Lock screen problem?
Hey, having a bit of an issue. I got Sailfish installed and up to a point where the screen is locked and there are arrows pointing out from the sides implying I should swipe. But nothing happens with swipe sideways. The swipe up and down works as expected. Anyone know what's going on?
Does it persist after a reboot? I have not encountered that problem so far.
(02-07-2020, 07:56 AM)Nooblife Wrote: Does it persist after a reboot? I have not encountered that problem so far.
Yeah, I tried rebooting. I suppose I will try to flash again.
I don't know what's going on. It complains something about lima gpu IRQ so it sounds pretty serious. The weird thing is that I did nothing strange with the install. The only "option" I selected was the question about is my device a pinephone, tablet or dont do evil, to which I answered pinephone.
Aha! I tried again and this time it worked out. I think what happened before was that I interrupted the installation somehow. This time the screen went black at some point when it was setting up the account, and instead of pressing any buttons, I waited.
the problem persists when there is low light. its a bug of the light sensor. Try to hold your phone in the bright light and it will work.
  Infinite Loading Screen syrinx 2 6,420 11-30-2020, 11:11 AM
Last Post: syrinx
  Sailfish install problem. pjsf 15 31,014 07-10-2020, 09:15 AM
Last Post: afigegoznaet
Bug For those having issues with the screen turning off wesleyorama 5 11,699 03-04-2020, 06:57 PM
Last Post: pinerokc
