New Builds from ayufan (0.8.X) w Video/3D/Mate desktop
#31
I used bionic-lxde-rock64-0.7.9.0rc10-1067-arm64.img.xz on an eMMC and it installed very quickly with, apparently, no problems. Seems quick. The problem I have is that I can not access any external drives, powered, non powered and flash drives. sudo fdisk -l shows them clearly but I cannot seem to mount them as they are not in fstab. I've messed up fstab before so would prefer not to have to edit it.
On my previous img they appeared automatically on the desktop, but video performance was poor hence this update to ayufan's image.
Is there a simple way to make them appear at start up? I've tried accessing them through the USB3 and 2 ports and through a powered hub, but it seems to make no difference.
Edit: I hadn't noticed that I had not downloaded the latest image. Now I'm using bionic-lxde-rock64-0.8.0rc10-1125-arm64.img Problem of automount is solved in this image, but now I cannot get any browser to work. Tried apt-get update/upgrade/dist-upgrade but still no joy. Tried reburning the image but still no joy. Maybe I've downloaded a corrupted image.
One step forward - one step back!
Edit: May 7th Tried bionic-mate-0.8 on eMMC but it fails to get passed
[ systemd-journald[292] : Failed to send WATCHDOG=1notification message: Transport endpoint is not connected
See screenshot.  [Image: 19y-rock64.jpg]
 Tried changing power supply and keyboard to a wireless keyboard in case anything was upsetting the power supply. No go.
Tried bionic-lxde-rock64-0.8.0rc10-1125-arm64.img on an SD Card - boots smoothly but neither web browser will work - firefox doesn't load, and Chromium just logs me out. Smplayer causes a reboot. Symptoms the same after update/upgrade. I'll try and work out what img I was using before and go back to that, as everything did work, but there was no graphic acceleration.
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12)
PineTab2 Arch Danctnix 6.4.2
(04-03-2019, 12:36 PM)gedas07 Wrote: I have a Bionic installed, and when i try to update with
sudo apt-get install linux-rock64 -y
then answer too me that
Leyendo lista de paquetes... Hecho
Creando árbol de dependencias
Leyendo la información de estado... Hecho
linux-rock64 ya está en su versión más reciente (0.7.9).
Says that i am in 0.7.9 , how can i update to 0.8?
Can somebody help me
Same problem with Debian stretch
linux-rock64 is already the newest version (0.7.9).
How do I update to 0.8 ?
Paul
Paul
P.S. do not upgrade to rc10 because it's not booting...
I've reverted to 0.7.9-1067 and edited my sources list, as you recommended. Carried out sudo apt-get update and upgrade but am now faced with a bewildering list of firmware images and Linux headers, in synaptic. Apparently I have installed:
uname -r
4.4.132-1075-rockchip-ayufan-ga83beded8524
What image should I be installing, to avoid rc10, or am I missing the point?
(I still have no way to mount external drives even though gparted sees them)
Edit: I tried:
sudo apt-get update -y
It is now broken again (will not boot). I assume that I attempted to upgrade to rc10.
'Stumps pulled'
Ayufan said there will be a new release today (hopefully!) that'll fix the no booting with RC10.
I can't wait to test it. Big Grin
With what command can I know which one I have installed, if 0.8 or 0.9?
(09-08-2019, 03:27 AM)gedas07 Wrote: With what command can I know which one I have installed, if 0.8 or 0.9?
uname -a
Almost. Rather: `dpkg --get-selections | grep linux-rock`.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
  How to Change Video Memory Amount gazhow64 0 2,014 12-10-2022, 04:12 PM
Last Post: gazhow64
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 3,317 03-14-2020, 06:39 AM
Last Post: cenicero
  Remote desktop access Rock64 over Internet hg6806 2 6,029 12-11-2019, 08:27 PM
Last Post: default_user8
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 6,585 09-19-2019, 07:00 AM
Last Post: Malmgren
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 10,521 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 4,893 06-13-2019, 02:05 AM
Last Post: pineadmin
  How fast is rock64 if a desktop? heocb 11 22,239 04-21-2019, 09:14 PM
Last Post: a1w.ca
  Video : Media Script for the Rock64/4K video in Linux NicoD 1 6,850 03-30-2019, 02:17 AM
Last Post: zet_lab
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,492 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 6,307 03-22-2019, 05:11 PM
Last Post: Luke
