Last update broke netflix
I just did the last update and it broke netflix, which stops now every 5 seconds or less.
Reinstalling the patch did not solve anything.
For the rest everything seems working fine but as I missed the forum news for more than a month I wonder if i missed some patch or update and that is the reason why this is happening.
MrFixit or OS update?
(02-25-2020, 05:07 AM)Tazdevl Wrote: MrFixit or OS update?
I did an os update with the script. Netflix did not work well any longer
Than i tried the script for netflix, just in case, but nothing changed.
then i did a apt-get update/upgrade also. Same result.
It looks like the buffer allocated/used got so small that Netflix does not manage any longer to work without continuous stuttering.
  Locked out after update Shylocked 5 5,930 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,898 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,379 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,261 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,909 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,588 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,897 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,485 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,665 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,171 10-19-2021, 01:57 AM
Last Post: j4n3z
