Default OS update log
#41
Check log in OP ? (Other Posts ?)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#42
(10-16-2019, 10:18 PM)bcnaz Wrote: Check log in OP  ?    (Other Posts ?)
Original Post
#43
I got my PBP, logged in, connected to my gateway, updated the Debian + Mate system with the mrfixit icon. Firefox crashes when I do anything with it. Chrome either crashes or loads so slowly as to be useless. This is very disappointing. I've used linux on many laptops designed for Windows and Linux alway works more or less well. Why am I having this probelm? Is anyone else seeing this? Otherwise the wifi works okay if slow.
#44
I seem to have misplaced the handy icon for the update script.
I'm probably just being tired and dense, but is there another/better way to trigger system updates?
Also, will i break anything if i let apt-get update the 80 or so items it's itchy to update?
#45
(11-01-2019, 03:43 PM)Watercourse Wrote: I seem to have misplaced the handy icon for the update script.
The icon is a shortcut to the script:
sudo ./usr/bin/mrfixit_update.sh
#46
Got it. Thank you. :-)
#47
So 2 days more for a new batch of pre-order?
I have been monitoring this since a friend mentioned the PBP to me. Feels like the perfect Linux Utility machine
#48
(11-01-2019, 03:43 PM)Watercourse Wrote: Also, will i break anything if i let apt-get update the 80 or so items it's itchy to update?
You will not break anything. In fact, you should regularly update Debian for security reasons.
(11-01-2019, 03:34 PM)richfm Wrote: I got my PBP, logged in, connected to my gateway, updated the Debian + Mate system with the mrfixit icon.
That icon is mostly updating the kernel, uboot and device tree. You should update the actual Debian system from time to time via
# apt-get update && apt-get dist-upgrade
#49
Unfortunately, those commands aren't working.
I get this:
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
Any ideas? Thanks! :-)
#50
(11-03-2019, 07:30 PM)rick1959 Wrote:
(11-03-2019, 01:58 PM)Der Geist der Maschine Wrote: # apt-get update && apt-get dist-upgrade
I get this:
use sudo in front of the commands above...
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,317 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,082 10-19-2021, 01:57 AM
Last Post: j4n3z
