Default OS update log
(12-10-2019, 03:06 PM)Luke Wrote: @sjk what happens if you press Fn+ESC?
I get the suspend/shutdown dialog, and click suspend. It then blinks and wakes up.
I see the same behaviour on my PBP.
1.8 is out with a kernel update and massive improvements to chromium performance.
Will this find its way to Ubuntu and Manjaro as well, or is this just something we'll have to do ourselves?
(12-23-2019, 09:11 AM)brent.thierens Wrote: Will this find its way to Ubuntu and Manjaro as well, or is this just something we'll have to do ourselves?
Happy to share the relevant flags with whomever wants of course.
There is a 'software tuning' section in the wiki here https://wiki.pine64.org/index.php/Pinebo...ning_guide (kudos to @Arwen for starting it) where anyone can add the tweaks Big Grin
Thanks!
Edit: Is this file the one you mention @Luke https://github.com/mrfixit2001/updates_r...em/default ?
It seemed that on v1.7 suspend worked the times I tried it, but with v.1.8 suspend problems are present again. System wakes up immediately after suspending.
Pressing FN+ESC blacks the screen, wakes up immediately again, but logs me out/crashes my xfce-session and I have to re-login.
(12-24-2019, 11:09 AM)tuxor Wrote: It seemed that on v1.7 suspend worked the times I tried it, but with  v.1.8 suspend problems are present again. System wakes up immediately after suspending.
I have never been able to suspend correctly since I received my unit. It has always suspended for a second and woke up, from v1.4 through v1.8.
Thanks!
Yes! Those are the Chromium flags Smile
Thanks!
Great!
I've found also ayufan's tweaks that maybe worth to explore and document in the wiki if still relevant https://github.com/ayufan-rock64/linux-package
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,317 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,083 10-19-2021, 01:57 AM
Last Post: j4n3z
