pmboostrap to emmc
In order to install PostmarketOS on EMMC, Pinephone page on postmarketos' wiki instruct to run the following :
pmbootstrap install --sdcard=/dev/mmcblk(...)
I currently run postmarketOS from SD card (not the demo image, but current release), and still have stock test image on EMMC. The partitions looks as follow :
sudo ls /dev/mmcblk* /dev/mmcblk0    /dev/mmcblk0p2    /dev/mmcblk2boot0  /dev/mmcblk2p1 /dev/mmcblk0p1    /dev/mmcblk2    /dev/mmcblk2boot1  /dev/mmcblk2p2
when I try to run :
I get the following error :
.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home (006470) [10:30:29] NOTE: (1/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (2/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (3/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (4/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (5/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (6/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (7/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (8/20) failed to find the install partition. Retrying... (006470) [10:30:29] NOTE: (9/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (10/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (11/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (12/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (13/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (14/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (15/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (16/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (17/20) failed to find the install partition. Retrying... (006470) [10:30:30] NOTE: (18/20) failed to find the install partition. Retrying... (006470) [10:30:31] NOTE: (19/20) failed to find the install partition. Retrying... (006470) [10:30:31] NOTE: (20/20) failed to find the install partition. Retrying... (006470) [10:30:31] ERROR: Unable to find the partition prefix, expected the first partition of /dev/mmcblk1 to be located at /dev/mmcblk11 or /dev/mmcblk1p1! (006470) [10:30:31] See also: <https://postmarketos.org/troubleshooting> (006470) [10:30:31] Traceback (most recent call last):  File "/usr/lib/python3.8/site-packages/pmb/__init__.py", line 63, in main    getattr(frontend, args.action)(args)  File "/usr/lib/python3.8/site-packages/pmb/helpers/frontend.py", line 196, in install    pmb.install.install(args)  File "/usr/lib/python3.8/site-packages/pmb/install/_install.py", line 547, in install    install_system_image(args)  File "/usr/lib/python3.8/site-packages/pmb/install/_install.py", line 397, in install_system_image    pmb.install.partitions_mount(args)  File "/usr/lib/python3.8/site-packages/pmb/install/partition.py", line 49, in partitions_mount    raise RuntimeError("Unable to find the partition prefix," RuntimeError: Unable to find the partition prefix, expected the first partition of /dev/mmcblk1 to be located at /dev/mmcblk11 or /dev/mmcblk1p1!
Now, if I try :
pmbootstrap install --sdcard=/dev/mmcblk0
or
pmbootstrap install --sdcard=/dev/mmcblk1
or
pmbootstrap install --sdcard=/dev/mmcblk2
I got this error:
(006763) [10:42:19] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/dev (006763) [10:42:19] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone 1711869952    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone (006763) [10:42:19] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot 53035008    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot (006763) [10:42:19] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home 8192    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home (006763) [10:42:19] % sudo touch /home/laurent/.local/var/pmbootstrap/chroot_native/dev/installp1 (006763) [10:42:19] % sudo mount --bind /dev/mmcblk0p1 /home/laurent/.local/var/pmbootstrap/chroot_native/dev/installp1 (006763) [10:42:19] % sudo touch /home/laurent/.local/var/pmbootstrap/chroot_native/dev/installp2 (006763) [10:42:19] % sudo mount --bind /dev/mmcblk0p2 /home/laurent/.local/var/pmbootstrap/chroot_native/dev/installp2 (006763) [10:42:19] (native) mount /dev/installp2 to /mnt/install (006763) [10:42:19] (native) % mkdir -p /mnt/install (006763) [10:42:19] (native) % mount /dev/installp2 /mnt/install (006763) [10:42:19] (native) format /dev/installp1 (boot, ext2), mount to /mnt/install/boot (006763) [10:42:19] (native) % mkfs.ext2 -F -q -L pmOS_boot /dev/installp1 /dev/installp1 is apparently in use by the system; will not make a filesystem here! (006763) [10:42:20] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ (006763) [10:42:20] NOTE: The failed command's output is above the ^^^ line in the log file: /home/laurent/.local/var/pmbootstrap/log.txt (006763) [10:42:20] ERROR: Command failed: (native) % mkfs.ext2 -F -q -L pmOS_boot /dev/installp1 (006763) [10:42:20] See also: <https://postmarketos.org/troubleshooting> (006763) [10:42:20] Traceback (most recent call last):   File "/usr/lib/python3.8/site-packages/pmb/__init__.py", line 63, in main     getattr(frontend, args.action)(args)   File "/usr/lib/python3.8/site-packages/pmb/helpers/frontend.py", line 196, in install     pmb.install.install(args)   File "/usr/lib/python3.8/site-packages/pmb/install/_install.py", line 547, in install     install_system_image(args)   File "/usr/lib/python3.8/site-packages/pmb/install/_install.py", line 407, in install_system_image     pmb.install.format(args)   File "/usr/lib/python3.8/site-packages/pmb/install/format.py", line 94, in format     format_and_mount_boot(args)   File "/usr/lib/python3.8/site-packages/pmb/install/format.py", line 35, in format_and_mount_boot     pmb.chroot.root(args, ["mkfs.ext2", "-F", "-q", "-L", "pmOS_boot", device])   File "/usr/lib/python3.8/site-packages/pmb/chroot/root.py", line 90, in root     return pmb.helpers.run_core.core(args, msg, cmd_sudo, None, output,   File "/usr/lib/python3.8/site-packages/pmb/helpers/run_core.py", line 301, in core     raise RuntimeError("Command failed: " + log_message) RuntimeError: Command failed: (native) % mkfs.ext2 -F -q -L pmOS_boot /dev/installp1
if i try :
pmbootstrap install --sdcard=/dev/mmcblk0p1
I got this error :
(007060) [10:47:53] *** (3/5) PREPARE INSTALL BLOCKDEVICE *** (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_native/mnt/install (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/var/cache/distfiles (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/var/cache/apk (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/proc (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-rust (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-packages (007060) [10:47:53] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-git (007060) [10:47:54] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-ccache (007060) [10:47:54] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-abuild-config (007060) [10:47:54] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/etc/apk/keys (007060) [10:47:54] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/dev/shm (007060) [10:47:54] % sudo umount /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/dev (007060) [10:47:54] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone 1711869952    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone (007060) [10:47:54] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot 53035008    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot (007060) [10:47:54] % sudo du --summarize --block-size=1 /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home 8192    /home/laurent/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home (007060) [10:47:54] NOTE: (1/20) failed to find the install partition. Retrying... (007060) [10:47:54] NOTE: (2/20) failed to find the install partition. Retrying... (007060) [10:47:54] NOTE: (3/20) failed to find the install partition. Retrying... (007060) [10:47:54] NOTE: (4/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (5/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (6/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (7/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (8/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (9/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (10/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (11/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (12/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (13/20) failed to find the install partition. Retrying... (007060) [10:47:55] NOTE: (14/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (15/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (16/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (17/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (18/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (19/20) failed to find the install partition. Retrying... (007060) [10:47:56] NOTE: (20/20) failed to find the install partition. Retrying... (007060) [10:47:56] ERROR: Unable to find the partition prefix, expected the first partition of /dev/mmcblk0p1 to be located at /dev/mmcblk0p11 or /dev/mmcblk0p1p1!
Does anyone know which command I should run to install on EMMC ?
* PinePhone BraveHeart Edition
SOLVED IN MY CASE: TOP TIP FROM Funeral_Chris ON IRC TO FORMAT THE eMMC FIRST TO CLEAR THE FACTORY IMAGE.
I have also just failed to install to eMMC.
My Brave Heart has booted pmOS/phosh from SDcard fine.
I have pmbootstrap setup fine on the phosh installation.
AFAIK emmc appears as /dev/mmcblk2
Everything runs fine with pmbootstrap until the actual copy to eMMC
$ pmbootstrap install --sdcard /dev/mmcblk2 ... (003064) [10:28:16] *** (3/5) PREPARE INSTALL BLOCKDEVICE *** (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/var/cache/distfiles (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/var/cache/apk (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/proc (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-rust (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-packages (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-git (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-ccache (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/mnt/pmbootstrap-abuild-config (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/etc/apk/keys (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/dev/shm (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/dev (003064) [10:28:16] % sudo du --summarize --block-size=1 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone 1075089408 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone (003064) [10:28:16] % sudo du --summarize --block-size=1 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot 46227456 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/boot (003064) [10:28:16] % sudo du --summarize --block-size=1 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home 8192 /home/chris/.local/var/pmbootstrap/chroot_rootfs_pine64-pinephone/home (003064) [10:28:16] (native) mount /dev/install (host: /dev/mmcblk2) (003064) [10:28:16] % sudo touch /home/chris/.local/var/pmbootstrap/chroot_native/dev/install (003064) [10:28:16] % sudo mount --bind /dev/mmcblk2 /home/chris/.local/var/pmbootstrap/chroot_native/dev/install (003064) [10:28:16] % sudo touch /home/chris/.local/var/pmbootstrap/chroot_native/dev/sdcardp1 (003064) [10:28:16] % sudo mount --bind /dev/mmcblk2p1 /home/chris/.local/var/pmbootstrap/chroot_native/dev/sdcardp1 (003064) [10:28:16] (native) % blkid -s LABEL -o value /dev/sdcardp1 /dev/sdcardp1: LABEL="pmOS_boot" UUID="e1c1b6b8-94f9-4b91-9438-3f4aea445694" TYPE="ext2" (003064) [10:28:16] % sudo umount /home/chris/.local/var/pmbootstrap/chroot_native/dev/sdcardp1 [10:28:16] WARNING: This device has a previous installation of pmOS. CONTINUE? (y/n) [n] y (003064) [10:28:22] (native) partition /dev/install (boot: 69M, root: the rest) (003064) [10:28:22] (native) % parted -s /dev/install mktable msdos (003064) [10:28:22] (native) % parted -s /dev/install mkpart primary ext2 2048s 69M (003064) [10:28:22] (native) % parted -s /dev/install mkpart primary 69M 100% (003064) [10:28:22] (native) % parted -s /dev/install set 1 boot on (003064) [10:28:22] % sudo touch /home/chris/.local/var/pmbootstrap/chroot_native/dev/installp1 (003064) [10:28:22] % sudo mount --bind /dev/mmcblk2p1 /home/chris/.local/var/pmbootstrap/chroot_native/dev/installp1 (003064) [10:28:22] % sudo touch /home/chris/.local/var/pmbootstrap/chroot_native/dev/installp2 (003064) [10:28:22] % sudo mount --bind /dev/mmcblk2p2 /home/chris/.local/var/pmbootstrap/chroot_native/dev/installp2 (003064) [10:28:22] (native) format /dev/installp2 (003064) [10:28:22] (native) % mkfs.ext4 -O ^metadata_csum -F -q -L pmOS_root /dev/installp2 /dev/installp2 is apparently in use by the system; will not make a filesystem here! (003064) [10:28:22] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ (003064) [10:28:22] NOTE: The failed command's output is above the ^^^ line in the log file: /home/chris/.local/var/pmbootstrap/log.txt
Any suggestions how to get mkfs to overcome its inhibitions?
I managed to install PostmarketOS to my pinephones emmc by booting Manjaro from the SD Card and running pmbootstrap from there.
I think as the factory test is also Postmarket os any installation running from the SD card will mount the emmc partitions as they have the pmos_* labels as well.
(02-17-2020, 04:55 AM)hk135 Wrote: I managed to install PostmarketOS to my pinephones emmc by booting Manjaro from the SD Card  and running pmbootstrap from there.
Thanks a lot ! I runned this from Manjaro :
pmbootstrap install --sdcard mmcblk2
and it worked !
Mine worked with `pmbootstrap install --sdcard=/dev/mmcblk0` on Ubuntu 20.04.
Make sure not to add the extra `p1` at the end - `mmcblk0p1`
What might be easier nowadays is just using JumpDrive to make the eMMC show up as writeable storage on your PC and just run pmbootstrap on your pc.
  phone won't boot from emmc with sdcard inserted ssilvi 3 7,622 06-06-2021, 02:47 AM
Last Post: ssilvi
  eMMC Partitioning/Formatting Izzet 3 7,587 01-12-2021, 03:57 PM
Last Post: Izzet
  Cannot find a method of flashing to EMMC that works MarkF 4 10,567 10-30-2020, 09:06 PM
Last Post: discogribbs
