Step By Step How To Install Ubuntu Image
(04-16-2016, 04:28 AM)damikeh Wrote:
(04-15-2016, 10:51 PM)ztoti Wrote: Hi there,
I've installed Ubuntu, expand the SD card, installed desktop environment, all success.
The issue is that I don't know how to start GUI. I tried startx, ctrl+alt+F7...doesn't work.
Any solution for it?
Oh yes - I have no experience with Linux
Hi ztoti,
https://www.youtube.com/watch?v=mGBSGaGteAc here is a video
For my MATE desktop testing, once the MATE desktop downloaded, which took around 10-12mins, I just started it with startx - was there any errors in the download? what error (if any) does startx display?
dm
I followed your guide, and tried to expand the disk using sudo, I thought it worked.. I think did a sudo on the install mate script, and there was tons of 404 errors, but it seemed to download and install.. however I tried startx and it didn't run.. I can't tell if I was supposed to go to a different directory or what.. also after the mate install, I issued a reboot command, it hung on restart with some errors around devices not being attached or something.. not sure.. could you please detail out the mate install?
I don't mind reimaging the sd card if I need to that only took a few minutes.. So close to having this up and running yet so far.. lol this thing seems way faster then my B+ pi..
thanks for your help by the way!
(04-18-2016, 12:39 AM)PDXMike Wrote: I followed your guide, and tried to expand the disk using sudo, I thought it worked.. I think did a sudo on the install mate script, and there was tons of 404 errors, but it seemed to download and install.. however I tried startx and it didn't run.. I can't tell if I was supposed to go to a different directory or what.. also after the mate install, I issued a reboot command, it hung on restart with some errors around devices not being attached or something.. not sure.. could you please detail out the mate install?
Same! I am trying startx and it says command not found.
Can you upload a video for Ubuntu installation? I am e newbie in Linux side and I want to use Ubuntu as a desktop like PC. If I understand correctly above, that I will not get a desktop environment at first opening right? I will need another installation and then will get a virtual desktop?
(04-18-2016, 06:35 AM)hayrikaya Wrote:
(04-12-2016, 12:18 PM)damikeh Wrote: Steps to install Ubuntu
I am using a Windows Desktop, so the steps covered here will show that.
Pre-Install setup
  1. Download the latest image from longsleeps folder (https://www.stdin.xyz/downloads/people/l...es/ubuntu/)
  2. Download Win32Imager (https://sourceforge.net/projects/win32di...t/download)
  3. Have some kind of extraction capabilities (May i suggest 7zip - http://www.7-zip.org)
  4. Have a Micro SD card (and adapter to enable it to plug into a USB port) ready, at least 8GB (Class 10 if you can)
  5. Have a decent power supply (at least 2a) and shorter cables are better.
Note: Some other images that I’ve tested with (Android and RemixOS) require Phoenix Card to write the image, which isn’t covered here. Please see the other forum/wiki posts.
Setup
  1. Extract the image, and Install the Win32Imager somewhere (preferably the same folder!)
  2. Open Win32imager and write the image to the SD card (ensure you have the SD card selected!)
  3. Once the write has completed, MAKE SURE you safely remove the USB drive from the PC – not doing so may harm the write process.
  4. Remove the SD card and put in the Pine64. Ensure you only have the REQUIRED peripherals connected, Keyboard, HDMI, and I would say LAN too, THEN connect the power.
  5. Let the Pine64 boot. When completed, use username: ubuntu and password: ubuntu to login; it’s also worth mentioning that once you see the login screen, you CAN ssh into the pine64 also, if you so prefer.
  6. Once logged in, run the following:  /usr/local/sbin/resize_rootfs.sh
    this will resize the / partition to fill the SD card.
  7. Profit!
Congratulations, you should now have a working system.
From here you can install MATE (for a desktop) or carry on in term mode and get using.
I would change the default password asap, and secure it with a ssh key.
If this is helpful to anyone, please let me know.
I may have a look at doing a video tomorrow if I get time, showing the steps above - if that would be helpful to anyone.
Cheers
dm
Hello, when I try to extract the iso file with Power ISO, there appears 2 options one is Fat32 (50MB) the other is Linux (7316 MB) so how will I extract this file? When I try with Winrar it gives error.
It's not a .iso file, it is a .img file. Which means it cannot be extracted. Just burn the file with Win32DiskImager to a SD card.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
Pre-Install setup
Setup
  7. Profit!
Cheers
dm
No sorry, it's an .iso file and needs to be extracted. .img file coming inside the .iso. I could extract with 7-Zip and burned to the micro sd card, but I got nothing when I have installed to the Pine64. I don't know how to fix the problem. I will try another micro sd card today, let's see if it will work this time. If not, that means the problem is about image file.
I just did this yesterday in preparation for my Pine's arrival.
I used 7-zip and unzipped the img.xz file. The result was an img file. I then used win32diskimager to write it the SD. The process went smoothly.
You should NOT try to extract from the img file. That will mess up the resulting image.
Sent from my XT1254 using Tapatalk
I initially had difficulty trying to get Mate to install. Had a few 404 errors. All I did to resolve was run sudo apt-get update. Then I was able to download the remaining files and begin installation of Mate. I am currently installing it now. If anything goes wrong with it I'll post here.
(04-19-2016, 05:00 AM)jl_678 Wrote: Hi,
Sure friend, I did not try to extract .img file. The original file downloaded from Google drive is an .iso file. I extracted it and got the .img file. And burned it to Micro SD but did not work.
Okay, sorry that was my misunderstanding then. I downloaded the image from Longsleep's repository which is linked below. Is that where you got it?
  Ubuntu server 20.04 request phi0x 2 11,305 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,811 08-30-2020, 10:35 AM
Last Post: jrronimo
  Install Telegram Desktop in KDE Neon podcastlinux 2 10,748 01-26-2020, 01:43 AM
Last Post: giga
  Kickstarter P64 with LCD, working image? MostHated 1 8,137 01-04-2020, 10:32 AM
Last Post: igorp
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,695 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,915 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,493 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,916 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 950,996 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,758 08-23-2017, 09:28 AM
Last Post: gilbertotcc
