Specifications page update please
Found a few minor issues on the Pinebook Pro specifications page;
https://store.pine64.org/?product=14-pin...nux-laptop
The weight is given in both metric & pounds, (aka lbs). But the dimensions are not also given in inches.
(Yes, I know us yanks are behind the times... and we can use a unit conversion tool... however, it's just a few numbers.)
Next, the Flash section has a old data on upgradable size;
Flash: 64 GB eMMC 5.0 (upgradable up to 64GB). The first two batches release for PINE64 forum user edition contains 128G eMMC module.
Probably should read;
Flash: 64 GB eMMC 5.0 (upgradable up to 128GB). The first two batches release for PINE64 forum user edition contains 128G eMMC module.
If there is a different method to report web page typos and such, just let me know.
Arwen Evenstar
Princess of Rivendale
(07-28-2019, 12:58 PM)Arwen Wrote: Found a few minor issues on the Pinebook Pro specifications page;
Oh good catch! - I'll correct that tomorrow morning Smile
I prefer my measurements in furlongs and firkins, thank you very much.
Good catch!
Luke, I'm sure your busy Smile  but ..still reads Flash: 64 GB eMMC 5.0 (upgradable up to 64GB). Blush
traveling and without access to the store -- @pineadmin please fix Smile
Fixed...
pineadmin...
Thanks @pineadmin.
And now the dimensions in inches?
(For us horribly backward yanks!)
Arwen Evenstar
https://www.google.com/search?q=millimeter+in+inches
I'll leave you fill the form (left side in millimeter to get the output on the right in inch)
  Locked out after update Shylocked 5 4,876 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 10,697 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 3,846 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 3,702 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 8,966 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 4,924 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,221 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 13,115 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,283 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 5,615 10-19-2021, 01:57 AM
Last Post: j4n3z
