Pine HDMI -> DVI monitor
Got my Pine RockPro working and now actually wanted to use it in my garage with an old Monitor.
Today reveiceed the HDMI to DVI adapter and hapily connected everything together and no signal..... Huh   Plugged the HDMI cable in my laptop and the old Monitor comes a live. So the adapter is working but somehow not with the Pine board.
Did some research and I came across some old posts that this problem is known. Only thing as a solution found so far is what I found on the armbian site.
https://www.armbian.com/pine64/
They say:  If you use a DVI display don’t forget to define
disp_dvi_compat=1
 in
/boot/armbianEnv.txt
 (supported starting with 5.21).
Now I tried to put in the line and save but with no succes. Seems I have no permission? Huh
(09-05-2019, 11:46 AM)Pineapple Wrote: Now I tried to put in the line and save but with no succes. Seems I have no permission? Huh
Do you mean you had problem saving the /boot/armbianEnv.txt ?
try it with "sudo nano /boot/armbianEnv.txt" ...
(09-05-2019, 11:46 AM)Pineapple Wrote: Today reveiceed the HDMI to DVI adapter and hapily connected everything together and no signal..... Huh   Plugged the HDMI cable in my laptop and the old Monitor comes a live. So the adapter is working but somehow not with the Pine board.
I have trouble with a monitor or dvi adapter sending corrupt and/or blank edid and I have to force to work. On armbian I use:
extraargs=drm_kms_helper.edid_firmware=edid/1920x1080.bin
Thanks Martinayotte that worked Smile
Evilbunny tried that but that isn't working Sad
Tried your same line. But also put in the resolution of the screen which I am using ( Dell 1909WF 1440x900 ) and still not working.
When I discontect the cable screen says no cable connected. When I plug in the cable it goes straight into power saving mode.
This is what I got now in the file.
verbosity=1
overlay_prefix=rockchip
rootdev=UUID=e6f2ace3-a9fd-4cb6-a5f5-c69dec4583d4
rootfstype=ext4
disp_dvi_compat=1
extraargs=drm_kms_helper.edid_firmware=edid/1440x900.bin
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
edit... after I change something I did rebooted the Pine board. Smile
edit no 2... Seems it might be a DVI hot plug problem. Just measured Pin no.16 and there was no voltaged. Will try to solder a resistor in my screen this week to see if it will keep out of the sleep mode.
Source: http://philtechnicalblog.blogspot.com/20...ilema.html
Even with separate hot plug connection no luck. Seems Pine isn't sending the DDC/EDID somehow to the screen?
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 3,756 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  pine store paulhide 1 5,782 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 9,492 03-18-2020, 08:41 AM
  First Boot HDMI/USB problem reefer 1 7,492 11-18-2018, 10:32 PM
  PINE A64+ 4K Media Computer RWL 4 11,160 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 14,121 09-19-2018, 10:30 AM
Last Post: mjgoode
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,863 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 8,375 12-26-2017, 07:01 PM
  HDMI "Format not supported" sam452 3 10,483 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,771 04-02-2017, 08:12 AM
Last Post: Luke
