Boot from SD card / boot options
(11-24-2019, 11:31 AM)ryannshit Wrote:
(11-23-2019, 03:08 PM)ryannshit Wrote:
(11-23-2019, 01:10 PM)ryannshit Wrote: I cannot get the Pinebook 1080 to boot to MicroSD card using the  Q40 image with Etcher. Tried multiple SD cards as well. Is there anywhere I can check my system boot options? I have a feeling it is not even trying to boot to MicroSD.
Tried Neon as well and it will not boot to SD Card. Etcher shows it writes to SD successfully , the card mounts and shows up on the Pinebook, but it   wont boot.
Purchased new Samsung Evo SDHC 32gb cards and still a no go! What am I doing wrong here? Is there a way to check or configure the boot order somehow?
That's very odd! It should just boot from the SD when inserted and powered up. I've had Etcher make faulty boot SDs before whenever I took an img.xz (or similar compressed image) and decompressed it, and then there's some images that won't boot unless the uncompressed image is burned. Which are you burning to your card, the compressed or uncompressed image?
Have you tried reseating the ffc cable that goes to the daughterboard with the sdcard/headphone jack? Does the sdcard work if you boot from eMMC? Do you have a serial console dongle so you can see what is going on while trying to boot?
(11-25-2019, 07:35 AM)xalius Wrote: Have you tried reseating the ffc cable that goes to the daughterboard with the sdcard/headphone jack? Does the sdcard work if you boot from eMMC? Do you have a serial console dongle so you can see what is going on while trying to boot?
I have not tried reseating. The SD Card shows up in the GUI as PINEBOOKneon for instance. I ran the widevine and mrfixit update scripts and still cannot boot to SD.
Just to clarify, is this problem occuring on a Pinebook or Pinebook Pro?
  Booting with TOC0 u-boot -- should it work? dreadbit 0 3,859 11-24-2022, 10:19 AM
Last Post: dreadbit
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 19,322 12-07-2020, 04:02 PM
Last Post: SanjevR
  eMMC boot linux distros for Pinebook. frank-zappa 14 33,737 09-06-2019, 08:39 AM
Last Post: frank-zappa
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 3,469 05-19-2019, 04:46 PM
Last Post: Shoananas
  Is it possible to choose between SD/eMMC boot programmatically? UltraBloxX 2 8,220 01-28-2019, 11:41 AM
Last Post: UltraBloxX
  [SOLVED] Can't boot when SD card inserted jschall 5 14,149 11-17-2018, 11:53 AM
Last Post: jschall
  Boot from MicroSD ramboton 3 9,113 11-16-2018, 06:04 PM
Last Post: Luke
  How to mount new microSD card? jschall 8 15,601 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 14,183 11-10-2018, 10:47 AM
Last Post: acruhl
  Dual Boot on eMMC? d97 1 5,623 08-30-2017, 10:04 AM
Last Post: abrmx
