USB -> eMMC is now available.
My issue was due to the USB connector on the adapter. I added a bit of solder to the contacts and now it works fine in all my computers.
(02-17-2018, 04:53 PM)GeerGuy Wrote: My issue was due to the USB connector on the adapter.  I added a bit of solder to the contacts and now it works fine in all my computers.
Thanks on the tips and pass to production team for improvement.
(11-22-2017, 12:37 PM)Tony32 Wrote: Thanks for the quick replies! I ordered the Rock64 today. I wonder if its possible to dual boot easily like with NOOBs.
Dual, triple, whatever boot. Just look up extlinux. The debian image for rock64 by ayufan uses extlinux which is a grub replacement boot system. You can boot as many images as you like.
How about fixing the eMMC? It has a volume on it that I cannot seem to get rid of no matter how hard I try (see the following post)
https://forum.pine64.org/showthread.php?tid=7277
Seriously - I have tried everything I could find on Google and every other search engine to no avail. Is this chip totally bjorked? I literally am afraid to plug the other one in for fear I will brick it, too.
wow,cool! But l wonder which is better, eMMC or SSD?
(07-24-2019, 02:21 AM)DonnaAlfaro Wrote: wow,cool! But l wonder which is better, eMMC or SSD?
In general, eMMC is better.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,752 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 7,134 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,408 08-19-2021, 06:46 PM
Last Post: bcnaz
  Receiving errors about eMMC (?) acasta 11 27,705 09-24-2019, 10:26 PM
Last Post: ridgarou
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 180,725 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 3,936 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 6,401 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 15,498 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 23,465 04-29-2018, 05:10 PM
Last Post: pfeerick
  eMMC errors MrFawlty 8 14,970 04-02-2018, 09:33 PM
