Rockchip RK3399 PCIe lanes only 2.5GTb/s?
Okay, I may be wrong, (it's rare, but happens :-). From my reading, it appears that the PCIe lane speed is 2.5GTb/s, (aka PCIe 1.x speed), verses 5GTb/s in 2.x. (That said, the chip seems to support the protocol updates in PCIe 2.1.)
So, anyone else read it that way?
Here is a reference;
http://opensource.rock-chips.com/images/...170420.pdf
Page 89
Quote:Signal data channel data rate maximum up to 2.5GTb/s, with 8b/10b form, the maximum data rate up to 250MB/s
Next line adds the following, (which implies all 4 lanes working together);
Quote:Work in full-duplex mode, maximum data rate up to 10GTb/s, which is 1GB/s
All that means, (if I've read that right), is any NVME drive will be limited by this change. Probably not an issue for 4 lane NVME drives. Though 2 lane NVME drives, (like that nice low power Western Digital Blue), might suffer a little. This will not stop me from using a NVME drive, though I might make more effort to find a 4 lane device that has reasonable power usage.
Also, (my original reason for the research), it appears that the 4 x PCIe lanes can not be bi-furcated into 2 x 2 PCIe lanes. All 4 must work together, as either 1/2/4 lanes. (So it DOES support 2 lane PCIe devices, like the afore mentions WD Blue NVME drive.)
Arwen Evenstar
Princess of Rivendale
rk3399 leaked manual, floating in the internet, v1.3 part 2, page 700, says:
Quote:It is compliant with PCI Express Specifications 1.1, 2.1.
PCIe supports the following features:
Maximum link width is 4, single bi-directional Link interface
Support 2.5GT/s and 5.0 GT/s serial data transmission rate per lane per direction
also, tests posted on this forum have shown speeds ~1.5GB/s.
ANT - my hobby OS for x86 and ARM.
(08-24-2019, 08:11 PM)z4v4l Wrote: rk3399 leaked manual, floating in the internet, v1.3 part 2, page 700, says:
Thank you. I thought it was a bit strange to support only 2.5GT/s for a newer device.
Arwen Evenstar
  Revisiting RK3399 LPDDR speeds Syonyk 1 4,047 01-02-2022, 10:03 AM
Last Post: Syonyk
  RK3399 - big.LITTLE core choice optimization lucserre 3 10,032 06-29-2020, 11:12 AM
Last Post: xmixahlx
  Memory clock speed: 800MHz vs 1600MHz? (NM, RK3399 won't run >800MHz DDR) Syonyk 4 12,024 06-26-2020, 07:22 PM
Last Post: Syonyk
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 18,656 12-19-2019, 05:15 AM
Last Post: ndp
  PCIe card success ? DrYak 0 3,228 11-12-2019, 01:16 PM
Last Post: DrYak
  PCIe Der Geist der Maschine 2 7,628 11-07-2019, 07:31 AM
Last Post: VoxUnius
