Triple (middle click) tap
Does anyone got this working ? Especially on Manjaro ?
What DE are you using?
(01-14-2020, 01:04 PM)tophneal Wrote: What DE are you using?
KDE
I don't recall middle click behavior while I was using KDE, but I found this that may help you enable it, if it's not.
https://forum.kde.org/viewtopic.php?f=20...44#p185338
(01-14-2020, 02:08 PM)tophneal Wrote: I don't recall middle click behavior while I was using KDE, but I found this that may help you enable it, if it's not.
Thanks - will try it tomorrow.
I can confirm middle click working under Manjaro (in Gnome), but it is not all that reliable. It also seems to work better in the lower half of the touchpad from my experience.
I cannot get it to work on KDE Sad
It could also be something a user pointed out to me when I first loaded CrOS, the multi finger taps work best when your finger tips are separated. I usually need to keep an inch to 2 distance between mine.
  Touchpad tap to click Der Geist der Maschine 0 1,255 01-19-2026, 01:38 PM
  How to middle-click with the trackpad? rillian 5 11,418 01-16-2020, 05:17 AM
