Tested PCIe cards and output
Hi all, I really want to love this little board but I just can't.  Not being able to use my Supermicro AOC-SASLP-MV8 is nearly a dealbreaker, and I do not have serial capability.  Strangest behavior is that all the cards but the Supermicro would boot the rockpro, even if they don't seem to be supported.  Supermicro just sits with a blinking cursor on the screen and no reaction to anything.
Anyways, I plugged in every PCIe addon card I had and took some dmesg and lspci logs.  Maybe someone here can figure out things for others.
Can't post it on here so I'll put it on pastebin raw format.
EVGA geforce GT 730 P/N 01G-P3-2730-KR dmesg
PNY Nvidia Quadro K620 VCQK620-T dmesg
PNY Nvidia Quadro lspci -vvv
LSI SAS 9271-4i dmesg
LSI lspci -vvv
Asus Hyper M.2 X4 dmesg
Asus USB 3.1 2-port card dmesg
Asus USB lspci
Hi! Probably, your card requires BIOS support which is impossible with this SBC. For the chip your card used there should be Marvell BIOS support, like I see in different product user manual.
[Image: attachment.php?aid=1441]
The cards which doesn't use dedicated BIOS support should work.
Also if you have spare hardware, you can try to insert the card into PCIe slot while the SBC is running, make a hotplug. If the hardware will not blow-up, probably you will got more information in kernel log.
.png   Screenshot from 2019-10-17 11-48-25.png (Size: 118.14 KB / Downloads: 1,501)
Thanks for the reply.  I don't agree with what you're saying because this card does not have RAID capability (one of the reasons I bought it).  Here is the link to the manufacturer's page of the card.  The information you found is specific to the Marvell 6480 controller where the card in question has a Marvell 9480.  Not trying to nit-pick here but sometimes the devil is in the details, and I admit I could be completely wrong.
Anyways, I just got a serial adapter in the mail so I'll try seeing what all the fuss is about with this card.
Agree with you now. Looking into serial output right after power-on is a good place to start. The adapter needs to be setup for 1.5MBaud speed.
Will start a new thread for the serial output of this card.
If your PCIe card contains an option ROM or similar with x86 code to run on startup, that's usually a dealbreaker, unless your card vendor has option ROM firmware that runs on ARM
  Compatible PCIe Sata Controller spacebricker 1 5,467 02-06-2023, 10:03 AM
Last Post: diizzy
  PCIe bifurcation support (on RK3399) Arn 1 5,456 11-28-2022, 05:12 PM
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 7,597 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 9,538 02-17-2021, 11:35 AM
Last Post: dml-pc
  Nvidia GPU on PCIe User 18962 4 8,775 12-22-2020, 02:54 PM
Last Post: amiraeva
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 5,126 10-20-2020, 12:22 PM
Last Post: xmixahlx
  RockPro64 pcie Gpu Davidos 8 22,897 07-14-2020, 05:11 PM
Last Post: ProDigit
  PCIe failure odhinnhrafn 11 20,505 03-16-2020, 08:39 AM
Last Post: odhinnhrafn
Question Can we add PCIE hub 1 to many pcie card seaurchin 1 5,369 11-25-2019, 11:08 AM
  No boot with Supermicro AOC-SASLP-MV8 (serial output) kram0000 0 3,681 10-22-2019, 04:00 PM
Last Post: kram0000
