HOW TO fix Wifi on RockPro64 - Recalbox OS and upload roms on SSD External
Question
Hello everyone, hope I''m posting this in the right section. Need some help on two things, I have a Rockpro64 with a Roshambo case and recalbox OS installed, I've tried a generic WiFi module 802,11n but when I switch enable WiFi it doesn't do anything.. any idea how can I get it to work? I know there is a dedicated module but I want to avoid to spend extra money. I have tried running the terminal remotely, but no luck Sad don't really know what commands I should run
And the other thing is how can I upload ROMs in the external SSD as i bought the mini cartridge as well. When I move ROMs is like moving them in mini SD, do i need to use a converter and plug the SSD to my PC to transfer files?
Thanks in advance ✌️✌️
(08-22-2019, 01:48 PM)Gouki Wrote: Hello everyone, hope I''m posting this in the right section. Need some help on two things, I have a Rockpro64 with a Roshambo case and recalbox OS installed, I've tried a generic WiFi module 802,11n but when I switch enable WiFi it doesn't do anything.. any idea how can I get it to work? I know there is a dedicated module but I want to avoid to spend extra money. I have tried running the terminal remotely, but no luck Sad don't really know what commands I should run
Do you know which chipset is in the wifi module?
Hi, thanks for you reply, i checked and should be this
Realtek RTL8188FTV Wireless LAN 802.11n USB 2.0 Network Adapter
(08-23-2019, 03:48 PM)Gouki Wrote: Hi, thanks for you reply, i checked and should be this
@Mrfixit2001 existing images don't contain headers so you'd need to get him to include drivers in future builds
And how do I do that?  Huh
I was hoping my post would have nudged him, otherwise you could try posting an issue on his github repository:
https://github.com/mrfixit2001/recalbox_...o64/issues
Ok thanks I'll try there  Rolleyes
Brick Logical Extensible Gizmo Organizing RockPro64 Enclosure hoarfrosty 0 3,118 08-06-2023, 09:32 PM
Last Post: hoarfrosty
  RockPro64 programing GPIO by Rust yanagawa3 0 4,851 11-24-2021, 08:43 PM
Last Post: yanagawa3
Photo RockPro64 programing GPIO, I2C,UART and SPI madhuks 3 11,558 08-06-2020, 09:07 AM
Last Post: Gienek
  RockPro64 as PATA/SATA bridge? Count Omega 1 7,404 12-07-2019, 02:25 PM
Last Post: Count Omega
  ROCKPRO64 for SCRAPING Ulthor_31 4 12,234 08-01-2019, 05:19 AM
Last Post: Ulthor_31
  RockPro64 as PVR/DVR bm_00 1 6,265 02-27-2019, 04:46 AM
Last Post: mabs
