Purchase Rock64 V3?
So I've seen that some people have the V3, and I particularly desire one (or a couple) based on the RTC battery.  How does a person specifically order a Rock64 V3, and not get old V2 stock?  Thanks.
(06-28-2019, 03:31 AM)richardk Wrote: So I've seen that some people have the V3, and I particularly desire one (or a couple) based on the RTC battery.  How does a person specifically order a Rock64 V3, and not get old V2 stock?  Thanks.
Only V3 ship at this time, as V2 is effectively phased out.
You need to specify to shipping if you require rev 3. Please see comments below.
(06-28-2019, 07:09 AM)Luke Wrote: Only V3 ship at this time, as V2 is effectively phased out.
I have very different info.
I recommend to send query to "sales at pine64 dot org".The last answer was:
- Rock64-1GB Version 3 estimate will be available in end of July.
- There are limited quantities for Rock64-4GB Version 3 available. Please make note when you order.
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Good to know and thank you for correcting me!
Sad
"sales at pine64 dot org" informed me that there are no plans to produce Rock64-1G or Rock64-2G version 3 for now.
Away
actually Tllim said it a long time ago, that only the 4GB model will be LTS (due to maintenance complexities).
tell me, i probably tired everybody with this question, but still, Big Grin are uhs-i modes working ok on v3? i mean without any soldering or stuff. is it stable? have you tested speeds? i guess it should deliver around 70+ MB/s with good cards, (given the 150 MHz limit put by rockchip).
ANT - my hobby OS for x86 and ARM.
TL;DR: UHS-I modes ? Yes ! It is working with factory integrated HW patch and patch to DTS. My cheap SanDisk Ultra "speed up to 80 MB/s" (UHS-I).
# iozone -e -I -a -s 100M -r 4k -r 1024k -i 0 -i 1 -i 2
<snip>
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4     4462     4574    12393    12390     9799     5164
          102400    1024    12418    26892    67185    67292    66996    30158
Long version:
  • * There is design fault in official "version 3 production schematics". The embedded diode in Q8502 changes FET to magic smoke or any component on 1.8V supply (VCC_18) not aware about 2.7V (3.3V - Source-Drain Diode Forward Voltage). Maybe published schema is total fake to disable copying (see also difference in 5V PIN2+PIN4).
    [Image: rock64-ver3-designed-magic-smoke.jpg]
  • * Fault is resolved by factory patch (replaced Q8502 with some other rotated transistor and pullup resistor).
    [Image: rock64-ver3-factory-patched.jpg]
  • * I had to prepare patch to DTS to activate voltage switching and enable UHS modes. This patch is not in standard distributions now.
  • * Some testing and observation with patch.
    # ### switched to 1.8V (gpio-30 is hi)
    # head -4 /sys/kernel/debug/gpio
    GPIOs 0-31, platform/pinctrl, gpio0:
    gpio-0   (                    |vcc_host_5v         ) out hi
    gpio-2   (                    |vcc_host1_5v        ) out lo
    gpio-30  (                    |?                   ) out hi
    # ### vccio3 domain switched to 1.8V
    # tail -4 /sys/kernel/debug/regulator/regulator_summary
    vccq_sd                          1    3      0  1800mV     0mA  1800mV  3300mV
        ff500000.dwmmc                                               1800mV  1950mV
        ff100000.syscon:io-domains                                      0mV     0mV
        deviceless                                                      0mV     0mV
    # ### mmc1 (sdcard) is running 150 MHz
    # cat /sys/kernel/debug/mmc1/clock
    150000000
    # ### booted to ultra high speed
    # dmesg | grep mmc1
    [    4.379677] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    4.520429] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
    [    4.913212] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    4.917711] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
  • * There are more tests with "Samsung EVO UHS-I (orange)". Also with 200MHz because Synopsys DesignWare Mobile Storage Host Controller was designed so as I wrote elsewhere.
    # ### without patch
    # dmesg | grep mmc1
    [    3.529051] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    3.581582] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
    [    3.581652] mmc1: new high speed SDHC card at address 0001
    [    3.582126] mmcblk1: mmc1:0001 BB1QT 29.8 GiB
              102400       4     1876     2460     7732     7751     8763     1701
              102400    1024    17982    13841    23239    23259    23261    12913
    # ### with patch
    # dmesg | grep mmc1
    [    3.881125] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    3.950459] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
    [    4.465921] mmc1: new ultra high speed SDR104 SDHC card at address 0001
    [    4.494979] mmcblk1: mmc1:0001 BB1QT 29.8 GiB
              102400       4     3781     3598    14463    14509    14485     2230
              102400    1024    28554    29160    67172    67270    67152    19281
    # ### with "200MHz" patch (not recommended)
    # cat 200.patch
    diff --git a/arch/arm64/boot/dts/rockchip/rk3328-rock64.dts b/arch/arm64/boot/dts/rockchip/rk3328-rock64.dts
    index 9d848967..2b15b339 100644
    --- a/arch/arm64/boot/dts/rockchip/rk3328-rock64.dts
    +++ b/arch/arm64/boot/dts/rockchip/rk3328-rock64.dts
    @@ -698,7 +698,7 @@
            cap-mmc-highspeed;
            cap-sd-highspeed;
            disable-wp;
    -       max-frequency = <150000000>;
    +       max-frequency = <200000000>;
            num-slots = <1>;
            pinctrl-names = "default";
            pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>;
    # dmesg | grep mmc1
    [    3.333112] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    3.402596] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
    [    3.793574] mmc1: new ultra high speed SDR104 SDHC card at address 0001
    [    3.794066] mmcblk1: mmc1:0001 BB1QT 29.8 GiB
              102400       4     4024     3762    15374    15388    15330     1988
              102400    1024    29919    30415    86725    87439    86829    17539
Buy me a beer !
Away
  Rock64 v2.0 u-boot SPI issues ju0n 0 792 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,120 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 28,415 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 16,755 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 18,718 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,841 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,918 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,941 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,295 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,920 11-28-2022, 02:18 PM
Last Post: Macgyver
