Inserting MicroSD
I feel foolish for asking, but the MicroSD card won't stay in inserted.  There's no "click" and it doesn't stay inserted.  While it's manually held, I can see it's recognized as /dev/mmcblk0p1.   What obvious thing am I missing?
I just want to reflash the emmc with a distro that works.
Are you pushing it in far enough? It is rather finicky to do and I especially find it very hard if I've clipped my nails recently. I suppose one could fashion a tool to make it easier.
(12-15-2019, 05:52 PM)uidentzero Wrote: I feel foolish for asking, but the MicroSD card won't stay in inserted.  There's no "click" and it doesn't stay inserted.  While it's manually held, I can see it's recognized as /dev/mmcblk0p1.   What obvious thing am I missing?
You have to push it in completely. Just in case your slot is broken, have a pair of tweezers ready.
I have issues inserting mine almost always after recently trimming my fingernails. I'll often have to angle my thumbnail to fit the rounded notch just to get enough of a push to get it to click in or out.
Have the same problem, then I just use another microSD or SD card adapter to insert it Smile
I use a large paper clip.
(12-16-2019, 04:51 AM)ioo Wrote: Are you pushing it in far enough? It is rather finicky to do and I especially find it very hard if I've clipped my nails recently. I suppose one could fashion a tool to make it easier.
Thanks.  I got it.  I had to press in and down to get it to stick.  [Sigh] It's the little things in life...
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 3,642 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Pinebook Pro won´t boot either from eMMC or microSD robieguarneros 40 74,046 11-16-2020, 10:48 AM
Last Post: axel
  Another Newb Unable to Boot From microSD JimmyJazz1971 3 7,253 10-26-2020, 03:48 AM
Last Post: JimmyJazz1971
  Booting from microSD evj 4 10,377 04-19-2020, 07:24 PM
Last Post: bcnaz
  Mr. Fixit Script Manual Update + MicroSD Boot help SageFox 12 27,700 04-17-2020, 03:30 AM
Last Post: mlentink
  Booting from MicroSD kunger 8 17,301 11-03-2019, 11:37 PM
Last Post: Arglebargle
