Default OS update log
(02-07-2020, 04:26 PM)ac8dg Wrote: In addition to using /usr/bin/mrfixit_update.sh ,
what are the recommended repositories to use for apt update  ?
I have deb and deb-src for these
http://http.debian.net/debian  stretch non-free contrib main
http://security.debian.org/debian  stretch/updates non-free contrib main
http://http.debian.net/debian  stretch/updates non-free contrib main
http.debian.net should be replaced with deb.debian.org (unless you don't want to download via Fastly).
You need the deb-src only for obtaining the source for the packages (for re-compiling, hacking, whatever), so feel free to comment them out for "regular" use.
I'm pretty sure that second entry should be http://security.debian.org/ NOT http://security.debian.org/debian
I did an update today, it downloaded and installed all the 4.4.213 files,,,, BUT
when I type uname -a nothing has changed (after a shutdown)
Is there some trick?
uname -a
Linux Debian-Desktop 4.4.210 #1 SMP Tue Jan 14 22:28:43
OOps,, my screw-up, disregard (had card in sd slot, made boot confused)
(02-08-2020, 12:10 PM)rleasle Wrote: I'm pretty sure that second entry should be    http://security.debian.org/   NOT   http://security.debian.org/debian
According to https://www.debian.org/security it should be:
deb http://security.debian.org/debian-security stretch/updates main contrib non-free
It currently also works without the "/debian-security" part though it might be disabled at some point (e.g. when stretch is not supported by the Debian Security Team anymore).
On the "video hardware codec" thread I was discussing why my standard Debian installation is missing the h264_rkmpp codec. Downloading the latest default Debian image reveals, that the the ffmpeg executable differs from the one on my pbp. I've got mine in November and I am doing regularly "apt-get update", "apt-get upgrade". I assume, installing upstream packages breaks mrfixit2001's modifications.
Can this be true?
If so, is there a way to keep my system up to date without losing mrfilxit2001's modifications?
Regularly wiping the emmc with the newest image is no solution to me, as I've already done a lot of mods to the system.
I don't know how others "lost" their modified FFMPEG, but mine is prevented from updating;
# apt-get upgrade Reading package lists... Done Building dependency tree       Reading state information... Done Calculating upgrade... Done The following packages have been kept back:  ffmpeg The following packages will be upgraded: ...
I made no changes to the packages. Checking, FFMPEG still has "--enable-rkmpp".
Arwen Evenstar
Princess of Rivendale
(02-10-2020, 11:14 AM)Arwen Wrote: I don't know how others "lost" their modified FFMPEG, but mine is prevented from updating;
I know. It's aptitude!
Just tested it on my sd card image. apt-get shows ffmpeg as being held back. aptitude fetches the package and installs it.
aptitude also breaks ffmpeg. After the upgrade, neither the new nor the modified ffmpeg work:
ffmpeg.org: error while loading shared libraries: libavdevice.so.58: cannot open shared object file: No such file or directory
It's probably because 'aptitude upgrade' does the equivalent of 'apt-get upgrade --with-new-pkgs'.
If you want to 'hold' a package use
echo 'package_name hold' > dpkg --set-selections
or configure a pin.
or configure a pin.
dpkg --get-selections showed ffmpeg on hold.
aptitude doesn't care about this.
I just double checked that.
The latest update seems to have made the bluetooth stack more unstable. I have a pair of Taotronics TT-BH22, which are bluetooth noise-cancelling headphones, which is what I'm testing with.
Prior to the last update, things were a bit finicky, but could be worked around:
- If the PBP had never been put to sleep, then they could connect and work fine.
- If the PBP had ever been put to sleep, then they would connect over bluetooth, but after ~4 minutes the connection would time out and die. The bluetooth would stop working, so typically I'd switch to plugged in mode (i.e., use the audio jack) and keep going--or just reboot.
Since the latest update:
- It doesn't matter if the PBP has been put to sleep; the bluetooth stack times out after ~4 minutes. On top of that, the "Bluetooth Devices" applet stops responding. And after ~2 more minutes, the entire UI locks up, requiring a system reboot.
Anyone else seeing weird issues with bluetooth after the latest PBP update?
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,317 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,083 10-19-2021, 01:57 AM
Last Post: j4n3z
