A quick tutorial on having the image work its best
(02-09-2020, 07:46 AM)kop316 Wrote:
(02-08-2020, 10:08 PM)liamsgotgenes Wrote:
(02-08-2020, 12:21 PM)kop316 Wrote: Hello,
To confirm, this seems to be different than here:
https://megous.com/dl/tmp/modem.txt
Can I ignore the link above for Ubuntu touch, or is the shutdown still essential in the aboce link?
EDIT: The script from megous does not seem to work in Ubuntu Touch.
I believe the script will only work on megous' kernel they are working on: https://xff.cz/kernels/
Note that right before the script he says "...enable the modem in my kernel..."
Makes sense. It was hard to tell if that was already in Ubuntu Touch. It sounded like it was in here and Postmarket OS.
This is not in UT yet.
Is there a way to save the modem settings without having to retype the commands upon reboot?
(02-11-2020, 02:34 PM)cow_killer Wrote: Is there a way to save the modem settings without having to retype the commands upon reboot?
Just make a bash script and if you like a desktop file so it shows up as an app (I assume ubports uses desktop files)
Better yet make an init script for whatever init system the OS is using and let that run things on start/stop. There may be something needed for suspend too, so that an incoming call or text can wake the phone.
I installed the system image of the 12th of February 2020 and now the commands:
amixer -c 0 set 'AIF1 Slot 0 Digital DAC' unmute
and similar fails with message:
amixer: Unable to find simple control 'AIF1 Slot 0 Digital DAC' and similar ones
The image of the 11th of February 2020 didn't have this problem.
(02-13-2020, 12:20 AM)ivanB1975 Wrote: I installed the system image of the 12th of February 2020 and now the commands:
That's weird because it seems that there have not been any changes committed since February 7, unless I'm misunderstanding the build history.
Same for me, unable to have any speaker working
I assume you started the line with 'sudo'?  The commands won't work without administrator privileges.
I refuse to tiptoe through life, only to arrive safely at death.
#19
I had that once, I solved it with (not sure why, but it worked):
echo "PULSE=no" > /etc/pulse/pulse.cfg
#20
how do you use this command? to me it opens a blank line with just a ">" , and then?
yes, no difference with or without sudo, in both cases the only result is a timid click coming from the speaker on the back when I tipe the first letter in the terminal, or on an app icon - but just the first letter, not the following ones
  Sound won’t work LMalilil 2 7,197 07-28-2020, 09:52 AM
Last Post: Cree
  wifi does not work - authentication problem? pphone-newbie 7 15,589 07-26-2020, 01:30 PM
Last Post: Cree
  dropdown menu doesn't work daniel 3 8,414 07-22-2020, 01:17 PM
Last Post: natasha
  Tutorial for new UBPorts CE users / list of known issues? ThatGeoGuy 2 7,931 07-21-2020, 05:54 PM
Last Post: natasha
  Image #58 Touchscreen Unresponsive BryWilson 3 9,424 06-27-2020, 02:38 AM
Last Post: Zweitaktmotor
  Does Miracast work? mercrapper 1 5,332 06-25-2020, 08:18 AM
Last Post: heng
  Image build guide? Djhg2000 3 9,872 06-18-2020, 02:04 PM
Last Post: bingo600
  Only the top few rows of pixels work on stable OTA 3 NoraCodes 0 3,521 06-18-2020, 09:18 AM
Last Post: NoraCodes
  Battery issues with latest image ashley123 6 14,394 06-14-2020, 11:06 AM
Last Post: KeithMcN
  Ubports OTA won't work on my braveheart none 12 25,225 06-13-2020, 03:23 AM
Last Post: tsar_chasm
