Power Consumption
(07-24-2019, 10:16 AM)stuartiannaylor Wrote:
(07-24-2019, 09:20 AM)FantasyCookie17 Wrote:
(07-24-2019, 08:50 AM)stuartiannaylor Wrote: 10Wh
10000 mAh is not 10 Wh, unless the voltage is 1v...
I have no idea what voltage it is or what voltage the chrome book is, as was too lazy to check.
I am thinking that it probable due to it being on the pinebook that it could be a tad short.
Maybe you should find out.
The battery in the Pinebook Pro (and the original Pinebook, for that matter) is 37Wh. That is 3.7V and 10Ah. Because, ya know, watt-hours = voltage * amp-hours. Wink
It's basically identical to the Chromebook you're referring to.
Yeah thanks for that as now you know how many Wh from a near as damn it identical device you know the expected run time from the reviews and should be able to give average power usage.
The Op1 was 2.0/1.5ghz but not all ran that high as opposed to 1.8/1.4ghz so the 9 hours is prob not as optimistic as Googles or Asus or whoever.
Thank You for your replies, guys.
I was hoping that Pine would have some good measurement equipment available, and that there would be some real world numbers.
I have asked Luke if there are any real world measurements available.
The actual power consumption for the Pinebook Pro will depend on the hardware components used in this specific system as a whole, including the efficiency of the AC adapter used.
The number for "Idle" could vary depending on each use case, of course, but in this case I would be interested in the power consumption for the standard configuration (no additional devices or accessories connected), fully charged, freshly logged in to the default OS (preferably a clean install), with WiFi turned on and connected, and no additional apps started.
And then each of us can take it from there.
(07-24-2019, 01:57 PM)fire219 Wrote: The battery in the Pinebook Pro (and the original Pinebook, for that matter) is 37Wh. That is 3.7V and 10Ah. Because, ya know, watt-hours = voltage * amp-hours. Wink
From what I've seen so far [1], the battery in the Pinebook Pro is 3.8V (nominal) and 10000 mAh = 38 Wh. Model Name: NV-40110180.
[1] Early photo of the innards posted by Luke: PINE64 Community Stall at FOSDEM 2019
https://forum.pine64.org/showthread.php?...6#pid44316
Assuming the CPU and GPU are mostly idling, how long does it run on a charge?
[edit]
OK, about 10 hours at most with a new battery, from another post.  As the battery gets some age/use/cycles that starts dropping.  Marginal at getting through an 8 hour work day.  I guess you can fiddle with slowing down the cpu.
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,551 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 32,928 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 28,649 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 14,103 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 31,237 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 3,317 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 14,530 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 27,053 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 20,682 12-16-2020, 09:24 AM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 16,195 12-05-2020, 01:19 AM
Last Post: dsimic
