Rock 64 network error as soon as I try to write or read.
hi,
I'm trying to build a rock 64 nas with a 1tb hdd to upgrade from my raspberry pi nas that topped out at 11 MB/s.
I have installed OMV multiple times and followed tutorials. Everything seems to work. I can mount the network drive however what happened is that when I would write files to it it would start at 11 MB/s and slowly tail off to zero then windows gives me a network error and i have to restart the rock 64. I've tried everything. Bought a new usb 3 adaptor, installed various flavours of linux and used samba instead but the same error. ive tried disabling the uas driver all to no avail. It seems to be able to write some data but seems to get stuck on larger files.
Any ideas?
Thanks, George
(03-10-2019, 01:27 PM)georgegohl888 Wrote: hi,
Any ideas?
Thanks, George
Solved! turned out to be a crappy network switch!
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,087 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  Rock 64 failure / kernel panic n0021913 2 5,513 07-07-2022, 01:16 PM
Last Post: anchor00
  Rock64 enable 1-wire to read DS18B20 or Dallas temperature sensor Perry 2 5,234 02-12-2021, 08:02 PM
Last Post: Perry
  Got an error message when trying to flash the Rock64 OS ilan 0 3,352 06-29-2020, 04:53 PM
Last Post: ilan
  Rock64 v2 network issues alephnull 2 6,919 05-29-2020, 06:00 AM
Last Post: maccarry
  Rock64 no network ripcord 6 11,195 04-08-2019, 02:54 AM
Last Post: ripcord
  Rock 64 seem like a dead end munocat 3 7,489 03-21-2019, 10:13 PM
Last Post: thewonderer
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 165,115 02-06-2019, 04:02 PM
  Rock 64 a failure..very disappointed arxaios 5 10,383 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 12,607 04-18-2018, 09:12 PM
Last Post: pfeerick
