Question about Ubuntu
I'm currently using the Ubuntu image of Longsleep but I'm getting these errors and it takes quiet sometime then to boot. Is this normal or a bug and is there anyway how I can fix this?
[Image: 536d0f0f37e46e9cdf8015d3f9120bb5.jpg]
Try a different SD card, looks like its having some trouble with that one. There is such a wide difference in speed and quality of SD cards, even among brand name cards, and there are many counterfeits as well so even when you think you are buying a brand name card sometimes all is not as it appears. I have a stack of 8, 16, 32s and a couple 64GBs cards that I use for testing.
Over at Armbian.com there is an effort to test out many SD cards for performance.
Currently playing around with Arduinos, CHIPs, Orange Pis, PineA64s, Raspberry Pis, etc.
(04-14-2016, 03:34 AM)DaveyDarko Wrote: Try a different SD card, looks like its having some trouble with that one. There is such a wide difference in speed and quality of SD cards, even among brand name cards, and there are many counterfeits as well so even when you think you are buying a brand name card sometimes all is not as it appears. I have a stack of 8, 16, 32s and a couple 64GBs cards that I use for testing.
I doubt it. I tried already 8 different microSD cards. From the brand Sandisk and Samsung and they are legit microSD cards. I bought them in a legit store and verified the volume. Can it have to do with those cards being Extreme modules with 80 mb/s RW ?
As long as they function within spec they should be fine I would think but occasional exceptions happen. I am using http://www.amazon.com/PNY-Turbo-Performa...ge_o08_s00 with my debian install on pine, works fine.
How long does your system takes to boot?
(04-14-2016, 01:39 AM)skardoska Wrote: I'm currently using the Ubuntu image of Longsleep but I'm getting these errors and it takes quiet sometime then to boot. Is this normal or a bug and is there anyway how I can fix this?
My Ubuntu images have Ethernet configured to use DHCP. I assume you just did not plug Ethernet. The default Ubuntu DHCP timeout is 5 minutes. So either plug Ethernet or modify the configuration in /etc/network/interfaces.d/eth0 prio booting.
The messages from your picture are normal and related to crappy drivers.
Can that become an issue if a just use CLI mode with small tasks like executing some code?
No issue.
(04-14-2016, 02:42 PM)longsleep Wrote: No issue.
What about serving some small webpages with nginx or using Docker on it?
Sure - all works.
  Issues with both Deb and Ubuntu germanshep 0 4,268 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 16,397 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 12,843 03-01-2017, 02:46 PM
Last Post: dkryder
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 7,414 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Opinion Question nebbors 3 8,771 12-14-2016, 05:30 PM
Last Post: cootcraig
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,282 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,719 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  General SBC question and Linux jkmooney 13 26,571 10-02-2016, 05:03 AM
Last Post: pfeerick
  Overclocking ubuntu mate Mixermic 2 7,751 10-01-2016, 04:36 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 10,334 09-18-2016, 02:05 PM
Last Post: brengthdom
