11-20-2019, 04:34 PM
The Panel built in color looks washed out. I don't know what's panel does it has.
So is it possible to replace with a better one?
Is it possible to replace LCD panel?
11-21-2019, 04:51 AM
I'm glad to see you bring this up - colour calibration is definitely off somewhere on the panel. I'm hoping it is software, not hardware.
For example, try looking at a pure red - it looks far too orange.
I also hope it can be fixed in software, colors are very off.
Viewing angles are not bad, but the screen is washed out.
11-22-2019, 10:16 AM
Maybe someone could create an ICC profile for the pinebook pro panel? I have a spyder, and made those in the past, but it's quite a lenghty process (just waiting for the panel to go through all the colours and stuff) and I just don't have enough time on my hands
11-22-2019, 01:24 PM
Looks like there is an ARM compile of Argyll and DisplayCal GUI ... I have an old Spyder3... I might give it a go myself this weekend (I'm kidless this weekend).
11-22-2019, 01:59 PM
(11-22-2019, 01:24 PM)gabeeg Wrote: Looks like there is an ARM compile of Argyll and DisplayCal GUI ... I have an old Spyder3... I might give it a go myself this weekend (I'm kidless this weekend). I have a redundant Spyder 2 - dunno how far back that goes (Windows XP perhaps?) long out of any support I suppose. (11-22-2019, 10:16 AM)mfritsche Wrote: Maybe someone could create an ICC profile for the pinebook pro panel? I have a spyder, and made those in the past, but it's quite a lenghty process (just waiting for the panel to go through all the colours and stuff) and I just don't have enough time on my hands @krishorne would you be able to do this when your PBP arrives? Talked to him last night. Says he has a Spyder4 at work he'll use to calibrate with, and will share the profile.
11-24-2019, 11:19 AM
(11-22-2019, 07:57 PM)tophneal Wrote:(11-22-2019, 10:16 AM)mfritsche Wrote: Maybe someone could create an ICC profile for the pinebook pro panel? I have a spyder, and made those in the past, but it's quite a lenghty process (just waiting for the panel to go through all the colours and stuff) and I just don't have enough time on my hands Turns out I had a Spyder 4 Pro...newer than I thought...still old though. I am running Displaycal as I type this on my other machine. As of this moment it is 1:02:34 into the process and 340 of 391 run. When complete I will post profile.
11-24-2019, 11:20 AM
Awesome stuff!
I have the archive with the .icc profile that Argyll/DispalyCAL created for me...but it is slightly too large to attach...I will just attach the .icc for now and some screens. In a rush and the icc has a crazy long name...probably want to rename it.OK, I'm back home and tried to use xcalib to load the profile and I get "unsupported ramp size 0" errors but dispwin -v Pinebook.icc (this is the name of the profile I created) seems to work. I say "seems" because I do not see a screen change in color or temp or anything else. Dispwin -V Pinebook.icc seems to verify it is loaded.... I just don't know. Anybody else try it? |
| LCD panel shifted after delevery | mbruchert | 2 | 6,185 |
11-13-2020, 06:50 PM Last Post: member |
Possible to replace SBC? | lunartic | 1 | 4,565 |
03-02-2020, 03:22 PM Last Post: tophneal |
| Replace eMMC | stefan.schumacher | 10 | 20,248 |
11-19-2019, 04:19 AM Last Post: abdel |
| What is the PWM frequency of the panel brightness controller? | User 12559 | 4 | 11,992 |
07-23-2019, 11:20 AM Last Post: User 12559 |
