02-17-2018, 04:53 PM
My issue was due to the USB connector on the adapter. I added a bit of solder to the contacts and now it works fine in all my computers.
USB -> eMMC is now available.
02-17-2018, 09:44 PM
08-17-2018, 04:24 PM
(11-22-2017, 12:37 PM)Tony32 Wrote: Thanks for the quick replies! I ordered the Rock64 today. I wonder if its possible to dual boot easily like with NOOBs. Dual, triple, whatever boot. Just look up extlinux. The debian image for rock64 by ayufan uses extlinux which is a grub replacement boot system. You can boot as many images as you like.
03-20-2019, 10:11 AM
How about fixing the eMMC? It has a volume on it that I cannot seem to get rid of no matter how hard I try (see the following post)
https://forum.pine64.org/showthread.php?tid=7277 Seriously - I have tried everything I could find on Google and every other search engine to no avail. Is this chip totally bjorked? I literally am afraid to plug the other one in for fear I will brick it, too.
07-24-2019, 02:21 AM
wow,cool! But l wonder which is better, eMMC or SSD?
07-27-2019, 04:27 PM
| Rock64 u-boot for eMMC Build Error | mexicanflyer | 0 | 4,829 |
09-18-2022, 02:29 PM Last Post: mexicanflyer |
USB3.0 to eMMC Adapter... | MattDralle | 2 | 7,222 |
10-28-2021, 12:20 PM Last Post: tllim |
| Pine Rock64 eMMC lifespan | moonspell79 | 3 | 7,472 |
08-19-2021, 06:46 PM Last Post: bcnaz |
| Receiving errors about eMMC (?) | acasta | 11 | 27,892 |
09-24-2019, 10:26 PM Last Post: ridgarou |
How to Write an Image to the eMMC Module Tutorial | MarkHaysHarris777 | 55 | 182,315 |
02-06-2019, 04:02 PM Last Post: tllim |
| flash image to sd/emmc through ethernet | LMM | 0 | 3,979 |
02-04-2019, 07:36 AM Last Post: LMM |
| Card emmc | Auggoncalves | 2 | 6,462 |
06-25-2018, 03:20 AM Last Post: Auggoncalves |
| Debian to eMMC? | Hoerli | 7 | 15,590 |
05-06-2018, 05:41 PM Last Post: pfeerick |
| [SOLVED] stuck at emmc | dr_dre | 10 | 23,715 |
04-29-2018, 05:10 PM Last Post: pfeerick |
| eMMC errors | MrFawlty | 8 | 15,075 |
04-02-2018, 09:33 PM Last Post: tllim |
