interface error on OMV
I installed OMV from ayufan
then I want to config the interface from DHCP to static ip. But When I applied after saved it, there is an "networking.service - Raise network interfaces" error occured.
I logged in and input the "hostname -I" command, it print two ip addresses as:
192.168.0.9 192.168.0.100
the first ip is from dhcp, and the second ip is static ip I hope it to be.
and I input "ifconfig eth0", there is only one ip displayed, it is 192.168.0.9.
So I had to change static ip to dhcp again, and the network is ok now.
So, the question is: how can I set static ip for it?
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,512 11-26-2024, 11:08 AM
  PCIE interface power on too late Slark Xiao 0 3,001 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  wifi interface on debian mruser1 2 4,831 10-14-2021, 09:07 AM
Last Post: mruser1
  TP-Link ARCHER T2U PLUS AC600 unrecognized/build error thelabratrules 1 4,955 04-03-2020, 08:29 AM
Last Post: thelabratrules
Exclamation physical disk properties Standby error Neo2018 0 3,958 03-16-2019, 11:41 AM
Last Post: Neo2018
  Camera interface with rockpro64 rahulsharma 4 9,695 09-26-2018, 12:33 AM
Last Post: rahulsharma
  Dual SATA-II Interface Card question and NAS question RockPro64Newbie 5 10,766 08-17-2018, 10:58 PM
Last Post: RockPro64Newbie
  Rock64 and ROCKPro64 PCI-e to Dual SATA-II Interface Card Redwid 5 15,803 05-10-2018, 07:37 PM
Last Post: pfeerick
