Pine64 Hardware and FSF RYF Certification
This is getting off-topic, but firmware changes to gear <i>ratio</i> do not imply that the firmware is changing the physical teeth on a gear, but rather gear <i>selection</i> See e.g. here: https://www.projectcarsgame.com/the_insi...-settings/
I did not mean to sound contradictory there.
But rather giving my opinion,
    I see the firmware kind of like the differential in an automobile,  and the software as the transmission.
It is a mechanical job to change the ratio in the differential,  very seldom done on most consumer vehicles.
while your transmission may change gear ratios hundreds of times, even in a short trip.
  While you can sometimes get the results you want by say changing the differential gears to run a better time at the dragstrip,
 But,  the car then becomes unpractical to drive on the highway or to work everyday.
Changing the firmware 'may' change how your hardware interacts with your software.  OF Course this is not always a bad thing,
But something to consider,
   as you may end up needing to re-tune your software after changing the firmware.
IF this is your 'cup of tea'  go for it.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I like open source, firmware too, because I like to see it. I want to look at the chip diagrams, see the fuction of the blobs, and write code that I understand all the way down to the transistor. I just want it.
And, incidentally, most modern CVT transmissions do not have gears. They are friction cones moved against one another to produce a gear ratio, which is indeed controlled by software. In fact, most modern cars only seem to shift "gears" because marketing suggested people enjoy the sensation. From a hardware perspective a modern cvt transmission is quite capable of adjusting its ratio to the engines powerband without any noticeable shift at all, it would simply slide through every ratio in a single smooth manner.
https://www.meineke.com/blog/what-is-a-c...nsmission/
  Ordering from Pine64 website NonPlayableCharacter22 0 828 07-28-2026, 02:07 PM
Last Post: NonPlayableCharacter22
  Has anyone installed Trisquel (linux-libre) on Pine64 RockPro64? libreboy 1 4,742 11-03-2025, 12:08 PM
Last Post: RandB
  Problem joining Discord Pine64 dhdurgee 1 4,869 09-30-2025, 11:44 AM
Last Post: dhdurgee
  SBC Case Builder and Pine64 SBC hominoid 1 5,327 06-13-2025, 03:03 PM
Last Post: hominoid
Star Pine64 Logo Submissions Admiral Snackbar 0 3,607 06-08-2025, 03:00 PM
Last Post: Admiral Snackbar
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 6,092 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  [Article] Test Bot for NuttX Pull Requests ... Tested on Real Hardware (Oz64 SG2000) lupyuen 0 3,441 02-15-2025, 11:26 AM
Last Post: lupyuen
  Registering my 'nick' on Pine64's IRC network diederik 7 9,845 12-04-2024, 05:44 AM
Last Post: mmonster
  Need Help Choosing the Right Pine64 Board for My Project jacoballen 1 3,743 09-22-2024, 06:28 PM
  Enhancing Privacy with additional hardware killswitches Substing 2 4,158 07-25-2024, 07:49 PM
