Best location for adhesive wifi antennas with NAS case
Hi, I have just received my NAS case. Even if I do not need it now, in the future I'd like to have wifi support, so I have also bought the wifi module.
- Is it possible to use WIFI with the supplied adhesive antennas (at short range) or do you always need external antennas with the metal case?
- If it is possible to use the supplied adhesive antennas, how would you fit them in the NAS case? Not sticking them? Sticking them to what?
Thanks!
(02-17-2020, 05:49 AM)callegar Wrote: Hi, I have just received my NAS case. Even if I do not need it now, in the future I'd like to have wifi support, so I have also bought the wifi module.
Thanks!
Better using external rubber antenna. You can use the supply antenna and just don't stick to NAS metal case.
  AW-CM256SM wifi card mtek 4 10,955 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 21,053 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 7,940 07-20-2022, 03:31 AM
Last Post: imianz
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,583 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 3,005 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 4,893 12-04-2021, 05:14 AM
Last Post: Goffi
  To Wifi or To Bluetooth, That is the Question WarpLover 0 3,282 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 6,493 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 8,980 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 3,473 01-09-2021, 05:24 PM
Last Post: kuleszdl
