Default OS update log
hi all after the latest update 17.01.2020
having problems with chromium it lags
glxgears test shows
$ glxgears
LIBGL: Initialising gl4es
LIBGL: v1.1.1 built on Mar 10 2019 13:15:04
LIBGL: Using GLES 2.0 backend
LIBGL: loaded: libbrcmGLESv2.so
LIBGL: loaded: libbrcmEGL.so
ERROR: The DDK is not compatible with any of the Mali GPUs on the system.
The DDK was built for 0x860 r2p0 status range [0..15], but none of the GPUs matched:
LIBGL: Error while gathering supported extension (eglInitialize: EGL_NOT_INITIALIZED), default to none
LIBGL: Targeting OpenGL 2.0
LIBGL: glX Will try to recycle EGL Surface
LIBGL: Current folder is:/home/tso4ev
LIBGL: ERROR: EGL Error detected: EGL_NOT_INITIALIZED
LIBGL: Unable to initialize EGL display.
LIBGL: Unable to initialize EGL.
LIBGL: Unable to init EGL.
Error: glXCreateContext failed
no 3d game will run any fix ?
  @Luke,
  Are these updates all separate from each other ?
If I miss a few or if I download a fresh installation,
        will I need to do 4 separate updates,   if I have missed 4 of them ?
OR will they automatically just determine and download the needed updates ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-18-2020, 03:10 PM)bcnaz Wrote: OR will they automatically just determine and download the needed updates ?
The update script checks for dependencies, so I would just run it from the button on the menu bar, then reboot, and run it again.  It should tell you that it is up to date.
Thanks, I was a bit worried that it may only do the latest download, then perhaps miss an important update from the interim ?
( Say I missed numbers 5, 6, 7 updates, . it could possibly just go to update number 7 ? )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-18-2020, 06:56 AM)tso4ev Wrote: hi all after the latest update  17.01.2020
glxgears test shows
$ glxgears
Yea, I had the 3D break on me too.
sudo nano /usr/bin/mrfixit_update.sh
edit:
curver="1.8"
Downgrade and reboot.
Then, remove the variable for version and upgrade again - it'll work.
I did clean install flash the image on sd card and then from the sd card I flsashed the emmc
(01-18-2020, 03:10 PM)bcnaz Wrote:   @Luke,
Nope, the newest one incorporates all previous updates Smile
Can anyone help the Linux noob here change the home directory name since this command is simply stating "no changes made" and I'm clueless as to how to do this.
usermod -d /home/rock -m NewUser
Thanks!
(01-20-2020, 12:14 PM)Envision Wrote: Can anyone help the Linux noob here change the home directory name since this command is simply stating "no changes made" and I'm clueless as to how to do this.
Thanks!
I've fixed that instruction;
usermod -l NewUser -d /home/NewUser -m rock
Now if you have already changed the user's name to something other than "rock", it would be something like this;
usermod -d /home/NewUser -m NewUser
Arwen Evenstar
Princess of Rivendale
Thanks!
Thank you so much!! Worked like a charm!  Big Grin
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,316 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,082 10-19-2021, 01:57 AM
Last Post: j4n3z
