Default OS update log
(12-24-2019, 11:46 AM)Luke Wrote:
(12-23-2019, 09:43 AM)e-minguez Wrote:
(12-23-2019, 09:32 AM)Luke Wrote:
(12-23-2019, 09:11 AM)brent.thierens Wrote: Will this find its way to Ubuntu and Manjaro as well, or is this just something we'll have to do ourselves?
Happy to share the relevant flags with whomever wants of course.
There is a 'software tuning' section in the wiki here https://wiki.pine64.org/index.php/Pinebo...ning_guide (kudos to @Arwen for starting it) where anyone can add the tweaks Big Grin
Thanks!
Edit: Is this file the one you mention @Luke https://github.com/mrfixit2001/updates_r...em/default ?
Yes! Those are the Chromium flags Smile
Where should we put these flags?
Thanks!
Those flags are to be used when running the chromium binary. You can either modify the launcher (~/.local/share/applications/ in gnome) or launch the browser via a script with those flags.
I've modified the wiki to add them https://wiki.pine64.org/index.php/Pinebo...mium_flags
Are the sources of latest kernel available?
cat /proc/version reports "Linux version 4.4.207".
I only found the following repo: https://github.com/mrfixit2001/rockchip-kernel.git
But it only contains sources for kernels up to linux version 4.4.206.
(12-08-2019, 05:24 AM)tuxor Wrote: I have to take it back, suspend stopped working on my Pinebook again.
Getting the same error as before, that there's a wake up call detected.
... [ 3150.735479] dpm_run_callback(): platform_pm_suspend+0x0/0x64 returns -110 [ 3150.735486] PM: Device xhci-hcd.3.auto failed to suspend: error -110 [ 3150.735491] PM: Some devices failed to suspend, or early wake event detected [ 3150.878334] PM: suspend exit 2019-12-08 11:14:16.061040883 UTC ...
That flaky behavior gets quite annoying to be honest. Where's the problem?
(12-10-2019, 11:49 PM)bigCamel Wrote:
(12-10-2019, 04:00 PM)sjk Wrote:
(12-10-2019, 03:06 PM)Luke Wrote: @sjk what happens if you press Fn+ESC?
I get the suspend/shutdown dialog, and click suspend. It then blinks and wakes up.
I see the same behaviour on my PBP.
Is there any update on the suspend issue?
(08-30-2019, 02:21 AM)Luke Wrote: Update 30/08/219
*Changed boot sequence giving SD priority
Notes: This is an important update - uboot got patched to look for extlinux in /boot partition on SD card before booting off of eMMC. This means that SD now has boot priority on the Pinebook Pro, allowing you to try out builds without Commiting as well as easy flashing (dd) of eMMC from a SD booted OS.
I ran the update but my Pinebook Pro will still not boot from micro SD.
Hello? I have heard no update on this for a while. While not affecting everyone, there are a few of us that are having this issue.
Any News as to why a 'few' of the stock Debian/Mate PBP's are having sound issues ?
NO sound out of the box, with a terminal mod to alsamixer from default to es sound gives sound only in rock, and only partial function at that.
Options are grayed-out, sound plays from most youtube videos, and only an occasional ad will play sound....???
I tried from an SD card with identical results.
Seems most are not having this issue, just 'SOME'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-17-2020, 07:33 AM)bcnaz Wrote: Any News as to why a 'few' of the stock Debian/Mate PBP's are having sound issues  ?
No, but looking into it. Its definitely something software related ...
V 1.9 update is now available:
*Kernel update
*Newest Firefox
*Fix for sound not working in Firefox
*Added community made wallpapers as background options (in /usr/share/backgrounds)
*Added support for BT audio output
*Updated uboot
*Option to NVMe boot
*Improved USB-C dock support
@Luke can you make wallpapers available for other OS users somewhere ?
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,316 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,082 10-19-2021, 01:57 AM
Last Post: j4n3z
