Instructions for Installing VS Code on Manjaro
Hi Guys,
I couldn't find this anywhere else so I decided to post what I did. Hope it helps. This is not the legit, fully supported VS Code so use at your own risk I guess!
git clone https://aur.archlinux.org/code-headmelted-bin.git
cd code-headmelted-bin
makepkg --install
EDIT: if you get something like:
==> ERROR: Cannot find the fakeroot binary.
==> ERROR: Cannot find the strip binary required for object file stripping.
you need to install dev tools...
sudo pacman -S base-devel
And that should be it! You can now open VS Code with command:
code-oss
Happy coding.
This short-and-sweet little bit looks like it would fit perfectly in Tutorials! (Copied/Moved.)
(12-20-2019, 03:17 PM)tophneal Wrote: This short-and-sweet little bit looks like it would fit perfectly in Tutorials! (Copied/Moved.)
Woops, I put this in Pinebook section instead of Pinebook Pro. I've only ever tried this on PBP so if you are on a Pinebook YMMV. Might need to re-move to the PBP section.
Thanks for pointing that out! Moved to PBP forums.
Or just run:
pamac build code-headmelted-bin
Via https://wiki.manjaro.org/index.php?title...line_Pamac
You guys are life savers! I would have loved to keep using sublime text but they don't give a crap about ARM Sad finally a fully featured editor that works!
I used to run this on the Pinebook without issue. No need to compile it for debian or suse users, as Jay has the binaries/repos up @ https://code.headmelted.com/
Nowadays I would probably use VSCodium, since that has arm and arm64 builds also. https://github.com/VSCodium/vscodium
ARM/ARM64 support is looking better for VSCode also in the new few months, since the C/C++ extension is looking at ARM, and then ARM64 support in the next releases... meaning VSCode + PlatformIO on ARM64 with intellisense, etc... opening up a lot of development options.
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,807 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 24,683 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,495 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,937 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,478 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,098 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 88,348 07-28-2020, 03:18 PM
Last Post: SamWilts
  Installing WPS Office on Manjaro brent.thierens 5 16,533 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 94,752 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 111,700 07-09-2020, 07:27 AM
Last Post: JtR
