login to GUI desktop hangs when PCIe SSD is plugged in
I'm running Ubuntu 18.04  and have updated and upgraded everything.  If I plug in the PCIe card for my nvme SSD, boot up, everything works fine.  I can run mongo on the nvme drive no problem.
As long as I don't log in ( to the desktop gui ), the system seems to work fine.
Or, if I remove the PCIe card and reboot, I can log in to the GUI desktop.
The problem only happens when
   1.) PCIe nvme card is plugged in,  and
   2.) I log in to the GUI desktop.
Thoughts?
Known issue which is worked on.
(04-24-2019, 02:02 AM)Luke Wrote: Known issue which is worked on.
That's good to hear.  Is there an issue or bug that has been registered?
Yes, both on ayufan's git and in the thread on mrfixit2001 debian build
So it affects both builds/ kernels.
In short, for some (yet unknown) reason, the lockup only happens with pulseaudio is installed. If you would like to help then please connect UART and dump a couple lockups and provide them here.
Also, change extlinux to:
append console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 no_console_suspend initcall_debug
  PCIE interface power on too late Slark Xiao 0 2,969 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  PCIe gen1 timeout - how to debug tosi 3 10,066 03-10-2022, 05:06 PM
Last Post: db579
  PXE boot - unable to login LMM 2 5,701 04-22-2021, 02:59 PM
Last Post: LMM
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 3,360 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 3,395 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 5,163 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 10,103 10-20-2020, 10:52 AM
Last Post: GreyLinux
  screen reader Orca on Ubuntu 18.04 Bionic LXDE Desktop 32bit bluciano 0 3,436 05-07-2020, 03:31 AM
Last Post: bluciano
  PCIe x4 mode - Lane 3 failure acdkyn 1 5,629 04-24-2020, 01:32 PM
Last Post: kuleszdl
  Considering buying and question on the PCIe slot MobileJAD 25 64,911 11-07-2019, 03:10 PM
Last Post: hmuller
