Slow SMB Transfer speed.Sent multiple email to Pine64 website and No single reply
I have the problem with file transfer speed with my Rock64 (4Gig ram with Pine 64 power adapter). Rock64 connected to Gigabit router port.
From Windows Surface Book pro3 PC (connected to AC wifi) to Rock64 external USB 3.0 HDD: Only get: 10- 16 MB/s.
Back from Rock64 to Surface Book pro3 PC ONLY : 12-19 MB/s
Sent multiple email to Pine64 website and No single reply. Such a terrible company, will never buy Pine64 product anymore.
I have tried all version of OMV from ayufan, pine64 website, pre-release or stable version. Check my USB3 to SSD adapter and was confirmed with UAS support.
root@rock64:~# lsusb -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
root@rock64:~# lsusb -v -d 152d:1561 | grep -i interface
  bDeviceClass            0 (Defined at Interface level)
    bNumInterfaces          1
    Interface Descriptor:
      bInterfaceNumber        0
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
      bInterfaceNumber        0
      bInterfaceProtocol     98
      iInterface              0
I have no Idea how to fix this, what is going on? ?(
Thankful for all Ideas!
Have you even considered joining one of the community channels (discord or IRC) and asking for help?
As for your problem, start with iperf and determine if the issue is networking or drive related.
(03-12-2019, 03:29 PM)Luke Wrote: Have you even considered joining one of the community channels (discord or IRC) and asking for help?
Hi Luke, thanks for the replied. Can you please point me to instruction on how to use iperf? I read and tried it but don't understand it very well to use it.
You might try and search for a demo video or two on the 'tube if the documentation isn't helpful. It sounds like you may be testing a lot of factors at the same time... wifi, windows, etc. Might suggest isolation and a direct connection to the pine to start, and then reintroduce the other complicating factors.
  Wrong resolution and very slow start of wifi. jgpacc 2 6,090 01-11-2022, 03:55 AM
Last Post: alanwake82
  New use case for my Pine64 S265 4 9,524 05-22-2020, 02:13 AM
Last Post: S265
  transfer to ssd georgetina1 1 4,374 12-20-2019, 03:52 AM
Last Post: dukla2000
  MicroSD Speed? (UHS?) PoV 10 20,800 08-07-2019, 12:48 PM
Last Post: mcerveny
Lightbulb NAS + ​Pine64 ROCK64 = Few Important Questions FilipWozniak 8 22,456 04-14-2019, 09:21 AM
Last Post: default_user8
  C++ GPIO seg fault on Rock64 using Pine64-CPP Jeff R 1 5,720 02-06-2019, 07:40 PM
Last Post: Jeff R
  Rock64 as multiple server Sputnik 2 6,399 11-01-2018, 12:59 AM
Last Post: Sputnik
  Docker-CE on a Pine64 amarbl 3 11,576 10-16-2018, 05:52 AM
Last Post: maumoura
  Slow SMB transfers when sharing encrypted USB drive - is my CPU the bottleneck? oealias 3 8,157 04-01-2018, 03:42 AM
Last Post: pfeerick
