Keyboard and key mapping
What keyboard is this? It is not standard North American, as I thought it would be.
What "layout" is it. It will be frustrating as it is to have a different layout, but even more if this odd layout is mapped incorrectly.
Thanks.
(11-12-2019, 09:04 AM)ambein Wrote: What keyboard is this? It is not standard North American, as I thought it would be.
Thanks.
I'm guessing you have one of the first ISO models. It is a UK layout. If you see the option, you might want UK with AltGr.
Yes the UK layout works! Thank you very much.
Was / is there an option to choose the keyboard layout, or was it a lottery?
By default it is the US layout but actually the UK corresponds to the characters displayed on the PBP keyboard.
And for those like me who need additional characters in their native language there are advanced options.
In addition to that : In the "position of compose key" section you can choose a key to make other characters.
For example ¸[key]+[,]+[c] = ç
(11-12-2019, 09:37 AM)ambein Wrote: Yes the UK layout works! Thank you very much.
The last/most recent preorder run gave an option to choose between ISO (UK) and ANSI (US). But all other previous preorder batches did not. I got mine in the first public preorder, open to forum members only, and ISO was the only option.
In the task bar you must have "En" indicated?
click on it to choose your keyboard
I didn't understand the question. ;$
By layout I meant choose the keyboard hardware. The physical keyboard. i.e. standard US. Using a UK keyboard for a daily driver is kind of jarring when all the keyboards I use are US.
Mapping I mean the software layer, which is easy to change, as long as one has a standard keyboard.
So I was asking are there any pine64 pros with US keyboard and why I wasn't able to get that, considering I ordered the US model.
(11-12-2019, 10:01 AM)ambein Wrote: By layout I meant choose the keyboard hardware. The physical keyboard. i.e. standard US. Using a UK keyboard for a daily driver is kind of jarring when all the keyboards I use are US.
The US keyboard models were only just made available to order on 11/5/2019. Likely no one that ordered them has them yet.
  PinePhone keyboard not registering input properly Feemphynead 0 2,567 04-25-2025, 03:37 AM
Last Post: Feemphynead
  PBP locking up multiple times per day - keyboard and mouse unresponsive newton688 6 10,828 03-04-2021, 11:28 AM
Last Post: MtnSk8
  Keyboard issue: Debian PineSupporter 8 15,554 02-01-2021, 09:57 PM
Last Post: PineSupporter
  ANSI keyboard fix for ubuntu Mangled 0 3,243 10-05-2020, 02:15 PM
Last Post: Mangled
  Error when running pinebook-pro-keyboard-updater NoahB 13 25,159 07-29-2020, 06:33 PM
Last Post: guiltydoggy
  Some keyboard shortcuts won't work on Manjaro KDE Daysleeper_Ed 6 15,604 07-02-2020, 02:19 PM
Last Post: perceg
  Kali Linux PB Pro Whacky Keyboard fredortiz95 0 3,053 06-13-2020, 03:38 PM
Last Post: fredortiz95
Question International Keyboard on Pinebook Pro TDC_PBP 3 8,405 05-09-2020, 04:06 PM
Last Post: TDC_PBP
  Manjaro Arm users - What does your trackpad/keyboard conf file look like? Eggmonkey 7 14,582 04-21-2020, 08:27 AM
Last Post: Surehand53
  Manjaro/KDE: Turning off internal keyboard and is a replacement part possible? LittleWalter 4 8,708 02-18-2020, 10:54 PM
Last Post: LittleWalter
