Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
#21
(03-04-2019, 05:54 AM)Neo2018 Wrote: no chance Confused >
Hello Neo2018,
Ok, you can remove the 'test' directory we created [Image: shy.png]
rm -rf /opt/test
I think that the only option is geting the disk out, connecting to usb(but you need a power supply connected to usb->sata controller.. because this disks are 3.5".. and usb allone can't power it.. a big of a annoyance..)
Does you like the disks always in max performance?
O noticed that yours is in APM level 254 ( max performance.. )
#22
(03-04-2019, 11:08 AM)tuxd3v Wrote: Ok, you can remove the 'test' directory we created [Image: shy.png]
rm -rf /opt/test
OK, already deleted.
I have an extra USB HDD 3.5 adapter with power supply. Previously used for RaspberryPi. The usb-> controller recognized the hard disk (model and serial number) well then. I hope it works.
I have to open the case anyway. I get a fan control upgrade with Arduino.
(03-04-2019, 11:08 AM)tuxd3v Wrote: Does you like the disks always in max performance?
The 4TB Seagate discs are mostly used for watching movies (DLNA, Plex and data backup like Nextcloud). Otherwise, the hard drive is sleeping.
The 500GB disc is 24/7 in operation.
Where did you see that? > O noticed that yours is in APM level 254 ( max performance.. )
I use OMV with these settings > [Image: 2R3Yf.jpg]
#23
I saw here
=== START OF INFORMATION SECTION === Model Family:     Seagate IronWolf Device Model:     ST4000VN008-xxxxxx Serial Number:    xxxxxxxx LU WWN Device Id: xxxxxxxxxxxxxxxxxxx Firmware Version: SC60 User Capacity:    4,000,787,030,016 bytes [4.00 TB] Sector Sizes:     512 bytes logical, 4096 bytes physical Rotation Rate:    5980 rpm Form Factor:      3.5 inches Device is:        In smartctl database [for details use: -P show] ATA Version is:   ACS-3 T13/2161-D revision 5 SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is:    Sat Mar  2 18:28:35 2019 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is:   Unavailable APM level is:     254 (maximum performance)
I have mines in mode 127,
Since it has no operating system running there, it will enter later in APM mode 1( StandBy )..
There exists a lag on first access, but after they are working fast, and a great part of the day, I am not using the Nas, so its nice
The disk is presented like normal to the OS, don't know why is hasn't worked
your /dev/sdb should have spits something out with or something else..
openSeaChest_Basics -d  /dev/sdb -i -v 4
To check the pcie controller:
dmesg|grep -Ei "ahci|pcie" --color
what is the output?
With usb adapter you should be ok then.
#24
(03-04-2019, 07:46 PM)tuxd3v Wrote: I saw here
Hello
At the time I tried a lot and probably put hdparm on default values or off.
Usually I always have it on 217.
(03-04-2019, 07:46 PM)tuxd3v Wrote: The disk is presented like normal to the OS, don't know why is hasn't worked
the self >
:~# openSeaChest_Basics -d  /dev/sdb -i -v 4 ========================================================================================== openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Basics Version: 2.8.0-1_19_0 ARM Build Date: Feb 28 2019 Today: Tue Mar  5 03:57:54 2019 ========================================================================================== open: Bad address open failure Error: 14 - Bad address Error: Could not open handle to /dev/sdb
(03-04-2019, 07:46 PM)tuxd3v Wrote: To check the pcie controller:
what is the output?
No result, no output.
#25
(03-04-2019, 09:37 PM)Neo2018 Wrote: No result, no output.
Well seems that the usb option its the only way..
#26
(03-07-2019, 06:09 PM)tuxd3v Wrote: Well seems that the usb option its the only way..
Hello tuxd3v
With USB have not tested it yet (little time)
But I discovered another problem. Much more important.
I'm having trouble setting in OMV > physical disk properties > Spindown time.
The hard drive goes too fast in standby mode.
I have created a new post in OMV Forum and PINE64 Forum.
Maybe you can look at it, or have a solution! It would be great.
Thank you.
#27
Hello tuxd3v
Thank you.
Hello Neo2018,
The APM mode 127, sends the disk in standby, relatively fast..
I don't know if you remember that I asked you about if you had something else Running from the IronWolf disk?
Usually, the best Thing is maintaining it only for Data, without Os and so..
Because if not, the disk will be waked constantly, reducing its life time (load/unload heads counts..)..
This has nothing to do with the PCIe card, or with the timers on the disk..
The timers by default are very nice, Seagate disks behave usually nicer in that regard..
If a disk is sleeping, and you issue some monitoring command on Him, it will wakeup, and I think this his the behaviour you are experiencing..
Maybe OMV is doing monitoring too much..
Try to use its corresponding SCSI counterpart, /dev/sgx, this can work for some commands, and doesn't usually wakeup the disks, but its more limited than query the /dev/sdX..
Maybe this is the problem..
#28
(03-18-2019, 05:50 AM)tuxd3v Wrote: The APM mode 127, sends the disk in standby, relatively fast..
The hard disk is used only for data> music, movies, data.
OS runs on the eMMC 64 GB.
(03-18-2019, 05:50 AM)tuxd3v Wrote: If a disk is sleeping, and you issue some monitoring command on Him, it will wakeup, and I think this his the behaviour you are experiencing..
For the test, I have the hard drive set to 128, SMART completely disabled. > No effect / same problem.
Hard disk changes to standby mode after 2 minutes.
OMV Forum report
#29
OMV Forum report
You can put it do  254 but then the disk will be always spinning , waiting energy even when you are not using him..
Stand By Means stop rotating, and only the controller has some circuits waken, to start the disk when needed..
If you do  hdparm -B 254 the disk go to sleep in the same way?
If then...
The reason for the Setup via a usb-sata converter with OpenSeaChest is Valid..
#30
(03-22-2019, 10:33 AM)tuxd3v Wrote: If you do  hdparm -B 254 the disk go to sleep in the same way?
Hello tuxd3v,
Here I did a test with 127 and 254.
Currently 192 is set, > hdparm does not respond to -S specifications, but it goes automatically after an indeterminate time in standby mode.
This is much better than 127, where after 2/5 min. in standby mode changes.
(03-22-2019, 10:33 AM)tuxd3v Wrote: The reason for the Setup via a usb-sata converter with OpenSeaChest is Valid..
Unfortunately, I do not have the time. But that is at the top of my list.
After this comment, (After this, not using hdparm at all ......) I have an idea.
What if I use a clean OMV without using hdparm. And immediately after mount the HDD, install or test OpenSeaChest. Accordingly, hdpart makes the problems and not PCI-e SATA-II Card.
or with another OS. (Which OS would be better suited?)?
is this worth a try?
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 27,510 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 9,120 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 84,018 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 8,435 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 9,401 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 43,256 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 5,280 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 5,312 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 6,034 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 16,139 07-31-2018, 12:40 PM
Last Post: dukla2000
