536K cma-reserved) [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x78/0x130 with crng_init=0 [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [    0.000000] rcu: Hierarchical RCU implementation. [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [    0.000000]  Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 256 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] GICv3: 16 PPIs implemented [    0.000000] GICv3: no VLPI support, no direct LPI support, no RVPEID support [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [    0.000000] ITS [mem 0xfee20000-0xfee3ffff] [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @eec80000 (flat, esz 8, psz 64K, shr 0) [    0.000000] ITS: using cache flushing for cmd queue [    0.000000] GICv3: using LPI property table @0x00000000eec40000 [    0.000000] GIC: using cache flushing for LPI property table [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eec50000 [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001134] Console: colour dummy device 80x25 [    0.001178] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [    0.001190] pid_max: default: 32768 minimum: 301 [    0.001354] LSM: Security Framework initializing [    0.001373] Yama: becoming mindful. [    0.001453] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [    0.001477] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [    0.001535] *** VALIDATE tmpfs *** [    0.002034] *** VALIDATE proc *** [    0.002279] *** VALIDATE cgroup1 *** [    0.002288] *** VALIDATE cgroup2 *** [    0.003193] ASID allocator initialised with 65536 entries [    0.003280] rcu: Hierarchical SRCU implementation. [    0.003521] Platform MSI: interrupt-controller@fee20000 domain created [    0.003878] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [    0.004448] EFI services will not be available. [    0.004855] smp: Bringing up secondary CPUs ... [    0.005339] Detected VIPT I-cache on CPU1 [    0.005372] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [    0.005386] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000 [    0.005429] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [    0.005981] Detected VIPT I-cache on CPU2 [    0.006006] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [    0.006017] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000 [    0.006042] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [    0.006539] Detected VIPT I-cache on CPU3 [    0.006560] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [    0.006571] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000 [    0.006593] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [    0.007090] CPU features: detected: EL2 vector hardening [    0.007097] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware [    0.007102] CPU features: detected: ARM erratum 1319367 [    0.007106] Detected PIPT I-cache on CPU4 [    0.007130] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [    0.007141] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000 [    0.007169] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [    0.007695] Detected PIPT I-cache on CPU5 [    0.007715] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [    0.007725] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000 [    0.007746] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [    0.007829] smp: Brought up 1 node, 6 CPUs [    0.007881] SMP: Total of 6 processors activated. [    0.007888] CPU features: detected: 32-bit EL0 Support [    0.007895] CPU features: detected: CRC32 instructions [    0.035030] CPU: All CPU(s) started at EL2 [    0.035113] alternatives: patching kernel code [    0.037559] devtmpfs: initialized [    0.045502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [    0.045522] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [    0.048078] pinctrl core: initialized pinctrl subsystem [    0.048920] thermal_sys: Registered thermal governor 'fair_share' [    0.048923] thermal_sys: Registered thermal governor 'bang_bang' [    0.048932] thermal_sys: Registered thermal governor 'step_wise' [    0.048937] thermal_sys: Registered thermal governor 'user_space' [    0.049396] DMI not present or invalid. [    0.049879] NET: Registered protocol family 16 [    0.051835] DMA: preallocated 256 KiB pool for atomic allocations [    0.052786] cpuidle: using governor ladder [    0.052803] cpuidle: using governor menu [    0.053176] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.053407] Serial: AMBA PL011 UART driver [    0.079067] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [    0.079077] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [    0.079083] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [    0.079090] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [    0.090133] cryptd: max_cpu_qlen set to 1000 [    0.115489] ACPI: Interpreter disabled. [    0.116150] vcc3v3_pcie: supplied by vcc12v_dcin [    0.116996] vcc5v0_sys: supplied by vcc12v_dcin [    0.117205] vcc5v0_usb: supplied by vcc12v_dcin [    0.117321] vcc3v3_sys: supplied by vcc5v0_sys [    0.117707] iommu: Default domain type: Translated [    0.119181] vgaarb: loaded [    0.119826] SCSI subsystem initialized [    0.120123] usbcore: registered new interface driver usbfs [    0.120152] usbcore: registered new interface driver hub [    0.120213] usbcore: registered new device driver usb [    0.120610] mc: Linux media interface: v0.10 [    0.120630] videodev: Linux video capture interface: v2.00 [    0.120656] pps_core: LinuxPPS API ver. 1 registered [    0.120661] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    0.120671] PTP clock support registered [    0.120834] EDAC MC: Ver: 3.0.0 [    0.121411] Advanced Linux Sound Architecture Driver Initialized. [    0.121753] NetLabel: Initializing [    0.121759] NetLabel:  domain hash size = 128 [    0.121764] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO [    0.121809] NetLabel:  unlabeled traffic allowed by default [    0.122251] clocksource: Switched to clocksource arch_sys_counter [    0.122262] *** VALIDATE bpf *** [    0.122418] VFS: Disk quotas dquot_6.6.0 [    0.122467] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    0.122522] *** VALIDATE ramfs *** [    0.122536] *** VALIDATE hugetlbfs *** [    0.122826] pnp: PnP ACPI: disabled [    0.127399] NET: Registered protocol family 2 [    0.127895] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [    0.127956] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [    0.128215] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [    0.128705] TCP: Hash tables configured (established 32768 bind 32768) [    0.128811] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [    0.128910] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [    0.129133] NET: Registered protocol family 1 [    0.129578] RPC: Registered named UNIX socket transport module. [    0.129585] RPC: Registered udp transport module. [    0.129590] RPC: Registered tcp transport module. [    0.129595] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.129605] PCI: CLS 0 bytes, default 64 [    0.130535] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [    0.130768] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [    0.131119] kvm [1]: IPA Size Limit: 40bits [    0.132480] kvm [1]: vgic-v2@fff20000 [    0.132502] kvm [1]: GIC system register CPU interface enabled [    0.132645] kvm [1]: vgic interrupt IRQ10 [    0.132804] kvm [1]: Hyp mode initialized successfully [    0.180728] Initialise system trusted keyrings [    0.180895] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [    0.185636] zbud: loaded [    0.187497] NFS: Registering the id_resolver key type [    0.187521] Key type id_resolver registered [    0.187527] Key type id_legacy registered [    0.187540] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [    0.187570] ntfs: driver 2.1.32 [Flags: R/W]. [    0.187875] fuse: init (API version 7.31) [    0.187945] *** VALIDATE fuse *** [    0.187956] *** VALIDATE fuse *** [    0.188215] SGI XFS with ACLs, security attributes, quota, no debug enabled [    0.189501] *** VALIDATE xfs *** [    0.209703] NET: Registered protocol family 38 [    0.209716] Key type asymmetric registered [    0.209721] Asymmetric key parser 'x509' registered [    0.209757] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [    0.209877] io scheduler mq-deadline registered [    0.209885] io scheduler kyber registered [    0.209984] io scheduler bfq registered [    0.211834] vcc5v0_host: supplied by vcc5v0_usb [    0.217136] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie1v8 not found, using dummy regulator [    0.217186] rockchip-pcie f8000000.pcie: f8000000.pcie supply vpcie0v9 not found, using dummy regulator [    0.762315] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [    0.762672] rockchip-pcie: probe of f8000000.pcie failed with error -110 [    0.763531] IPMI message handler: version 39.2 [    0.765021] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [    0.765681] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.765692] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [    0.765914] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [    0.766980] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.766992] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [    0.768508] pwm-regulator: supplied by regulator-dummy [    0.768699] vcc5v0_typec: supplied by vcc5v0_usb [    0.769410] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [    0.771147] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A [    0.771866] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A [    0.877017] printk: console [ttyS2] enabled [    0.879302] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    0.882481] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [    0.883097] spi-nor: probe of spi0.0 failed with error -2 [    0.884214] libphy: Fixed MDIO Bus: probed [    0.884638] usbcore: registered new interface driver asix [    0.891470] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port [    0.899191] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    0.899766] ehci-pci: EHCI PCI platform driver [    0.900181] ehci-platform: EHCI generic platform driver [    0.902799] ehci-platform fe380000.usb: EHCI Host Controller [    0.903403] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [    0.904169] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000 [    0.932277] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [    0.932927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.933651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.934283] usb usb1: Product: EHCI Host Controller [    0.934712] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [    0.935276] usb usb1: SerialNumber: fe380000.usb [    0.935987] hub 1-0:1.0: USB hub found [    0.936339] hub 1-0:1.0: 1 port detected [    0.939040] ehci-platform fe3c0000.usb: EHCI Host Controller [    0.939631] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2 [    0.940382] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000 [    0.962274] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [    0.962909] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.963634] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.964267] usb usb2: Product: EHCI Host Controller [    0.964697] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [    0.965260] usb usb2: SerialNumber: fe3c0000.usb [    0.965940] hub 2-0:1.0: USB hub found [    0.966290] hub 2-0:1.0: 1 port detected [    0.967034] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    0.967586] ohci-pci: OHCI PCI platform driver [    0.968015] ohci-platform: OHCI generic platform driver [    0.968618] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [    0.969323] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3 [    0.970073] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000 [    1.036390] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [    1.037114] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.037746] usb usb3: Product: Generic Platform OHCI controller [    1.038265] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [    1.038828] usb usb3: SerialNumber: fe3a0000.usb [    1.039531] hub 3-0:1.0: USB hub found [    1.039882] hub 3-0:1.0: 1 port detected [    1.040548] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [    1.041226] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4 [    1.041968] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000 [    1.116480] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [    1.117208] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.117842] usb usb4: Product: Generic Platform OHCI controller [    1.118363] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [    1.118929] usb usb4: SerialNumber: fe3e0000.usb [    1.119801] hub 4-0:1.0: USB hub found [    1.120160] hub 4-0:1.0: 1 port detected [    1.121090] uhci_hcd: USB Universal Host Controller Interface driver [    1.122497] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    1.123132] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [    1.123931] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    1.124774] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000 [    1.125579] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    1.126306] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.126939] usb usb5: Product: xHCI Host Controller [    1.127369] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    1.127934] usb usb5: SerialNumber: xhci-hcd.0.auto [    1.128761] hub 5-0:1.0: USB hub found [    1.129120] hub 5-0:1.0: 1 port detected [    1.129757] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    1.130363] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [    1.131042] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [    1.131668] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [    1.132497] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [    1.133223] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.133857] usb usb6: Product: xHCI Host Controller [    1.134288] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    1.134853] usb usb6: SerialNumber: xhci-hcd.0.auto [    1.135661] hub 6-0:1.0: USB hub found [    1.136017] hub 6-0:1.0: 1 port detected [    1.136799] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    1.137409] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [    1.138204] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    1.139070] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000 [    1.139872] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    1.140599] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.141232] usb usb7: Product: xHCI Host Controller [    1.141664] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    1.142229] usb usb7: SerialNumber: xhci-hcd.1.auto [    1.143063] hub 7-0:1.0: USB hub found [    1.143420] hub 7-0:1.0: 1 port detected [    1.144046] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    1.144646] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [    1.145327] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [    1.145951] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [    1.146755] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [    1.147481] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.148114] usb usb8: Product: xHCI Host Controller [    1.148545] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    1.149110] usb usb8: SerialNumber: xhci-hcd.1.auto [    1.149917] hub 8-0:1.0: USB hub found [    1.150272] hub 8-0:1.0: 1 port detected [    1.151030] usbcore: registered new interface driver uas [    1.151630] usbcore: registered new interface driver usb-storage [    1.152191] usbcore: registered new interface driver ums-alauda [    1.152766] usbcore: registered new interface driver ums-cypress [    1.153326] usbcore: registered new interface driver ums-datafab [    1.153883] usbcore: registered new interface driver ums_eneub6250 [    1.154455] usbcore: registered new interface driver ums-freecom [    1.155013] usbcore: registered new interface driver ums-isd200 [    1.155562] usbcore: registered new interface driver ums-jumpshot [    1.156126] usbcore: registered new interface driver ums-karma [    1.156667] usbcore: registered new interface driver ums-onetouch [    1.157246] usbcore: registered new interface driver ums-realtek [    1.157806] usbcore: registered new interface driver ums-sddr09 [    1.158355] usbcore: registered new interface driver ums-sddr55 [    1.158905] usbcore: registered new interface driver ums-usbat [    1.159493] usbcore: registered new interface driver usbserial_generic [    1.160082] usbserial: USB Serial support registered for generic [    1.162823] mousedev: PS/2 mouse device common for all mice [    1.165439] rk808 0-001b: chip id: 0x0 [    1.169034] rk808-regulator rk808-regulator: there is no dvs0 gpio [    1.169592] rk808-regulator rk808-regulator: there is no dvs1 gpio [    1.170175] DCDC_REG1: supplied by vcc5v0_sys [    1.171369] DCDC_REG2: supplied by vcc5v0_sys [    1.172294] DCDC_REG3: supplied by vcc5v0_sys [    1.172826] DCDC_REG4: supplied by vcc5v0_sys [    1.173643] LDO_REG1: supplied by vcc5v0_sys [    1.175213] LDO_REG2: supplied by vcc5v0_sys [    1.175750] vcc3v0_touch: Bringing 1800000uV into 3000000-3000000uV [    1.177264] LDO_REG3: supplied by vcc5v0_sys [    1.178682] LDO_REG4: supplied by vcc5v0_sys [    1.179215] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV [    1.180751] LDO_REG5: supplied by vcc5v0_sys [    1.182039] LDO_REG6: supplied by vcc5v0_sys [    1.183552] LDO_REG7: supplied by vcc5v0_sys [    1.184859] LDO_REG8: supplied by vcc5v0_sys [    1.186302] SWITCH_REG1: supplied by vcc3v3_sys [    1.186992] SWITCH_REG2: supplied by vcc3v3_sys [    1.190664] rk808-rtc rk808-rtc: registered as rtc0 [    1.191643] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [    1.192277] fan53555-reg: supplied by vcc5v0_sys [    1.193581] random: fast init done [    1.194165] vcc1v8_s3: supplied by vcc_1v8 [    1.195046] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [    1.195659] fan53555-reg: supplied by vcc5v0_sys [    1.198012] typec_fusb302 4-0022: No cable types defined, using default cables [    1.198706] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [    1.202715] device-mapper: uevent: version 1.0.3 [    1.203310] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com [    1.207771] sdhci: Secure Digital Host Controller Interface driver [    1.208315] sdhci: Copyright(c) Pierre Ossman [    1.209280] Synopsys Designware Multimedia Card Interface Driver [    1.210806] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [    1.211455] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [    1.212058] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [    1.212588] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo [    1.213498] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO [    1.226613] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    1.240550] sdhci-pltfm: SDHCI platform and OF driver helper [    1.241747] mmc1: CQHCI version 5.10 [    1.267598] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [    1.269753] ledtrig-cpu: registered to indicate activity on CPUs [    1.270570] hid: raw HID events driver (C) Jiri Kosina [    1.271129] usbcore: registered new interface driver usbhid [    1.271616] usbhid: USB HID core driver [    1.275774] Initializing XFRM netlink socket [    1.276401] NET: Registered protocol family 10 [    1.282121] Segment Routing with IPv6 [    1.282532] mip6: Mobile IPv6 [    1.282798] NET: Registered protocol family 17 [    1.283562] Key type dns_resolver registered [    1.284779] registered taskstats version 1 [    1.285141] Loading compiled-in X.509 certificates [    1.285612] zswap: loaded using pool lzo/zbud [    1.286052] Key type ._fscrypt registered [    1.286403] Key type .fscrypt registered [    1.286745] Key type fscrypt-provisioning registered [    1.287213] Key type big_key registered [    1.288801] Key type encrypted registered [    1.304489] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:16 UTC (1358499016) [    1.306190] ALSA device list: [    1.306455]   No soundcards found. [    1.306954] ttyS2 - failed to request DMA [    1.307386] md: Waiting for all devices to be available before autodetect [    1.307978] md: If you don't use raid, use raid=noautodetect [    1.308959] md: Autodetecting RAID arrays. [    1.309320] md: autorun ... [    1.309566] md: ... autorun DONE. [    1.309886] Waiting for root device /dev/mmcblk1p3... [    1.322757] usb 1-1: new high-speed USB device number 2 using ehci-platform [    1.367034] mmc1: Command Queue Engine enabled [    1.367446] mmc1: new HS200 MMC card at address 0001 [    1.368507] mmcblk1: mmc1:0001 SLD32G 28.9 GiB [    1.369117] mmcblk1boot0: mmc1:0001 SLD32G partition 1 4.00 MiB [    1.369842] mmcblk1boot1: mmc1:0001 SLD32G partition 2 4.00 MiB [    1.370589] mmcblk1rpmb: mmc1:0001 SLD32G partition 3 4.00 MiB, chardev (238:0) [    1.374028] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [    1.374750] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [    1.375375] usb 1-1: Product: USB 2.0 Hub [    1.375549] GPT:Primary header thinks Alt. header is not at the end of the disk. [    1.376231] hub 1-1:1.0: USB hub found [    1.376376] GPT:8708252 != 60620799 [    1.376834] hub 1-1:1.0: 4 ports detected [    1.377010] GPT:Alternate GPT header not at the end of the disk. [    1.377884] GPT:8708252 != 60620799 [    1.378191] GPT: Use GNU Parted to correct GPT errors. [    1.378684]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 [    1.453997] EXT4-fs (mmcblk1p3): mounted filesystem without journal. Opts: (null) [    1.454719] VFS: Mounted root (ext4 filesystem) on device 179:3. [    1.457760] devtmpfs: mounted [    1.458404] Freeing unused kernel memory: 1216K [    1.458859] Run /sbin/init as init process [    1.512557] usb 8-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [    1.548005] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54 [    1.548734] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    1.549360] usb 8-1: Product: USB3.1 Hub [    1.549706] usb 8-1: Manufacturer: GenesysLogic [    1.578726] hub 8-1:1.0: USB hub found [    1.579421] hub 8-1:1.0: 4 ports detected [    1.584201] random: init: uninitialized urandom read (12 bytes read) [    1.692383] usb 7-1: new high-speed USB device number 2 using xhci-hcd [    1.725403] usb 7-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54 [    1.726130] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    1.726756] usb 7-1: Product: USB2.1 Hub [    1.727102] usb 7-1: Manufacturer: GenesysLogic [    1.752402] usb 4-1: new full-speed USB device number 2 using ohci-platform [    1.786931] hub 7-1:1.0: USB hub found [    1.787733] hub 7-1:1.0: 4 ports detected [    1.802532] usb 1-1.1: new low-speed USB device number 3 using ehci-platform [    1.841435] configfs: Unknown parameter 'mode' [    1.842904] udevd[428]: starting version 225 [    1.857233] random: udevadm: uninitialized urandom read (16 bytes read) [    1.857878] random: udevadm: uninitialized urandom read (16 bytes read) [    2.017350] usb 4-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice= 1.34 [    2.018126] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    2.029477] frecon[486]: No monitor available, running headless! [    2.032691] frecon[486]: No monitor available, running headless! [    2.035080] frecon[486]: No monitor available, running headless! [    2.037729] frecon[486]: No monitor available, running headless! [    2.069259] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08 [    2.069993] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [    2.070632] usb 1-1.1: Product: Dell KB216 Wired Keyboard [    2.075262] input: Dell KB216 Wired Keyboard as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input0 [    2.122309] usb 7-1.3: new low-speed USB device number 3 using xhci-hcd [    2.144113] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input0 [    2.151809] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input1 [    2.223198] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input2 [    2.225210] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input1 [    2.277036] usb 7-1.3: New USB device found, idVendor=03f0, idProduct=0941, bcdDevice= 1.00 [    2.277780] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    2.278422] usb 7-1.3: Product: HP X500 USB Optical Mouse [    2.278897] usb 7-1.3: Manufacturer: PixArt [    2.316577] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600 [    2.324883] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null) [    2.333301] input: PixArt HP X500 USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:03F0:0941.00033 [    2.335911] hid-generic 0003:03F0:0941.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt HP X500 USB Optical Mouse] on usb-xhci-hcd.1.auto-1.3/input0 [    2.348541] Bluetooth: Core ver 2.22 [    2.348893] NET: Registered protocol family 31 [    2.349282] Bluetooth: HCI device and connection manager initialized [    2.349843] Bluetooth: HCI socket layer initialized [    2.350271] Bluetooth: L2CAP socket layer initialized [    2.350717] Bluetooth: SCO socket layer initialized [    2.358653] usbcore: registered new interface driver btusb [    2.422316] usb 1-1.2: new full-speed USB device number 4 using ehci-platform [    2.426837] loop: module loaded [    2.462466] usb 7-1.4: new high-speed USB device number 4 using xhci-hcd [    2.493465] usb 7-1.4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00 [    2.494204] usb 7-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [    2.494842] usb 7-1.4: Product: 802.11n NIC [    2.495209] usb 7-1.4: Manufacturer: Realtek [    2.495583] usb 7-1.4: SerialNumber: 00E04C0001 [    2.676319] usb 1-1.2: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00 [    2.677054] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    2.677693] usb 1-1.2: Product: USB Audio Device [    2.678097] usb 1-1.2: Manufacturer: C-Media Electronics Inc. [    2.680569] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/fe380000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:0D8C:0014.0004/input/input4 [    2.744142] hid-generic 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-fe380000.usb-1.2/input3 [    2.920672] usbcore: registered new interface driver snd-usb-audio [    3.023625] lib80211: common routines for IEEE802.11 drivers [    3.049599] r8188eu: module is from the staging directory, the quality is unknown, you have been warned. [    3.062528] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0) [    3.086552] usbcore: registered new interface driver r8188eu [    4.859697] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: discard,commit=600 [    4.867508] EXT4-fs (dm-0): resizing filesystem from 4096 to 149900 blocks [    4.870966] EXT4-fs (dm-0): resized filesystem to 149900 [    5.113122] EXT4-fs (mmcblk1p1): re-mounted. Opts: resgid=20119,commit=600 [    5.237740] init: ureadahead main process (663) terminated with status 5 [    5.304608] systemd-journald[757]: Running without systemd. [    5.306503] zram: Added device: zram0 [    5.317920] zram0: detected capacity change from 0 to 3855314944 [    5.338466] systemd-journald[757]: Received request to flush runtime journal from PID 813 [    5.352371] init: vpd-log main process (672) terminated with status 1 [    5.530220] init: platform-cpusets main process (894) terminated with status 2 [    5.636683] init: tcsd main process (1012) terminated with status 137 [    5.637284] init: tcsd main process ended, respawning [    5.677151] init: machine-info pre-start process (910) terminated with status 1 [    5.816319] init: daisydog pre-start process (896) terminated with status 1 [    6.402624] Adding 3764952k swap on /dev/zram0.  Priority:-2 extents:1 across:3764952k SSFS Developer Console To return to the browser, press:  [ Ctrl ] and [ Alt ] and [ <- ]  (F1) To use this console, the developer mode switch must be engaged. Doing so will destroy any saved data on the system. In developer mode, it is possible to - login and sudo as user 'chronos' - require a password for sudo and login(*) - disable power management behavior (screen dimming):  sudo initctl stop powerd - install your own operating system image! * To set a password for 'chronos', run the following as root: chromeos-setdevpasswd If you are having trouble booting a self-signed kernel, you may need to enable USB booting.  To do so, run the following as root: enable_dev_usb_boot Have fun and send patches! (none) login: [    7.548165] ttyS0 - failed to request DMA [    8.222467] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_DCP_CHARGER [    9.882274] random: crng init done [    9.882577] random: 7 urandom warning(s) missed due to ratelimiting [   12.466276] init: ui main process (1135) terminated with status 2 [   12.875065] init: machine-info pre-start process (1522) terminated with status 1 [   14.793602] init: ui main process (1615) terminated with status 2 [   15.195987] init: machine-info pre-start process (1775) terminated with status 1 [   17.186482] init: ui main process (1872) terminated with status 2 [   17.610288] init: machine-info pre-start process (2032) terminated with status 1 [   17.622996] init: sdio-hciattach main process (900) terminated with status 1 [   19.485718] init: ui main process (2125) terminated with status 2 [   19.924661] init: machine-info pre-start process (2287) terminated with status 1 [   21.802552] init: ui main process (2380) terminated with status 2 [   22.214531] init: machine-info pre-start process (2547) terminated with status 1 [   24.100347] init: ui main process (2640) terminated with status 2 [   24.509680] init: machine-info pre-start process (2798) terminated with status 1 [   26.540113] init: ui main process (2891) terminated with status 2 [   35.640485] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [   35.641069] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [   35.642167] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [   35.643008] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [   35.643625] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [   35.644119] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [   35.644616] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [   35.645178] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [   35.645784] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [   35.651322] rk_gmac-dwmac fe300000.ethernet: init for RGMII [   35.653096] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [   35.653725] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000 [   35.654181] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [   35.654833] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [   35.655482] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [   35.655937] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [   35.656550] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [   35.657137] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [   35.657652] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [   35.658161] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [   35.728133] es8316 1-0011: Failed to get IRQ 0: -22 [   35.830415] libphy: stmmac: probed [   35.830725] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [   35.831815] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [   35.847450] rockchip-vop ff8f0000.vop: Adding to iommu group 1 [   35.848576] rockchip-vop ff900000.vop: Adding to iommu group 2 [   35.854512] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm]) [   35.857202] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm]) [   35.858187] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [   35.859721] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [   35.860552] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [   35.861128] [drm] No driver support for vblank timestamp query. [   35.861695] [drm] Cannot find any crtc or sizes [   35.862621] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [   35.933669] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. [   35.935417] rockchip-rga ff680000.rga: HW Version: 0x03.02 [   35.936292] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 [   35.937128] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [   35.943117] panfrost ff9a0000.gpu: clock rate = 500000000 [   35.943504] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [   35.948635] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [   35.949642] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2 [   35.950152] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [   35.951067] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [   35.951664] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [   35.955898] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [   35.956696] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 [   35.957512] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [   35.958685] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [   35.965780] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1 [   35.980666] input: gpio-keys as /devices/platform/gpio-keys/input/input5 [   36.060414] asoc-audio-graph-card sound: ES8316 HiFi <-> ff890000.i2s mapping ok [   36.061109] asoc-audio-graph-card sound: ASoC: no DMI vendor name! [   36.077529] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok [   36.078195] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name! [   36.082459] Registered IR keymap rc-cec [   36.082978] rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0 [   36.083768] input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input6 [   36.166406] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   36.181286] Console: switching to colour frame buffer device 240x67 [   36.221709] rockchip-drm display-subsystem: fb0: rockchipdrmfb frame buffer device [   37.004427] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   37.844574] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   38.690685] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   39.530399] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   40.376052] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   41.220474] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   42.060487] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   42.905584] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   43.746209] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   44.590604] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   45.436533] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   46.276535] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   47.121836] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   47.961761] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   48.806530] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   49.652324] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   50.492506] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   51.338095] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   52.177650] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   53.022484] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock [   53.868216] dwhdmi-rockchip ff940000.hdmi: PHY PLL failed to lock
It booted, but screen didnt light up, likely due to HDMI errors above.
However via serial console, its responsive!
Developer Console To return to the browser, press:  [ Ctrl ] and [ Alt ] and [ <- ]  (F1) To use this console, the developer mode switch must be engaged. Doing so will destroy any saved data on the system. In developer mode, it is possible to - login and sudo as user 'chronos' - require a password for sudo and login(*) - disable power management behavior (screen dimming):  sudo initctl stop powerd - install your own operating system image! * To set a password for 'chronos', run the following as root: chromeos-setdevpasswd If you are having trouble booting a self-signed kernel, you may need to enable USB booting.  To do so, run the following as root: enable_dev_usb_boot Have fun and send patches! (none) login: chronos chronos@(none) ~ $ chronos@(none) ~ $ ls -la total 8 drwxr-xr-x 2 chronos chronos 4096 Jan  1 16:00 . drwxr-xr-x 5 chronos chronos 4096 Jan  1 16:00 .. chronos@(none) ~ $ uname -a Linux (none) 5.5.0-MANJARO-ARM+ #3 SMP Mon Feb 17 00:45:01 CET 2020 aarch64 GNU/Linux chronos@(none) ~ $
Happy to investiage further as needed.
Thanks!
Noticing that u-boot was applying dtb file for RockPro64, I moved the RockPro64 dtb file and replaced it with dtb file for my device (Rock-Pi-4).
Result: it does not reach developer console, similar to output posted by @tophneal earlier:
Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [    0.000000] Linux version 5.5.0-MANJARO-ARM+ (brent@brent-pc) (gcc version 4.9.x 20150123 (prerelease) (4.9.2_cos_gg_4.9.2-r223-ac6128e0a17a52f011797f33ac3e7d620 [    0.000000] Machine model: Radxa ROCK Pi 4 [    0.000000] efi: Getting EFI parameters from FDT: [    0.000000] efi: UEFI not found. [    0.000000] cma: Reserved 64 MiB at 0x00000000f4000000 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.0 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: Trusted OS migration not required [    0.000000] psci: SMC Calling Convention v1.0 [    0.000000] percpu: Embedded 34 pages/cpu s101400 r8192 d29672 u139264 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: ARM erratum 845719 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 991752 [    0.000000] Kernel command line: earlyprintk console=ttyS2,1500000n8 rw root=/dev/mmcblk1p3 rootfstype=ext4 init=/sbin/init rootwait cros_debug loglevel=7 dm_ved [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB) [    0.000000] Memory: 3788564K/4030464K available (13628K kernel code, 838K rwdata, 5448K rodata, 1216K init, 8475K bss, 176364K reserved, 65536K cma-reserved) [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x78/0x130 with crng_init=0 [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [    0.000000] rcu: Hierarchical RCU implementation. [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [    0.000000]  Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 256 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] GICv3: 16 PPIs implemented [    0.000000] GICv3: no VLPI support, no direct LPI support, no RVPEID support [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [    0.000000] ITS [mem 0xfee20000-0xfee3ffff] [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @eec80000 (flat, esz 8, psz 64K, shr 0) [    0.000000] ITS: using cache flushing for cmd queue [    0.000000] GICv3: using LPI property table @0x00000000eec40000 [    0.000000] GIC: using cache flushing for LPI property table [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eec50000 [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001054] Console: colour dummy device 80x25 [    0.001098] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [    0.001109] pid_max: default: 32768 minimum: 301 [    0.001267] LSM: Security Framework initializing [    0.001285] Yama: becoming mindful. [    0.001367] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [    0.001391] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [    0.001450] *** VALIDATE tmpfs *** [    0.001947] *** VALIDATE proc *** [    0.002203] *** VALIDATE cgroup1 *** [    0.002212] *** VALIDATE cgroup2 *** [    0.003123] ASID allocator initialised with 65536 entries [    0.003210] rcu: Hierarchical SRCU implementation. [    0.003447] Platform MSI: interrupt-controller@fee20000 domain created [    0.003782] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [    0.004310] EFI services will not be available. [    0.004714] smp: Bringing up secondary CPUs ... [    0.005198] Detected VIPT I-cache on CPU1 [    0.005231] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [    0.005246] GICv3: CPU1: using allocated LPI pending table @0x00000000eec60000 [    0.005289] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [    0.005838] Detected VIPT I-cache on CPU2 [    0.005862] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [    0.005873] GICv3: CPU2: using allocated LPI pending table @0x00000000eec70000 [    0.005898] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [    0.006394] Detected VIPT I-cache on CPU3 [    0.006416] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [    0.006426] GICv3: CPU3: using allocated LPI pending table @0x00000000eed00000 [    0.006449] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [    0.006948] CPU features: detected: EL2 vector hardening [    0.006954] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware [    0.006959] CPU features: detected: ARM erratum 1319367 [    0.006963] Detected PIPT I-cache on CPU4 [    0.006988] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [    0.006999] GICv3: CPU4: using allocated LPI pending table @0x00000000eed10000 [    0.007026] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [    0.007549] Detected PIPT I-cache on CPU5 [    0.007570] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [    0.007579] GICv3: CPU5: using allocated LPI pending table @0x00000000eed20000 [    0.007601] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [    0.007684] smp: Brought up 1 node, 6 CPUs [    0.007736] SMP: Total of 6 processors activated. [    0.007744] CPU features: detected: 32-bit EL0 Support [    0.007751] CPU features: detected: CRC32 instructions [    0.034793] CPU: All CPU(s) started at EL2 [    0.034879] alternatives: patching kernel code [    0.037317] devtmpfs: initialized [    0.045316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [    0.045336] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [    0.047905] pinctrl core: initialized pinctrl subsystem [    0.048732] thermal_sys: Registered thermal governor 'fair_share' [    0.048735] thermal_sys: Registered thermal governor 'bang_bang' [    0.048744] thermal_sys: Registered thermal governor 'step_wise' [    0.048750] thermal_sys: Registered thermal governor 'user_space' [    0.049205] DMI not present or invalid. [    0.049687] NET: Registered protocol family 16 [    0.051630] DMA: preallocated 256 KiB pool for atomic allocations [    0.052551] cpuidle: using governor ladder [    0.052568] cpuidle: using governor menu [    0.052937] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.053167] Serial: AMBA PL011 UART driver [    0.077926] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [    0.077935] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [    0.077942] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [    0.077948] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [    0.088968] cryptd: max_cpu_qlen set to 1000 [    0.114115] ACPI: Interpreter disabled. [    0.114509] vcc5v0_sys: supplied by vcc12v_dcin [    0.114801] vcc3v3_pcie: supplied by vcc5v0_sys [    0.114995] vcc3v3_sys: supplied by vcc5v0_sys [    0.115257] vcc5v0_host: supplied by vcc5v0_sys [    0.115495] vcc5v0_typec: supplied by vcc5v0_sys [    0.116078] iommu: Default domain type: Translated [    0.117650] vgaarb: loaded [    0.118281] SCSI subsystem initialized [    0.118570] usbcore: registered new interface driver usbfs [    0.118599] usbcore: registered new interface driver hub [    0.118662] usbcore: registered new device driver usb [    0.119014] mc: Linux media interface: v0.10 [    0.119036] videodev: Linux video capture interface: v2.00 [    0.119066] pps_core: LinuxPPS API ver. 1 registered [    0.119070] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    0.119093] PTP clock support registered [    0.119245] EDAC MC: Ver: 3.0.0 [    0.119747] Advanced Linux Sound Architecture Driver Initialized. [    0.120088] NetLabel: Initializing [    0.120094] NetLabel:  domain hash size = 128 [    0.120099] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO [    0.120154] NetLabel:  unlabeled traffic allowed by default [    0.120589] clocksource: Switched to clocksource arch_sys_counter [    0.120599] *** VALIDATE bpf *** [    0.120750] VFS: Disk quotas dquot_6.6.0 [    0.120799] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    0.120851] *** VALIDATE ramfs *** [    0.120865] *** VALIDATE hugetlbfs *** [    0.121140] pnp: PnP ACPI: disabled [    0.125704] NET: Registered protocol family 2 [    0.126197] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [    0.126257] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [    0.126516] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [    0.127006] TCP: Hash tables configured (established 32768 bind 32768) [    0.127114] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [    0.127214] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [    0.127447] NET: Registered protocol family 1 [    0.127886] RPC: Registered named UNIX socket transport module. [    0.127893] RPC: Registered udp transport module. [    0.127897] RPC: Registered tcp transport module. [    0.127902] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.127911] PCI: CLS 0 bytes, default 64 [    0.128847] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [    0.129074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [    0.129382] kvm [1]: IPA Size Limit: 40bits [    0.130732] kvm [1]: vgic-v2@fff20000 [    0.130755] kvm [1]: GIC system register CPU interface enabled [    0.130899] kvm [1]: vgic interrupt IRQ10 [    0.131057] kvm [1]: Hyp mode initialized successfully [    0.177207] Initialise system trusted keyrings [    0.177338] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [    0.182107] zbud: loaded [    0.183979] NFS: Registering the id_resolver key type [    0.184004] Key type id_resolver registered [    0.184010] Key type id_legacy registered [    0.184023] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [    0.184057] ntfs: driver 2.1.32 [Flags: R/W]. [    0.184358] fuse: init (API version 7.31) [    0.184428] *** VALIDATE fuse *** [    0.184439] *** VALIDATE fuse *** [    0.184696] SGI XFS with ACLs, security attributes, quota, no debug enabled [    0.186022] *** VALIDATE xfs *** [    0.206043] NET: Registered protocol family 38 [    0.206058] Key type asymmetric registered [    0.206064] Asymmetric key parser 'x509' registered [    0.206104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [    0.206226] io scheduler mq-deadline registered [    0.206232] io scheduler kyber registered [    0.206330] io scheduler bfq registered [    0.212669] IPMI message handler: version 39.2 [    0.213822] dma-pl330 ff6d0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [    0.214243] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.214252] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [    0.214408] dma-pl330 ff6e0000.dma-controller: WARN: Device release is not defined so it is not safe to unbind this driver while in use [    0.215090] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [    0.215099] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [    0.216132] pwm-regulator: supplied by regulator-dummy [    0.216777] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [    0.218042] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A [    0.218148] serial serial0: tty port ttyS0 registered [    0.218492] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A [    0.320700] printk: console [ttyS2] enabled [    0.322763] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    0.325616] libphy: Fixed MDIO Bus: probed [    0.326038] usbcore: registered new interface driver asix [    0.331734] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port [    0.338948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    0.339522] ehci-pci: EHCI PCI platform driver [    0.339936] ehci-platform: EHCI generic platform driver [    0.342550] ehci-platform fe380000.usb: EHCI Host Controller [    0.343150] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [    0.343917] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [    0.370602] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [    0.371252] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.371977] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.372610] usb usb1: Product: EHCI Host Controller [    0.373039] usb usb1: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [    0.373602] usb usb1: SerialNumber: fe380000.usb [    0.374330] hub 1-0:1.0: USB hub found [    0.374685] hub 1-0:1.0: 1 port detected [    0.377383] ehci-platform fe3c0000.usb: EHCI Host Controller [    0.377977] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2 [    0.378730] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [    0.400605] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [    0.401256] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.401980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.402614] usb usb2: Product: EHCI Host Controller [    0.403042] usb usb2: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ehci_hcd [    0.403607] usb usb2: SerialNumber: fe3c0000.usb [    0.404298] hub 2-0:1.0: USB hub found [    0.404647] hub 2-0:1.0: 1 port detected [    0.405380] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    0.405930] ohci-pci: OHCI PCI platform driver [    0.406362] ohci-platform: OHCI generic platform driver [    0.406973] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [    0.407657] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3 [    0.408409] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [    0.474745] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [    0.475470] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.476103] usb usb3: Product: Generic Platform OHCI controller [    0.476623] usb usb3: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [    0.477187] usb usb3: SerialNumber: fe3a0000.usb [    0.477883] hub 3-0:1.0: USB hub found [    0.478238] hub 3-0:1.0: 1 port detected [    0.478896] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [    0.479582] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4 [    0.480329] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [    0.554838] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.05 [    0.555567] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.556201] usb usb4: Product: Generic Platform OHCI controller [    0.556722] usb usb4: Manufacturer: Linux 5.5.0-MANJARO-ARM+ ohci_hcd [    0.557288] usb usb4: SerialNumber: fe3e0000.usb [    0.558201] hub 4-0:1.0: USB hub found [    0.558560] hub 4-0:1.0: 1 port detected [    0.559470] uhci_hcd: USB Universal Host Controller Interface driver [    0.560771] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    0.561402] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [    0.562203] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    0.563045] xhci-hcd xhci-hcd.0.auto: irq 224, io mem 0xfe800000 [    0.563852] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.564579] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.565212] usb usb5: Product: xHCI Host Controller [    0.565644] usb usb5: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    0.566209] usb usb5: SerialNumber: xhci-hcd.0.auto [    0.567045] hub 5-0:1.0: USB hub found [    0.567403] hub 5-0:1.0: 1 port detected [    0.568036] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    0.568640] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [    0.569320] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [    0.569946] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [    0.570774] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [    0.571500] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.572134] usb usb6: Product: xHCI Host Controller [    0.572565] usb usb6: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    0.573130] usb usb6: SerialNumber: xhci-hcd.0.auto [    0.573946] hub 6-0:1.0: USB hub found [    0.574302] hub 6-0:1.0: 1 port detected [    0.575072] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    0.575686] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [    0.576496] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    0.577366] xhci-hcd xhci-hcd.1.auto: irq 225, io mem 0xfe900000 [    0.578164] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05 [    0.578889] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.579522] usb usb7: Product: xHCI Host Controller [    0.579954] usb usb7: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    0.580519] usb usb7: SerialNumber: xhci-hcd.1.auto [    0.581353] hub 7-0:1.0: USB hub found [    0.581710] hub 7-0:1.0: 1 port detected [    0.582342] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    0.582940] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [    0.583626] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [    0.584271] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [    0.585074] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05 [    0.585800] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.586433] usb usb8: Product: xHCI Host Controller [    0.586865] usb usb8: Manufacturer: Linux 5.5.0-MANJARO-ARM+ xhci-hcd [    0.587430] usb usb8: SerialNumber: xhci-hcd.1.auto [    0.588242] hub 8-0:1.0: USB hub found [    0.588598] hub 8-0:1.0: 1 port detected [    0.589346] usbcore: registered new interface driver uas [    0.589950] usbcore: registered new interface driver usb-storage [    0.590508] usbcore: registered new interface driver ums-alauda [    0.591126] usbcore: registered new interface driver ums-cypress [    0.591688] usbcore: registered new interface driver ums-datafab [    0.592243] usbcore: registered new interface driver ums_eneub6250 [    0.592813] usbcore: registered new interface driver ums-freecom [    0.593375] usbcore: registered new interface driver ums-isd200 [    0.593924] usbcore: registered new interface driver ums-jumpshot [    0.594487] usbcore: registered new interface driver ums-karma [    0.595027] usbcore: registered new interface driver ums-onetouch [    0.595603] usbcore: registered new interface driver ums-realtek [    0.596163] usbcore: registered new interface driver ums-sddr09 [    0.596713] usbcore: registered new interface driver ums-sddr55 [    0.597262] usbcore: registered new interface driver ums-usbat [    0.597860] usbcore: registered new interface driver usbserial_generic [    0.598450] usbserial: USB Serial support registered for generic [    0.600912] mousedev: PS/2 mouse device common for all mice [    0.603439] rk808 0-001b: chip id: 0x0 [    0.606672] rk808-regulator rk808-regulator: there is no dvs0 gpio [    0.607228] rk808-regulator rk808-regulator: there is no dvs1 gpio [    0.607815] DCDC_REG1: supplied by vcc5v0_sys [    0.608916] DCDC_REG2: supplied by vcc5v0_sys [    0.609689] DCDC_REG3: supplied by vcc5v0_sys [    0.610220] DCDC_REG4: supplied by vcc5v0_sys [    0.611061] LDO_REG1: supplied by vcc5v0_sys [    0.612502] LDO_REG2: supplied by vcc5v0_sys [    0.613035] vcc1v8_hdmi: Bringing 3000000uV into 1800000-1800000uV [    0.614324] LDO_REG3: supplied by vcc5v0_sys [    0.615653] LDO_REG4: supplied by vcc5v0_sys [    0.616187] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV [    0.617593] LDO_REG5: supplied by vcc5v0_sys [    0.618778] LDO_REG6: supplied by vcc5v0_sys [    0.620105] LDO_REG7: supplied by vcc5v0_sys [    0.620645] vcc0v9_hdmi: Bringing 1800000uV into 900000-900000uV [    0.621961] LDO_REG8: supplied by vcc5v0_sys [    0.623314] SWITCH_REG1: supplied by vcc3v3_sys [    0.623871] SWITCH_REG2: supplied by vcc3v3_sys [    0.627301] rk808-rtc rk808-rtc: registered as rtc0 [    0.628274] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [    0.628887] fan53555-reg: supplied by vcc5v0_sys [    0.630746] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [    0.631357] fan53555-reg: supplied by vcc5v0_sys [    0.635234] device-mapper: uevent: version 1.0.3 [    0.635834] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com [    0.639894] sdhci: Secure Digital Host Controller Interface driver [    0.640436] sdhci: Copyright(c) Pierre Ossman [    0.641085] Synopsys Designware Multimedia Card Interface Driver [    0.642105] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [    0.642744] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [    0.643343] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [    0.643865] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [    0.644770] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [    0.645288] mmc_host mmc0: card is non-removable. [    0.646052] random: fast init done [    0.658980] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    0.671049] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [    0.671688] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [    0.672290] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [    0.672821] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [    0.673741] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO [    0.686910] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    0.701026] sdhci-pltfm: SDHCI platform and OF driver helper [    0.703197] mmc0: queuing unknown CIS tuple 0x80 (2 bytes) [    0.703284] mmc2: CQHCI version 5.10 [    0.705239] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [    0.707446] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [    0.710930] mmc0: queuing unknown CIS tuple 0x80 (7 bytes) [    0.716582] mmc0: queuing unknown CIS tuple 0x81 (9 bytes) [    0.730107] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [    0.732165] ledtrig-cpu: registered to indicate activity on CPUs [    0.733310] hid: raw HID events driver (C) Jiri Kosina [    0.733956] usbcore: registered new interface driver usbhid [    0.734450] usbhid: USB HID core driver [    0.740730] usb 1-1: new high-speed USB device number 2 using ehci-platform [    0.742045] Initializing XFRM netlink socket [    0.742866] NET: Registered protocol family 10 [    0.748346] Segment Routing with IPv6 [    0.748742] mip6: Mobile IPv6 [    0.749011] NET: Registered protocol family 17 [    0.749609] Key type dns_resolver registered [    0.750733] registered taskstats version 1 [    0.751098] Loading compiled-in X.509 certificates [    0.751639] zswap: loaded using pool lzo/zbud [    0.752129] Key type ._fscrypt registered [    0.752484] Key type .fscrypt registered [    0.752828] Key type fscrypt-provisioning registered [    0.753346] Key type big_key registered [    0.755534] Key type encrypted registered [    0.775605] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [    0.778112] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:54:33 UTC (1358499273) [    0.779347] ALSA device list: [    0.779613]   No soundcards found. [    0.780063] ttyS2 - failed to request DMA [    0.780478] md: Waiting for all devices to be available before autodetect [    0.781085] md: If you don't use raid, use raid=noautodetect [    0.781975] md: Autodetecting RAID arrays. [    0.782336] md: autorun ... [    0.782582] md: ... autorun DONE. [    0.782898] Waiting for root device /dev/mmcblk1p3... [    0.791904] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [    0.792623] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [    0.793248] usb 1-1: Product: USB 2.0 Hub [    0.794111] hub 1-1:1.0: USB hub found [    0.794648] hub 1-1:1.0: 4 ports detected [    0.827562] mmc2: Command Queue Engine enabled [    0.827977] mmc2: new HS400 Enhanced strobe MMC card at address 0001 [    0.829172] mmcblk2: mmc2:0001 SLD32G 28.9 GiB [    0.829771] mmcblk2boot0: mmc2:0001 SLD32G partition 1 4.00 MiB [    0.830489] mmcblk2boot1: mmc2:0001 SLD32G partition 2 4.00 MiB [    0.831288] mmcblk2rpmb: mmc2:0001 SLD32G partition 3 4.00 MiB, chardev (238:0) [    0.835833] GPT:Primary header thinks Alt. header is not at the end of the disk. [    0.836484] GPT:8708252 != 60620799 [    0.836791] GPT:Alternate GPT header not at the end of the disk. [    0.837317] GPT:8708252 != 60620799 [    0.837625] GPT: Use GNU Parted to correct GPT errors. [    0.838117]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 [    0.922262] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 223 [    0.931807] mmc0: new ultra high speed SDR104 SDIO card at address 0001 [    0.960838] usb 7-1: new high-speed USB device number 2 using xhci-hcd [    1.005384] usb 7-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54 [    1.006114] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    1.006741] usb 7-1: Product: USB2.1 Hub [    1.007089] usb 7-1: Manufacturer: GenesysLogic [    1.065065] hub 7-1:1.0: USB hub found [    1.065725] hub 7-1:1.0: 4 ports detected [    1.151632] usb 8-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [    1.185000] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54 [    1.185744] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    1.186380] usb 8-1: Product: USB3.1 Hub [    1.186736] usb 8-1: Manufacturer: GenesysLogic [    1.209314] hub 8-1:1.0: USB hub found [    1.210021] hub 8-1:1.0: 4 ports detected [    1.210715] usb 4-1: new full-speed USB device number 2 using ohci-platform [    1.210900] usb 1-1.1: new low-speed USB device number 3 using ehci-platform [    1.400901] usb 7-1.3: new low-speed USB device number 3 using xhci-hcd [    1.468993] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08 [    1.469742] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [    1.470389] usb 1-1.1: Product: Dell KB216 Wired Keyboard [    1.475747] usb 4-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice= 1.34 [    1.476565] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    1.478371] input: Dell KB216 Wired Keyboard as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input0 [    1.542843] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input0 [    1.550574] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input1 [    1.555736] usb 7-1.3: New USB device found, idVendor=03f0, idProduct=0941, bcdDevice= 1.00 [    1.556494] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    1.557144] usb 7-1.3: Product: HP X500 USB Optical Mouse [    1.557628] usb 7-1.3: Manufacturer: PixArt [    1.613374] input: PixArt HP X500 USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:03F0:0941.00033 [    1.622065] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input2 [    1.623308] hid-generic 0003:03F0:0941.0003: input,hidraw1: USB HID v1.11 Mouse [PixArt HP X500 USB Optical Mouse] on usb-xhci-hcd.1.auto-1.3/input0 [    1.624641] hid-generic 0003:413C:2113.0002: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fe380000.usb-1.1/input1 [    1.741027] usb 7-1.4: new high-speed USB device number 4 using xhci-hcd [    1.771688] usb 7-1.4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00 [    1.772446] usb 7-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [    1.773097] usb 7-1.4: Product: 802.11n NIC [    1.773476] usb 7-1.4: Manufacturer: Realtek [    1.773861] usb 7-1.4: SerialNumber: 00E04C0001 [    1.820856] usb 1-1.2: new full-speed USB device number 4 using ehci-platform [    2.075586] usb 1-1.2: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00 [    2.076335] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    2.076984] usb 1-1.2: Product: USB Audio Device [    2.077398] usb 1-1.2: Manufacturer: C-Media Electronics Inc. [    2.081956] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/fe380000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:0D8C:0014.0004/input/input4 [    2.152447] hid-generic 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-fe380000.usb-1.2/input3 [    7.580926] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_DCP_CHARGER [   82.120874] random: crng init done
That's very odd/interesting!
However, when I check the image in GParted, there is no error regarding a GPT header that's not correct...
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 19,001 06-22-2020, 06:23 AM
  Panfrost and CrOS tophneal 2 8,184 04-20-2020, 12:23 PM
