how to build Stock Android Oreo 8.1 from source code for rock64?
i build the Android source 8.1,but not succcess boot from sd card,anybody know why ??
i just want to run the sdcard boot image for rock64 board by build it myself by http://files.pine64.org/os/sdk/ROCK64/RO...8.1.tar.gz source code.
rock64 img from (http://wiki.pine64.org/index.php/ROCK64_...d_8.x_eMMC) this is ok,
but why myself build is not work
any guy know why?
how  should i do , or change something?
I have a rock64  board(mem  1g),and i have download the ROCK64 Android Oreo ver8.1 SDK from link http://files.pine64.org/os/sdk/ROCK64/RO...8.1.tar.gz.
i have setup the android build environment for ubuntu16.04.1 LTS desktop,and build the source success
source build.sh
and i get the image in rockdev/Image-rk3328_box
vps@ubuntu:~/rk3328v81_box$ uname -r
4.15.0-39-generic
vps@ubuntu:~/rk3328v81_box$ uname -a
Linux ubuntu 4.15.0-39-generic #42~16.04.1-Ubuntu SMP Wed Oct 24 17:09:54 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
vps@ubuntu:~/rk3328v81_box$ ls -al rockdev/Image-rk3328_box/
total 2727264
drwxrwxr-x 2 vps vps       4096 Nov 23 07:49 .
drwxrwxr-x 3 vps vps       4096 Nov 23 07:47 ..
-rwxrwxr-x 1 vps vps    1048576 May 15  2018 baseparameter.img
-rw-rw-r-- 1 vps vps    1491516 Nov 23 07:47 boot.img
-rw-rw-r-- 1 vps vps   18970644 Nov 23 02:44 kernel.img
-rw-rw-r-- 1 vps vps     162126 Nov 23 02:31 MiniLoaderAll.bin
-rwxrwxr-x 1 vps vps      49152 May 15  2018 misc.img
-rw-rw-r-- 1 vps vps     168060 Nov 23 07:49 oem.img
-rwxrwxr-x 1 vps vps        981 May 15  2018 parameter.txt
-rw-rw-r-- 1 vps vps      49152 May 15  2018 pcba_small_misc.img
-rw-rw-r-- 1 vps vps      49152 May 15  2018 pcba_whole_misc.img
-rw-rw-r-- 1 vps vps    9260688 Nov 23 07:47 recovery.img
-rw-rw-r-- 1 vps vps      95232 Nov 23 02:50 resource.img
-rw-rw-r-- 1 vps vps 1201701108 Nov 23 07:48 system.img
-rw-rw-r-- 1 vps vps    4194304 Nov 23 02:31 trust.img
-rw-rw-r-- 1 vps vps    4194304 Nov 23 02:31 uboot.img
-rw-rw-r-- 1 vps vps 1396378072 Nov 23 07:49 update.img
-rw-rw-r-- 1 vps vps  154861692 Nov 23 07:49 vendor.img
but when i flash the update.img to sd card,
Win32DiskImager or SD_Firmware_Tool.
the board could note boot success!
[Image: rock64.jpg]
Hi, did you figure out a solution yet? I am facing the exact same issue
The Android source is set up to use the flash. You are booting from SD card and don't have a flash module. I tried screwing around with the source to adjust it to work from only SD card. I gave up after a while and bought a flash module.
It is unable to mount things because it is trying to mount them from the flash device.
What is the way to compile ? I tried 'source build.sh' but Build uboot failed ? Am I missing some tools ?
(03-13-2019, 02:52 PM)jonsmirl Wrote: The Android source is set up to use the flash. You are booting from SD card and don't have a flash module. I tried screwing around with the source to adjust it to work from only SD card. I gave up after a while and bought a flash module.
I don't have an EMMC Module and don't wish to buy one as I am using Rock64 in one of my products and EMMC Module is costlier as compared to SD Cards.
It would be better if Pine64 provides a patch file to fix things. They have released Android Oreo 8.1.0 Image for SD Boot so they should have the working source code with them.
(03-16-2019, 06:16 AM)aurel Wrote: Hi,
Probably. Posting the error logs on del.dog and sending the link here would allow me to help you
  rock64-android10-tv patchset for Firely AlexS 1 366 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 243,731 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,071 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,356 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,507 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,664 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,358 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,538 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,104 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,445 09-18-2020, 08:12 PM
Last Post: BowerR64
