Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
(06-07-2019, 04:34 AM)beard5849 Wrote: What I'm looking for is GCC with NEON support .
And, not a cross compiler, so must run on the RockPro64.
Reason: LPCnet  and the FreeDV project.
Any pointers please?
And yes, I loaded mrfixit2001's Debian minimal image on 1st June 2019
Alan B
Hello beard5849,
I haven't understood your question..
You can use Rockpro64, and GCC, then,
You just need read the NEON Intrinsics, if you don't want to program in assembler, you can do it in C/C++..
You can check also the ARM Compute Library.
  Freezes and kernel panics with Debian trixie jssfr 4 4,345 04-15-2026, 06:48 PM
Last Post: prahal
  RK3399 PCIe enumeration jhadd 0 3,512 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,976 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,635 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,109 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,975 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,212 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 7,315 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 3,240 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 6,673 02-19-2022, 06:44 AM
Last Post: sigmaris
