Hardware Status Monitoring?
Is it possible to measure hardware status (core temperature, core voltage, core clock, memory voltage, memory clock, etc.) on the Rock64 under Linux? So far, I've managed to read core temperature and clockspeed, but that's about it.
I know vcgencmd works on the Raspberry Pi, and was ported to the Pine64, but I haven't seen anything similar for the Rock64.
(03-20-2018, 12:48 PM)Leapo Wrote: Is it possible to measure hardware status (core temperature, core voltage, core clock, memory voltage, memory clock, etc.) on the Rock64 under Linux? So far, I've managed to read core temperature and clockspeed, but that's about it.
Do you know about this script?
/usr/local/sbin/rock64_diagnostics.sh
Readily available is the cpu temperature and cpu frequency - as reported by rock64_health.sh or rock64_diagnostics.sh
You can get the voltage (in microvolts) of the cpu here : /sys/class/regulator/regulator.7/microvolts
It used to be regulator.4, but it seems that is now for one of the USB ports.
eval cat /sys/class/regulator/regulator.{0..12}/name
regulator-dummy
vcc_phy
vcc_sys
vcc_sd
vcc_host_5v
vcc_host1_5v
vdd_logic
vdd_arm
vcc_ddr
vcc_io
vdd_18
vcc18_emmc
vdd_10
A lazy test of
eval cat /sys/class/regulator/regulator.{0..12}/microvolts
tells us that regulators 2,3,6,7,9,10,11 & 12 are the only ones reporting any voltages. So it looks like you can get the voltage of the SD card, eMMC, and CPU. regulator.8 which looks like it may be memory related doesn't seem to report any voltage info.
#!/bin/bash
REGULATOR_PATH="/sys/class/regulator/"
for regulator in `ls $REGULATOR_PATH | sort -V`; do
   echo $regulator, $(cat $REGULATOR_PATH/$regulator/name), $(cat $REGULATOR_PATH/$regulator/microvolts 2>/dev/null )
done
yields
regulator.0, regulator-dummy,
regulator.1, vcc_phy,
regulator.2, vcc_sys, 5000000
regulator.3, vcc_sd, 3300000
regulator.4, vcc_host_5v,
regulator.5, vcc_host1_5v,
regulator.6, vdd_logic, 1050000
regulator.7, vdd_arm, 1100000
regulator.8, vcc_ddr,
regulator.9, vcc_io, 3300000
regulator.10, vdd_18, 1800000
regulator.11, vcc18_emmc, 1800000
regulator.12, vdd_10, 1000000
I'm not sure what the other regulators are controlling... you might be able to work backwards from the names through the schematic to see what they are hooked up to... assuming the names are right...
(03-20-2018, 09:35 PM)evilbunny Wrote: Do you know about this script?
Hadn't seen that before, but it uses the same method I'd already figured-out to get CPU clockspeed and CPU Temperature. Doesn't appear to pull any of the other stats I'm after, though.
(03-21-2018, 05:28 AM)pfeerick Wrote: You can get the voltage (in microvolts) of the cpu here : /sys/class/regulator/regulator.7/microvolts
That was incredibly helpful, and got me on the right track, thank you!
Quick reference of the monitoring points I've discovered so-far:
CPU Temp: /sys/class/thermal/thermal_zone0/temp
CPU Volts: /sys/class/regulator/regulator.5/microvolts
CPU Freq: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
GPU Freq: /sys/devices/platform/ff300000.gpu/devfreq/ff300000.gpu/cur_freq
SYS Volts: /sys/class/regulator/regulator.3/microvolts
For clarification, "SYS Volts" appears to be the 5v input that the Rock64 runs from (Handy for making sure your power supply is up to scratch). And you're right, it looks like the buck converter handling the memory isn't reporting voltage. That's kinda concerning... From the specs, it should be running at 1.2 or 1.25v for DDR3LP, but getting the real voltage would be nice.
I wrote this C program to monitor the CPU temp. Just put it in Geany or another C compiler, save it as a *.c file, I call it tempCheck.c
Then compile it and run it.
Code starts after this.
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
void sleep_ms(int milliseconds)
struct timespec ts;
ts.tv_sec = milliseconds / 1000;
ts.tv_nsec = (milliseconds % 1000) * 1000000;
nanosleep(&ts, NULL);
int main()
int nanosleep(const struct timespec * req, struct timespec * rem);
FILE *temperature;
double T;
while(1)
temperature = fopen("/sys/class/thermal/thermal_zone0/temp", "r");
if(temperature == NULL)
printf("Can't measure the cpu temperature");
else
fscanf(temperature, "%lf", &T);
T /= 1000;
system("clear");
printf("The cpu temperature is %6.3f C.\n", T);
fclose(temperature);
sleep_ms(500);
}return 0;
(03-31-2018, 06:30 PM)NicoD Wrote: I wrote this C program to monitor the CPU temp. Just put it in Geany or another C compiler, save it as a *.c file, I call it tempCheck.c
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
struct timespec ts;
int main()
FILE *temperature;
double T;
while(1)
else
T /= 1000;
system("clear");
sleep_ms(500);
}return 0;
Thank you ! Smile
[attachment=1374][attachment=1374]
Is this sufficient for your needs?
https://forum.pine64.org/showthread.php?tid=4462
.jpg   monitor.JPG (Size: 215.73 KB / Downloads: 982)
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
struct timespec ts;
int main()
FILE *temperature;
double T;
while(1)
else
T /= 1000;
system("clear");
sleep_ms(500);
}return 0;
For those that don't want to compile a program, this can be done in two lines of bash ;-) :
temp=$(cat /sys/class/thermal/thermal_zone0/temp)
echo ${temp::-3}.${temp:(-3)} C
  The state of mainline hardware decoding CounterPillow 17 32,940 01-26-2022, 03:39 PM
Last Post: sigmaris
  Hardware acceleration using FFmpeg gusarg81 0 5,042 08-21-2020, 01:36 PM
Last Post: gusarg81
  hardware-accelerated video transcoding (Plex) on Rock64 mdr 2 11,550 02-07-2019, 03:42 PM
Last Post: mdr
  How to do hardware decoding of video? SuperSaiyanCaleb 9 29,045 08-28-2018, 01:39 PM
Last Post: mcerveny
  H264 hardware encoder not work sueshieh 3 10,473 11-02-2017, 03:57 AM
Last Post: dalmate
  What is name of gpio hardware on a rock64? gene83 6 11,053 10-05-2017, 07:57 AM
Last Post: gene83
  4.4 and Mainline Status Matrices Luke 0 3,871 08-17-2017, 02:32 AM
Last Post: Luke
