Rock64 v3 and SD-Cards
I have seen many problems with the Rock64 v3 in the last few days.
Many customers have told me that existing Rock64 images suddenly no longer boot in v3.
We have verified this and found that apparently v3 can not cope with many SD cards. The booting of eMMC goes without problems.
If a customer has bought a new v3 and nothing works, contact us, we will send you an emmc card for the purchase price without any profit.
markus@humberg.de
Stickied and being looked into. How many others are experiencing issues?
From what I've heard, the issue is that GPIO0_D6 (SDMMC0_PWREN) is left floating by current Linux devicetree configurations, but needs to be set to high or low in order to select an appropriate SDCard voltage.
You can solder a connection between test pad 2302 and 3.3v to revert your Rev3 board's SD-Card slot to Rev2 behavior, which should work with all cards.
If you have a UHS-capable MicroSD card, you can solder a connection between test pad 2303 and ground to force the slot into UHS mode.
Edit: The test pad can be located on the back of the PCB, near the center. I've highlighted it in this drawing, in red: https://i.imgur.com/F9BCSkj.png
Issue has been identified and solved. New images from mrfixit2001 and ayufan will have the fix.
(05-10-2019, 06:03 AM)Luke Wrote: Issue has been identified and solved. New images from mrfixit2001 and ayufan will have the fix.
I have upload the mrfixit200 debian image that works with Rock64 v3 to file server and here is the download link: http://files.pine64.org/os/ROCK64/v3/roc...9_2.img.xz
My bootlog with this image, after the loading kernel message it sits flashing the power LED twice per second and no more output or network activity.
Have tried a few different SD cards from 16GB to 64GB, all Class 10/UHS1.
DDR version 1.13 20180428 ID:0x805 N In LPDDR3 786MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT Boot1 Release Time: Feb  2 2018 15:41:39, version: 2.46 ChipType = 0x11, 143 SdmmcInit=2 0 BootCapSize=0 UserCapSize=0MB FwPartOffset=2000 , 0 SdmmcInit=0 0 BootCapSize=0 UserCapSize=60952MB FwPartOffset=2000 , 0 StorageInit ok = 24000 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa3d00 RunBL31 0x10000 NOTICE:  BL31: v1.3(debug):9d3f591 NOTICE:  BL31: Built : 14:39:02, Jan 17 2018 NOTICE:  BL31:Rockchip release version: v1.3 INFO:    ARM GICv2 driver initialized INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 1 INFO:    plat_rockchip_pmu_init: pd status 0xe INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:   Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 U-Boot 2017.09 (May 09 2019 - 11:48:17 -0400) Model: Rockchip RK3328 EVB DRAM:  4 GiB Sysmem: init Relocation Offset is: fed15000 I2c speed: 400000Hz PMIC:  RK8050 (on=0x02, off=0x01) vdd_logic 1100000 uV vdd_arm 1100000 uV MMC:   rksdmmc@ff500000: 1, rksdmmc@ff520000: 0 *** Warning - bad CRC, using default environment In:    serial@ff130000 Out:   serial@ff130000 Err:   serial@ff130000 Model: Rockchip RK3328 EVB switch to partitions #0, OK mmc1 is current device Unknown command 'rkimgtest' - try 'help' Card did not respond to voltage select! mmc_init: -95, time 9 Unknown command 'rknand' - try 'help' Unknown command 'rksfc' - try 'help' Unknown command 'rksfc' - try 'help' Bootdev: mmc 0 CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)   apll 400000 KHz   dpll 1572000 KHz   cpll 1200000 KHz   gpll 491009 KHz   npll 600000 KHz   armclk 600000 KHz   aclk_bus 150000 KHz   hclk_bus 75000 KHz   pclk_bus 75000 KHz   aclk_peri 150000 KHz   hclk_peri 75000 KHz   pclk_peri 75000 KHz Net: Warning: ethernet@ff540000 (eth0) using random MAC address - e2:b5:61:c5:27:cc eth0: ethernet@ff540000 Hit key to stop autoboot('CTRL+C'):  0 Unknown command 'boot_android' - try 'help' Unknown command 'bootrkp' - try 'help' switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 351 bytes read in 4 ms (85 KiB/s) 1: ROCK64 Retrieving file: /Image reading /Image 22226952 bytes read in 1006 ms (21.1 MiB/s) append: console=tty1 rw root=PARTUUID=deedbeef-02 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr= eth1addr= serial=c3d9b8674f4b94f6 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 loglevel=3 Retrieving file: /rk3328-rock64.dtb reading /rk3328-rock64.dtb 72924 bytes read in 8 ms (8.7 MiB/s) ## Flattened Device Tree blob at 08300000    Booting using the fdt blob at 0x8300000    Loading Device Tree to 00000000f6eed000, end 00000000f6f01cdb ... OK Adding bank: 0x00200000 - 0xff000000 (size: 0xfee00000) Total: 4576.971 ms Starting kernel ... DDR version 1.13 20180428 ID:0x805 N In LPDDR3 786MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT Boot1 Release Time: Feb  2 2018 15:41:39, version: 2.46 ChipType = 0x11, 144 SdmmcInit=2 0 BootCapSize=0 UserCapSize=0MB FwPartOffset=2000 , 0 SdmmcInit=0 0 BootCapSize=0 UserCapSize=60952MB FwPartOffset=2000 , 0 StorageInit ok = 23989 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa3d00 RunBL31 0x10000 NOTICE:  BL31: v1.3(debug):9d3f591 NOTICE:  BL31: Built : 14:39:02, Jan 17 2018 NOTICE:  BL31:Rockchip release version: v1.3 INFO:    ARM GICv2 driver initialized INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 1 INFO:    plat_rockchip_pmu_init: pd status 0xe INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:   Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 U-Boot 2017.09 (May 09 2019 - 11:48:17 -0400) Model: Rockchip RK3328 EVB DRAM:  4 GiB Sysmem: init Relocation Offset is: fed15000 I2c speed: 400000Hz PMIC:  RK8050 (on=0x02, off=0x01) vdd_logic 1100000 uV vdd_arm 1100000 uV MMC:   rksdmmc@ff500000: 1, rksdmmc@ff520000: 0 *** Warning - bad CRC, using default environment In:    serial@ff130000 Out:   serial@ff130000 Err:   serial@ff130000 Model: Rockchip RK3328 EVB switch to partitions #0, OK mmc1 is current device Unknown command 'rkimgtest' - try 'help' Card did not respond to voltage select! mmc_init: -95, time 9 Unknown command 'rknand' - try 'help' Unknown command 'rksfc' - try 'help' Unknown command 'rksfc' - try 'help' Bootdev: mmc 0 CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)   apll 400000 KHz   dpll 1572000 KHz   cpll 1200000 KHz   gpll 491009 KHz   npll 600000 KHz   armclk 600000 KHz   aclk_bus 150000 KHz   hclk_bus 75000 KHz   pclk_bus 75000 KHz   aclk_peri 150000 KHz   hclk_peri 75000 KHz   pclk_peri 75000 KHz Net: Warning: ethernet@ff540000 (eth0) using random MAC address - e2:b5:61:c5:27:cc eth0: ethernet@ff540000 Hit key to stop autoboot('CTRL+C'):  0 Unknown command 'boot_android' - try 'help' Unknown command 'bootrkp' - try 'help' switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 345 bytes read in 4 ms (84 KiB/s) 1: ROCK64 Retrieving file: /Image reading /Image 22226952 bytes read in 1007 ms (21 MiB/s) append: console=tty1 rw root=/dev/mmcblk1p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr= eth1addr= serial=c3d9b8674f4b94f6 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 loglevel=3 Retrieving file: /rk3328-rock64.dtb reading /rk3328-rock64.dtb 72924 bytes read in 8 ms (8.7 MiB/s) ## Flattened Device Tree blob at 08300000    Booting using the fdt blob at 0x8300000    Loading Device Tree to 00000000f6eed000, end 00000000f6f01cdb ... OK Adding bank: 0x00200000 - 0xff000000 (size: 0xfee00000) Total: 4577.812 ms Starting kernel ...
(05-08-2019, 09:49 AM)Leapo Wrote: From what I've heard, the issue is that GPIO0_D6 (SDMMC0_PWREN) is left floating by current Linux devicetree configurations, but needs to be set to high or low in order to select an appropriate SDCard voltage.
It works! I couldn't get it to work connecting it to 3.3V (I'm using UHS cards) but only to ground.
Yup, just confirmed that the hardware fix works on my new v3 as well.
(05-06-2019, 10:04 AM)Humberg Wrote: I have seen many problems with the Rock64 v3 in the last few days.
markus@humberg.de
As I was just about to order me one rock64 board, I came across this post. So the obvious question is, can I order one now and have no problem with it or should I wait a little bit? I don't want to mess around with the hardware.
(05-27-2019, 12:33 PM)Leapo Wrote: Yup, just confirmed that the hardware fix works on my new v3 as well.
Did you mean SW fix?
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,692 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,523 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,930 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,492 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,771 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,142 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,444 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,428 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,839 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,190 11-28-2022, 02:18 PM
Last Post: Macgyver
