Sms apps and signal messenger
What OS's on the pinephone will allow sms messages? And what app would be use for that?
Better yet, is there anyway to use signal messenger for sms as well? Currently the desktop Linux version of signal is only for communication to other signal users using mms. Would an android like implementation work, where signal can also send sms messages?
(12-06-2019, 08:07 AM)boggle Wrote: What OS's on the pinephone will allow sms messages? And what app would be use for that?
For sms it's likely to be pretty much all or nothing as it looks like they're all using ofono as intermediary between app and modem. Once support for the Quectel modem is in ofono the apps should work...in theory.
I'm running Debian on my PinePhone. I guess if I try to set up Signal, the easiest would be to port the Debian desktop version to ARM64. It wouldn't have all the same features as regular Signal though and would rely on pairing it with an existing install. That would be a fun project.
For now I look to other things like Matrix.org as solutions
*.*.* PinePhone BraveHeart edition w/ distro: Debian + Phosh // GuixOS, Debian, Arch // pocket linux enthusiast // washed up sysadmin *.*.*
Signal for pinefon is 'signal-desktop_6.11.0_arm64.deb' at Gitlab.  Requires
Signal on your android.
  https://gitlab.com/undef1/signal-desktop...s/13612537
Note:  This is not the current version (requires registering) but it'll get you there.
Signal for the desktop doesn't work so well on the small pinefon screen.
-wigan-
signal was used for sms also  but for security resons they disabled it
 so don't hold your breth
 ezik
for sms you can use chatty or whatever comes with your distro
mms is somwhat tricky because you need diferent APN for it
ezik
SMS is supported on basically every distribution.
Plasma Mobile uses Spacebar, Phosh uses Chatty, other environments have their own SMS app.
Hello
Silence, a fork of Signal, still supports SMS as far as I remember. It works under Android and you can use it with an Android emulator on a Pinephone under GNU Linux.
axolotl, which is native signal client for linux based phones, not android. axolot has reached 2.0.4 version. however, i haven't tested it, i use signal-cli.
https://github.com/nanu-c/axolotl
https://github.com/AsamK/signal-cli
  Using Signal on PinePhone in mid-2023? dante404 47 65,606 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Alternatives to Signal or simple signal setup methods? JamesBond009 3 9,043 04-25-2024, 02:22 PM
Last Post: TRS-80
  [Video] LVGL in WebAssembly: Building NuttX Touchscreen Apps with Zig lupyuen 0 2,786 09-30-2023, 03:37 AM
Last Post: lupyuen
Question Proprietary apps for PinePhone/PineTab Benoit 10 24,719 10-14-2022, 12:29 AM
Last Post: groomsb31
  LinuxPhoneApps.org lists over 400 apps now - and now has a thread here linmob 0 2,721 10-11-2022, 12:17 PM
Last Post: linmob
  Web apps oliwierzgorniak 2 4,380 09-24-2022, 10:20 AM
Last Post: oliwierzgorniak
  Which apps can I run on this phone? poppyhodler 2 5,953 06-07-2022, 12:18 PM
Last Post: jenniferjohn12
  GTK Rust mobile Linux client for Signal Be. 14 37,588 11-11-2021, 05:35 PM
Last Post: sativista
  Session Private Messenger Cree 6 16,466 10-15-2021, 09:10 PM
Last Post: lot378
  Pinephone Apps Unified Dev Hub biketool 11 20,876 09-09-2021, 10:53 AM
Last Post: ragreenburg
