PinePhone RTL8723CS automatic test fail and WiFi problem
I run automated tests RTL8723CS is failing.
https://wiki.pine64.org/index.php/PinePhone
If RTL8723CS is failing:
"make sure there is Wifi router around 5 meter area when perform this test, the Wifi test function sniff for SSID to determine test result during autotest. The Wifi can fail if the battery power is too low. "
I tried with battery full and charger on but still automatic tests fail and there should be Wifi signals around.
And I have not got WiFi working with Ubports or Manjaro Alpha3.
Any one else having this problem?
Any ideas how to get it to work?
Or is the HW just faulty?
(02-13-2020, 05:58 AM)surfingtux Wrote: I run automated tests RTL8723CS is failing.
I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
(02-13-2020, 04:10 PM)pjsf Wrote: I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
Earlier I had tried once to flick switches on/off and tried also to run tests when switch is off.
Now I tried multiple times but no success. Sad
Thanks for the tip. Maybe this might still help someone else.
My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
(02-19-2020, 12:11 AM)publiclewdness Wrote: My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
For EG25:
Do you have sim card inserted?
https://wiki.pine64.org/index.php/PinePh...quirements
and
discussion around that issue:
https://forum.pine64.org/showthread.php?tid=8991
  Pinephone visibly losing power while plugged in Hiraghm 9 9,010 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,703 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,944 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,988 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,674 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 8,370 02-28-2026, 04:18 PM
Last Post: baptx
Lightbulb Faster OS test deployments - Faster UART? WhiteHexagon 0 1,233 02-11-2026, 06:30 AM
Last Post: WhiteHexagon
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,647 12-04-2025, 08:07 AM
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,202 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,844 11-30-2025, 08:07 AM
