Devuan Appear to Work
(02-01-2020, 12:18 PM)Zachir999 Wrote:
(02-01-2020, 11:56 AM)rleasle Wrote: I got networking to work with just wpa_supplicant and no NetworkManager or wicd (probably not the right way, but it works for this experiment).  Moved on to purging systemd, updated sources.list, did an apt-get update/upgrade.
When I tried to install a DE, got a conflict installing the elogind package (dependency for lots of stuff) and the udev package.
Not sure if I should give up, start over, or try something radical with apt-get.
# apt-get install elogind
Reading package lists... Done
Building dependency tree
Reading state information... Done
Recommended packages:
 policykit-1
The following NEW packages will be installed:
 elogind
0 upgraded, 1 newly installed, 0 to remove and 7 not upgraded.
3 not fully installed or removed.
Need to get 0 B/471 kB of archives.
After this operation, 1668 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
 elogind
Authentication warning overridden.
(Reading database ... 83889 files and directories currently installed.)
Preparing to unpack .../elogind_234.4-2_armhf.deb ...
Unpacking elogind (234.4-2) ...
dpkg: error processing archive /var/cache/apt/archives/elogind_234.4-2_armhf.deb (--unpack):
trying to overwrite '/lib/udev/rules.d/70-power-switch.rules', which is also in package udev 232-25+deb9u11
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Which DE did you try to install? I installed MATE and had no issues, I can take a look when I get another SD card.
I tried both MATE and xfce. Same conflict.
Based on the message, it looks like something between udev and elogind. I'll look into it later tonight hopefully, but if it's not a critical install I would recommend trying eudev instead of udev. I wish I had more time to look into this sooner.
I managed to get everything working by creating a modified version of the package in question (elogind) with the conflicting file removed. Now I just need to test the full install
(02-03-2020, 08:40 AM)rleasle Wrote: I managed to get everything working by creating a modified version of the package in question (elogind) with the conflicting file removed. Now I just need to test the full install
I just checked, and yes, you need to install the package eudev, and I just tried installing elogind and it didn't have any problems. I will update my tutorial.
Curious. Could have sworn I saw the eudev package installed during my conversion process.
would debootstrap work and you could just modify danielt's installer instead?
Debootstrap would probably work... I was focused more on migrating the default Debian, but I see no reason for it not to. I'll have to give it a shot
(02-04-2020, 08:17 AM)rleasle Wrote: Curious. Could have sworn I saw the eudev package installed during my conversion process.
It was installed for me, which means you can uninstall udev and get rid of the conflict with elogind
Users browsing this thread: 7 Guest(s)
