Battery problem solution?
So far, we have learned how to switch the modem on via terminal commands to enable phone calls and texting.
However, it seems that the phone battery drains very quickly when this is on. Somebody mentioned power management to be developed.
Here is something else that occured to me:
On my Android phone, making phone calls and using mobile data are two very different things. Phone calls/texting is always on if I have a sim card inserted, but mobile data can be switched on and off. If it is on, it drains the Android phone battery just as badly as my Pinephone.
Can these 2 functions be separated on the Pinephone as well?
At the moment, my notification area (in Postmarket OS) shows 3 symbols:
- phone signal strength (vertical bars)
- 4G (mobile data)
- Wifi signal strength (scope bars)
If I was able to switch "4G" off but keep the other two going, I am sure it would improve battery life.
Is there any terminal command that can do that?
The underlying method will be the AT commands, but doing it that way may cause confusion on the higher level interfaces. At the top you've got NetworkManager / ModemManager, or connman, depending on distro. In between those and the AT commands you have Ofono. These should be able to turn off the mobile data while leaving the voice/text interface on. I'd hope that would reduce power consumption, but it depends what's going on inside the modem firmware.
  Battery life improvement freelectro 11 13,233 09-14-2026, 08:53 AM
Last Post: Juergen
  Battery connector dead mdk 5 5,455 01-15-2026, 02:24 PM
Last Post: mikeb
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,074 02-05-2025, 02:30 AM
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,003 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,432 02-17-2024, 04:15 PM
Last Post: vortex
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,632 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 13,976 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,893 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 53,614 02-26-2022, 02:07 AM
Last Post: vusra
  Pinephone time goes too slow (not a 2115 year problem) grwlf 1 3,742 02-06-2022, 05:05 AM
Last Post: grwlf
