Boot from USB - What's about resizing the partitions?
Hello together
Yesterday my new Rock64 2GB arrived. Very nice piece!
I want to use this for IOT "iobroker"
There are for Rock64 ready made Armbian images.
I configured the Rock64 to boot from USB and create an USB3.0-Memorystick with this bootable iobroker Image.
It boots up, but then it stops. Could it be, that the memory or partitions of the 64GB Stick has to be resized?
When I use an SSD by an SATA to USB3.0 Adapter, I will not boot up at all.
I know this partition resizing of bootable USB-devices from the Raspberry Pi.
How is it at the Rock64?
Does anybody has a manual for this?
Thank you!
(02-28-2019, 01:38 AM)hg6806 Wrote: Hello together
Thank you!
I haven't played with a new armbian install in a while but shouldn't it resize on first boot?
Failing that install/use gparted to resize.
I mean, after booting the first time from SD card, you have to resize/expand the filesystem.
How do you do that on a USB-ästick or SSD drive?
Is there a How-to?
(02-28-2019, 05:46 AM)hg6806 Wrote: I mean, after booting the first time from SD card, you have to resize/expand the filesystem.
Is there a How-to?
Use gparted
What kind of partition I have to expand?
(02-28-2019, 06:00 AM)hg6806 Wrote: What kind of partition I have to expand?
It should be the largest one, just expand it by dragging the end of the partition to the end of the drive. Then click on apply.
  PXE Boot example? lewis 7 18,840 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  How to boot an older, working kernel bits 0 3,239 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 31,327 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 5,252 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 3,540 12-27-2023, 10:34 AM
Last Post: dstallmo
  Disabling last mount time check on boot acwest 0 2,424 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 14,360 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,986 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 6,954 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 3,882 12-20-2020, 02:24 PM
Last Post: Turbo
