How do I pre-order?
I'm confused on how to pre-order the Pinebook Pro.  I've been browsing to pine64.org every few days for almost 2 months now and am failing to see how this can be done.  I realized that I had not joined the forum quite early enough to get in the first cohort of pre-orders but I thought I'd be able to get in there by now.
The pine64.org front page says "Starting August 25 pre-orders are open to everyone. Following this production-run, the next pre-order window is scheduled for mid-September 2019", followed by a [Pre-Order Now] button.  That button takes you to the store which only says "Out of stock" when I select either the EU or US power supply and the [Add to cart] button just says "Sorry, this product is unavaliable."
Is there something I'm missing?
(10-03-2019, 03:12 PM)ColoBill Wrote: I'm confused on how to pre-order the Pinebook Pro.  I've been browsing to pine64.org every few days for almost 2 months now and am failing to see how this can be done.  I realized that I had not joined the forum quite early enough to get in the first cohort of pre-orders but I thought I'd be able to get in there by now.
No, you are not missing anything.
The second batch that started August 25th was filled up, if I remember correctly.
So, you would look to the 3rd batch, probably opening up mid October.
Eventually, there will be open ordering.
They do need to update the ordering page and other places to clarify that information.
Arwen Evenstar
Princess of Rivendale
  Post by Luke  10/01
      "Likely late October"  next pre-orders
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Order Status mamboman777 1 6,291 06-17-2023, 10:25 AM
Last Post: fxc
  boot order straightwalker 7 12,047 12-25-2021, 09:23 AM
Last Post: alidonkaka6
  Will It Be Okay To Order The PineBook Pro US Version For Use In The UK? ImmyChan 7 13,295 03-15-2021, 10:24 PM
Last Post: dsimic
  Pinebook Pro pre-order iMav 4 7,658 03-03-2021, 07:41 PM
Last Post: globaltree
Question Possible to order Pinebook Pro with 128Gb eMMC? KC9UDX 8 16,220 07-28-2020, 06:52 PM
Last Post: LittleWalter
  NVMe adapter separate order? powerful owl 5 10,211 07-27-2020, 10:02 PM
Last Post: powerful owl
  My order from Jan 20th is moving. zaphod80013 0 2,761 02-24-2020, 09:50 PM
Last Post: zaphod80013
  Pinebook Pro ANSI pre-order Amandaville 3 8,319 02-18-2020, 03:42 PM
Last Post: Amandaville
  Booting from an SD card without the boot order update jaysistar 7 13,530 01-27-2020, 08:30 AM
Last Post: jaysistar
  order deadline for next production run bsammon 6 13,348 01-01-2020, 09:40 PM
Last Post: bcnaz
