GPU accelaration ubuntu 18.04
Hey,
It seems to me that the GPU isn't used at all on Ubuntu 18.04 on my pbp.
At least powertop reports 100% idle for the GPU even when playing video (in browser and mpv).
Does anyone else have a similar experience?
(11-29-2019, 04:32 AM)ventus_orientis Wrote: Hey,
Playing video involves VPU, not GPU which is for graphic processing.
Mine was working, then I think I broke it. Stellarium doesn't start properly anymore and 1080 videos are laggy.
glxinfo gives this at the beginning...
name of display: :0.0
libGL error: MESA-LOADER: failed to open rockchip (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: rockchip
There is nothing labeled "rockchip" in the path, but there are 22 drivers...
Any ideas?
de KL7JKC
Use MPV media player - that has accelerated video playack for files up-to 4K@30FPS.
You can also use SMplayer with 1080p files. For SMPlayer you just need to specify settings in the config.
(12-01-2019, 03:06 PM)Luke Wrote: Use MPV media player - that has accelerated video playack for files up-to 4K@30FPS.
Thanks, Luke!
smplayer works without lagging though it seems grainy.  I was using vlc.
Still can't get stellarium to work, though it worked right after I installed it.
Still works in the default debian build, but opens a small box and just sits there in Ubuntu/mate 18.04.
I was trying to get wine to work, when I started having video issues.  If I have to, I'll reflash the SD back to the original image and then reinstall stuff (carefully).
Thanks again!
de KL7JKC
Thanks, Luke!
Thanks again!
Experiment and have fun Smile
glxinfo aso shows that there is an error loading the video driver (mpv does show the same error, rkmpv does the same).
also: the gpu is not used when running software like glxgears.
This is seems to be a problem with the video accelaration.
I hope it can be fixed?
  After update in Ubuntu bionic mate system crashed Wawe 2 7,193 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu Installation on PBP narinderpal10 5 12,061 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,408 12-15-2020, 01:53 AM
Last Post: BryanF
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 32,849 11-19-2020, 03:16 AM
Last Post: FeMike
  Ubuntu 20.10 bastafari 6 12,530 10-27-2020, 10:16 AM
Last Post: Mangled
  How does one get working deep/S3 sleep with Ubuntu Focal/5.7 mainline kernel? Syonyk 7 16,164 10-26-2020, 02:03 PM
Last Post: edward
  Ubuntu 20.10 beta Mangled 21 36,399 10-12-2020, 07:13 AM
Last Post: Mangled
  ANSI keyboard fix for ubuntu Mangled 0 3,306 10-05-2020, 02:15 PM
Last Post: Mangled
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 63,698 09-06-2020, 08:20 AM
Last Post: pine76
  Ubuntu for RockPro64 dndeokar 1 5,413 08-14-2020, 06:42 AM
